Old 07-07-2007, 02:56 AM   #37
Pars
Drives: 07 Yaris Liftback
Bailout, Thanks for the tip regarding the engine cut-out, it's saving me $200/year. I use to think coasting in neutral was the proper way to save gas, but once I learned that the engine cuts fuel-flow when coasting, I'm now always in gear while coasting.
Pars is offline   Reply With Quote
Old 07-07-2007, 08:20 PM   #38
voodoo22
Drives: Yaris Sedan (auto)
Palsan raises some good points about how hypermilling can cause other drivers to waste the fuel you're saving.
I also live in Ontario; like Palsan. I drive 100 kms of the 401 highway (supposedly one of the busiest highways in North America) every day, from one side of Toronto to the other. I can understand what Palsan is saying, but I have to say that he left out another side effect of driving at the speed limit.
Quite often a series of drivers will latch onto me going 100 km/h and follow me for the length of their commute in the express. I think they do this because they feel too much pressure from the drivers behind them to speed excessively. If I caved into those same pressures and drove simply by the flow of traffic I would be going at speeds from 120-170km/h every day on my commute. Yes, that's right, 170 km/h. The people here are insane in their driving technique or lack of. 140 is almost the norm in the fast lane and less than a 2 second gap between cars. I'm sure most of these drivers are incapable of parrallel parking with the same small gap they give to the drivers in front of them.
So instead of taking the easy way out and going the flow of traffic, go the speed limit and let the people who can't deal with the pressure of slowing down speeders follow you at speed limit as well.
When I first moved to Toronto I tried driving the flow of traffic (even at those excessive speeds) in my current car. I was getting 8.6 l/100 kms. Since I gave up on that insanity, my mileage has jumped to 7.5 l/100km and on my best tank was an incredible 6.9 l/100 km on a 255 hp I6 car.
It took me a few months, but I now enjoy going 100km/h on my commute. I feel so much safer and also feel like I'm controlling the traffic around me. It's also amazing how many times I will pass the speeders who have had to stop in the fast lane because of every one cutting each other off.
One technique I employ which has greatly reduced my use of friction brakes is coasting in gear whenever I come up to where traffic is merging into the express. People here will cut you off wether you're going 90 or 150km/h so I just coast between 100-90, let everyone merge in safely and I have had virtually no close calls since employing this technique and have used my brakes almost never by merges any more.
I can't wait to get my Yaris in a couple weeks and get on this fuel mileage bandwagon. It's an auto (so the wife can drive it easier), but I'm looking forward to getting amazing gas mileage and driving a car which people expect you to be driving slower in.
Thanks for all the tips Bailout and others. I've felt that feeling in 2nd gear many times in my previous vehicles (all manual) where there is almost a shift feeling and the rides smooths out, but I never knew what that was until reading these posts.
voodoo22 is offline   Reply With Quote
Old 07-07-2007, 11:29 PM   #39
Pars
Yep, the 401 is a treacherous place to be, if you're in the GTA area. It's not so bad during rush hour, when everyone is force to slow down, but during the day, when you've got congested areas with the occasional opening for the idiots, it makes for a bad formula. That's why through-out the day, more times then not, some of the lanes are blocked-up from a accident. Plus there's all the constructions, that adds to the danger, since it forces the speeders to share the lanes with the regular drivers and takes up critical shoulder space. (BTW, shoulders are very good to have...which explains all the tragedy on the 400 near hwy 89...there's no left shoulder in that particular stretch...stupid.).
Normally, I'm a advocate for speeding. I'll be one of those guys cruising in the middle lane waiting for the speeder to pass by, so they can clear the way for me and also give me a better chance to avoid the traps. But, specifically the 401 in the GTA area, the speed limits should be followed religiously (unless you need to take it up a bit to steer clear of a truck). Then there's area like 401 near Napanee, a beautiful stretch of highway, which can safely support speeds of excess of 160km/hr. But, for some unknown reason (probably something personal), this dinky no-name town in the middle of nowhere has taken it upon themselves to aggressively police this particular stretch of highway and is crashing-in big time. It makes sense to have higher speed limits for these particular stretch of highway, not only does it eliminate danger caused by these 2-bit towns who put unsafe speed traps, but it also acts as a warning to drivers to slow down when approaching a questionable area, since the higher speed limits will suddenly go back to normal. It's already being done for the rural highway but not the major highways.
Anyways, I digress, but I know Bailout is an advocate for the 88km/hr speed limit, but he probably mostly travel the country highway (which are not setup to manage high speeds) and his time is probably paid for, even if he's late (assuming he needs to work).
Old 07-22-2007, 06:33 PM   #40
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
Not sure if this was discussed here in this topic...
Running with "a emptier gas tank", saves quite some weight, half a tank means 40pounds less. the car handles a little bit better and I've noticed a zipper acceleration when the tank almost get empty - only my impression ?
hystria is offline   Reply With Quote
Old 07-24-2007, 08:09 PM   #41
Canuck
Drives: 07 5 door Hatchback
Regarding faceout parking, wouldn't backing INTO the space to be face-out use as much gas as backing OUT of the space?
And keep in mind that in jurisdictions with only one plate, it is usually illegal to park face-out.
Canuck is offline   Reply With Quote
Old 08-09-2007, 09:14 AM   #42
Yaris Newbie
Drives: 2007 Yaris
So, here's a question from another post that got some response there but might be more suitable here. I was referred here anyway.
Regarding Driving under load.
In rolling hills, where coasting downhill is possible, but it is obvious that I will need to climb the next hill with at least some pressure on the accelerator... should I just forgo coasting down the hill and maintain constant pressure on the gas pedal the entire time (down and up the hill)?
Given these points already made:
Driving slower (to a point) increases gas mileage.
Moderate drafting (please no safety debate) increases gas mileage.
Would it be better to go 50-60 alone or to increase speed to 70 or slightly more to gain a draft off of a transfer truck (18 wheeler)?
At what speed should (the rare times I use AC) I roll up the windows and turn on the AC?
Will a cold air intake improve MPG?
Is there a difference in running the AC at a lower fan speed compared to higher temperature (more red on the circular dial) compared to turning the AC on for a while then off for a while? Or is the compressor doing the same amount of work in all three situations?
Yaris Newbie is offline   Reply With Quote
Old 08-09-2007, 08:10 PM   #43
flagmunkey
flagmunkey's Avatar
Drives: 2007 Yaris
Send a message via AIM to flagmunkey
i think what is ment is that you go into a dual spot and stop in the opposite one that is intended to be parked in, moving or coasting forward the entire time.
flagmunkey is offline   Reply With Quote
Old 08-10-2007, 12:48 AM   #44
BailOut
Steals terrorist's lunch
BailOut's Avatar
On smaller hills, yes. On larger hills, no.
While drafting does indeed offer decreased air resistance, it does nothing for rolling resistance. Going 50-60 alone is much better than drafting at 70. I only draft when I can find a proper vehicle going between 45 and 60 MPH.
None. Windows down is always much more efficient than using the a/c. Mythbusters proved as much as well.
Only if you drive like a testosterone-infested aggressive punk.
The compressor is basically a binary unit, being either on or off. As such it doesn't matter what the fan is set on. If the a/c is on the compressor is clutched 100%.
- Brian
Share the Road
Old 08-10-2007, 11:21 AM   #45
petesimac
Drives: Yaris LB
Bailout, I heard recently by the so-called experts, that one should roll their windows up when the speed of the car reaches 30 mph, as the drag reduces fuel efficiency -- have you heard this as well?
petesimac is offline   Reply With Quote
Old 08-10-2007, 11:40 AM   #46
BailOut
BailOut's Avatar
I heard that, too, and a few of us on CleanMPG quickly debunked it. Using an SGII one can drive around at various speeds and watch for an MPG change with the windows up or down. You wont' find one.
Then do the same thing with the a/c on or off and watch your average MPG instantly drop by 10-15%.
We know that the windows down affects drag, but it does so at a fraction of an MPG. Between all my measuring efforts the only time I have ever noticed the drag is when I'm FAS'ing one section of my commute home. In that section I already have a lot of rolling resistance and not much of a grade to maintain my speed before the next climb, and if I have my window fully down with a strong wind catching in it I can lose an additional 2 MPH from 60 by the bottom of that 1/2 mile hill. That's not exactly earth-shattering.
This correlates with what the Mythbusters show found both in their initial testing and their re-vistiing of the myth.
- Brian
Share the Road
Old 08-10-2007, 12:40 PM   #47
sherryberry
sherryberry's Avatar
Drives: 07 Blazing Blue Yaris
Send a message via AIM to sherryberry Send a message via MSN to sherryberry Send a message via Yahoo to sherryberry
I thought I saw a mythbusters episode that tried to see if you get better mileage with a/c or window down. Believe that the one w/ a/c ran out of fuel faster than the one with window down but I could be wrong since it's been a while since I've seen it.
Don't Milk the Cat!
-Said by me during a game of Cranium.
sherryberry is offline   Reply With Quote
Old 08-10-2007, 12:45 PM   #48
hehe mythbusters rocks
Old 08-10-2007, 12:48 PM   #49
sherryberry
i watch it all the time. Or at least I try to watch it as much as I can i like explosions
Don't Milk the Cat!
Old 08-10-2007, 11:31 PM   #50
Pars
For those who have the scangage. Is it possible to tell how much gas the car is using up while idling with the AC running?
Since it's hot outside and I don't want to disturb the little one's sleep, I might have the car idling for over 1/2 hr on occassions, just to make sure the little princess sleep isn't disturbed. The price for disturbing a babe's sleep is too high, so I'm not worried about the fuel cost, but it'd be nice to know.
Old 08-11-2007, 10:22 AM   #51
BailOut
BailOut's Avatar
Pars,
Please remember that the cost of burning fuel goes far beyond the price you pay at the pump. If you would like her to have a future free of the Arab stranglehold on oil - and the wars that come with it - we must cut back on our fuel usage harshly, and if you would like her and her own progeny to inherit a planet worth having the lessening of our usage and consumption of all resources is totally necessary.
With that said, you can use the SGII's GPH (gallons per hour) monitor to see the fuel usage at idle.
- Brian
Share the Road
Old 08-11-2007, 06:47 PM   #52
Canuck
But all it really proved was that for those vehicules (they were SUVs) ith those conditions, the windows down were more efficient than AC. I would not extrapolate to all cars. And there is a comfort thing too. windows down at 100kmh is really no fun.
Old 08-19-2007, 12:47 PM   #53
lgcharlot
'07 YARIS HB 5-SPEED
Drives: '07 yaris 3-door hatchback
On a couple of long trips from California to BC (2000 miles round trip), I was able to average 37 mpg in my 5-speed Yaris hatchback, that's at an average speed of 70 mph (113 km/h). On a 450 mile trip last spring, I deliberately kept my speed in the 50~55 mph (80~90 km/h) range to see what kind of fuel economy the car was capable of if driven conservatively: got 45.2 mpg (astounding for a a non-hybrid car running California's E-10 gasohol blend). On "pure" gasoline (with no added ethanol, if that's even available anymore), the car might have been able to top 50 mpg.
When I was shopping for a small car last year, I considered the Prius and the Insight, and quickly came to the conclusion that, at $25,000 (with taxes and DMV fees), those hybrids are WAY too expensive and can't even come close to matching the cost-per-mile of ownership of the Yaris at $12,000 (or even the Corolla at $15,000). On the freeway, which is 90% of my driving, the Prius only gets 13% better fuel economy than my Yaris, and there's no way you would ever recover the $12,000 price difference within the typical lifespan of these cars (150,000 miles at best). Maybe I would by a hybrid if gas was $10/gallon, and getting the absolute maximum fuel economy was crucial. Too bad you can't get the European version Yaris with the diesel engine here in the US - they probably get 60 mpg.
lgcharlot is offline   Reply With Quote
Old 08-19-2007, 08:05 PM   #54
fenwayfanatic94
buyin this car next
Drives: mazdampv & jeep liberty
surprised how much i know, surprises me how much more i could do. good information.
fenwayfanatic94 is offline   Reply With Quote
Fuel Level Gauge Stuck ? - 2007 Yaris Sedan kaboom New YARIS Purchase Forum 9 05-15-2007 02:58 AM
Fuel consumption US Yaris vs. Canadian Yaris Driver Performance Modifications 8 10-29-2006 02:27 AM
