Old 05-02-2007, 09:03 AM   #55
Originally Posted by Sway84 View Post
i wanted to know which light code are the inside fan/ac components, ther eare three of those and i dont know whether the light can be changed from the stock green colour...or is it just the color of the inside sheet of the actual component?
please help me lol...
Here's all you need to know, eh?
http://www.yarisworld.com/forums/showthread.php?t=2275
Old 05-20-2007, 08:54 AM   #56
Sway84
Sway84's Avatar
Drives: 07 Yaris HB
Send a message via MSN to Sway84
parking light question
there are two sets of parking lights....one is easy to change, directly beside the headlight itself, there is another one that is behind the yellow attached panel on the side...
a) which light bulb is this one?
b) anyone have a DIY manual to putting it on?.. cause i looked at it yesterday and was soooc confused with changing that bulb...and is there a way to take that yellow panel out? without ruining my headlight?
Sway84 is offline   Reply With Quote
Old 05-20-2007, 08:58 AM   #57
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Which? the parking light next to the headlight, or behind the ornage reflector?
If behind the reflector, why would you bother changing it at all? Unless your removing the reflector somehow like the oversea's headlights look, its useless to change that bulb.
Old 05-25-2007, 09:06 AM   #58
Sway84
Sway84's Avatar
Drives: 07 Yaris HB
i wanted to know if the eagle eye LEDs on autoillumination.com work...they say 1157 on the bulb code..... and it was under the section 7507.... but im worried it wont fit in. anyone know if it will work?... its the newest LED on the top of that 7507 page...
Old 07-07-2007, 03:28 PM   #59
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
I am sitting here comparing my bulbs that I have compliled in my bulb box
7507 is the one you need for the turn signal, the pins are slightly offset while the 1156 for your reverse has straight pins, both bulbs are single contact
you need 7507 for you turns, if they don't have what you want you can buy the stuff and make your own or contact them they are very helpful
also superbrightleds.com has some great stuff
SPONSORED BY
Old 07-10-2007, 09:40 AM   #60
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Is 9003 and HB2 and H4 all the same? Just curious because I know of the HB2 and H4 are, but I wasnt for sure about the 9003.
Old 07-12-2007, 01:28 AM   #61
slvryaris
slvryaris's Avatar
Opening this back up. Popped off my map light covers in my sedan and noticed they are not DE3175's. I couldnt get them out but I am sure they are not the same as the dome light. Just noticed that the Hatchback doesnt even have a number for map lights although dont some hatchbacks have the reading lights????
Old 09-01-2007, 01:55 PM   #62
OgDogg
Gas Guzzler
OgDogg's Avatar
Drives: 07 Yaris Sedan S
The sedan uses 194 wedge bulbs in the map lights. :)
OgDogg is offline   Reply With Quote
Old 09-01-2007, 02:10 PM   #63
brickhardmeat
Lonesome Cowboy
so does the hatch
SPONSORED BY
Old 09-05-2007, 03:36 AM   #64
yaŽisdude™
yaŽisdude™'s Avatar
Drives: 2007 Yaris T-Sport
wow,nice thread
yaŽisdude™ is offline   Reply With Quote
Old 10-25-2008, 10:00 PM   #65
msfire671
ONE LOVE...YARiS LOVE!!!
msfire671's Avatar
Drives: Toyota Yaris
Send a message via MSN to msfire671 Send a message via Yahoo to msfire671
how about led sizes for a 2008 sedan....please?
msfire671 is offline   Reply With Quote
Old 07-21-2009, 01:40 AM   #66
toyota
SRacer
toyota's Avatar
Drives: Toyota Yaris 2007
Send a message via Yahoo to toyota
awesome! thanks for the info...
very helpful...
"If I go down, I do time. I do real time. I don't know about your other drivers but when I see flashing lights in the mirror I don't stop."
- Dominic, Fast & Furious
Learn The Truth about Six Pack Fast!
toyota is offline   Reply With Quote
Old 07-21-2009, 01:45 AM   #67
toyota
SRacer
toyota's Avatar
Originally Posted by Chris07LB View Post
SEARCH HiLEDS LED DOME LIGHT
Where did you get this at?
and how is the lighting?
would you say it's way better?
or the same, but whiter?
let me know, i think i might
wanna get the one for mine...
thanks
Old 07-28-2009, 09:39 PM   #68
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
Exclamation HELP!
I tried to change the turning signal lights puting 2057 insted of 992(7440A) wich are the one for I think it might blown out a fuse but thats my asumption and I tried looking for the fuse but i dont know where they at.any pictures any one? or location?
Originally Posted by sw07gt
Old 07-28-2009, 11:28 PM   #69
JumpmanYaris
USAF_SrA_E-4
Old 10-05-2009, 10:24 PM   #70
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Not sure if this has been addresses before on this thread or not, but here goes:
The Climate Control knobs take a Neo Wedge Type B bulb.
I discovered that the amber led's from autolumination.com are lighter than the Scion/Toyota amber, but the incandescent amber bulbs they sell are a perfect match. I have an amber scion radio, so this was important to me, as the 08 green bulbs were horrific with the amber radio.
Old 01-05-2010, 11:45 PM   #71
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
im looking at going LED for my tails, the 7443 led's are those duel brightness? so when there on and when you brake?
can I just get any 7443 LED or does it have to say Duel?
http://www.4055design.com
Old 01-25-2010, 04:03 PM   #72
brendiamondVIOS
Drives: yaris sedan S VIOS
are these the same as 2008 yaris's? and what size bulb is the courtesy side doors?
brendiamondVIOS is offline   Reply With Quote
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal hasher22 DIY / Maintenance / Service 88 03-06-2014 07:40 AM
Bulb sizes for all Yaris Models DJ_SpaRky Cosmetic Modifications (Exterior/Interior) 16 07-22-2009 11:23 PM
Accessory Bulb Types, anyone know? Ayka Cosmetic Modifications (Exterior/Interior) 135 04-29-2007 09:33 AM
