Janghwa, Hongryeon
Drives: 20th AE VW GTI Join Date: Aug 2007
Bridgestone RE750, 205/55-15
Anyone running this tire?
I checked the "math" section of the tire guide, but it seemed like another language to me :( Basically, if I'm running the OEM wheels, will this tire (A) fit, and (B) have the same rolling diameter?
22B | 藤原とうふ店 | Fatal Frame | 呪怨 | 장화,홍련 | Strong Bad
How to survive a Zombie attack "The inerasable scars, left by the palms of my hands" 365tuners |
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
SPONSORED BY
Yes, 205/55/15 will fit your stock steel rims with no problem. And, yes it is the recommended replacement upgrade size for 185/60/15 with basically the same diameter. Install 205/55/15's with confidence.
*Oh, BTW, post some feedback and pics when you upgrade tires so other members can benefit from your experience. Last edited by kimona; 08-17-2007 at 12:03 AM. |
#4 | |
Janghwa, Hongryeon
Only reason I asked was because the tire guide mentions something about rim width also playing a part in selecting the aspect ratio.
Recommended rim width for the OEM 185/60 (23.7") is 4.5-7.0"; for the 205/55 (23.9"), it's 5.5-7.5", so you'll be fine.
Janghwa, Hongryeon
Cool beans :)
I figured it would be OK, just making sure. I've been modding cars for years and I've had two "awakenings" in two days on this site. Crazy stuff I tell you :)
![]() ![]() ![]() Drives: Black Yaris YRS 3dr Manual Join Date: Aug 2007
hang on
the stock steelies can handle up to 205's? 185/60/R15 is stock i think |
der Zeck
that is a perfect size.... that is what I am running for my winter tires on my stockies.....
der Zeck
or just click on my signature for recommended wheel/tire widths from 14-20 inch rims
hey, just try not to use 205's on the stock 5.5" width wheels.
i run 195/55R15 on my Yaris1 Ts wheels, and they are already pretty buldged. |
Well, 195/55's will work fine enough, but 205/55's are within spec and they do fit the 5.5" wheel within recommendation... no problem. Plus, 205's will fill the huge gap better and provide more of a footprint.
der Zeck
205's are fine on 5.5 wheels... like kimona said.... wider footprint
| Does anyone here know why Bridgestone tires are so expensive? | grampi | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 06-04-2007 12:10 AM |
