#91 |
It's all about VVTI
Drives: Yaris 5Dr LE White Join Date: Feb 2006
Blah, guess I will just mix it around, I felt as if higher octane give me better milage. and manual did said use as low as 87. So guess I'll be switching back and fourth, what could be the harm, right?
Ziv on Vitz '06. |
#92 |
![]() ![]() Drives: '93 toyota pickup Join Date: Jan 2006
no, not really i agree cars could adjust for lower octane by puttin in less gas per shot. but the car wont make any more power just because u put higher octane in.
#93 | |
![]() ![]() ![]() Drives: two yaris liftbacks Join Date: Jan 2006
#94 | |||
Only Happy When it Rains
Their is a reason all testing is done on 93 octane gas. Quote:
#95 |
Speed Wrenchin'
Drives: 2006 Yaris 3 door, Bayou Blue Join Date: Jan 2006
The engines management system is designed to give best fuel economy, lowest emissions etc. on low octane fuel.There are certain parameters programmed within the ecu for timing and fuel delivery. The set parameters will not continually advance the timing when better fuel is added.The timing will only advance to a point designed for low octane fuel. If any pinging or knocking is detected, timing will be retarded to prevent engine damage. Timing will only increase to the max that is allowed within the program. Hence why we can buy and replace prom chips that will allow more timing and more fuel delivery. An engine that is tuned for low octane fuel will not add any power or increased fuel economy or increased durability etc. etc. with higher octane fuel. You simply are wasting your money. Cheapest/easiest mods for power and increased economy are letting the engine breath easier. ie: better flowing air intake and exhaust.
Quench my thirst with gasoline |
#96 |
I believe that the ECU will advance to a point where it can take advantage of 93 octane fuel.
If that was not the case, why on earth would manufacturers give hp ratings and fuel economy ratings and make sure you know that the car was tested with 93 octane fuel? |
#97 |
Speed Wrenchin'
Is the yaris designed to run optimum on 93 octane fuel? My manual says 87 to 91. I do not think you would see any noticable difference between 87 and 93 in the Yaris. It isn't that much of a difference money wise anyways at the pumps. If a person feels better using 91 or 93 go for it, see if there is a difference. Personally until I get a performance chip, I will stick with 87. We are getting ripped as it is at the pumps.
#98 |
I don't know if it will actually make any difference, I'm just commenting that the manufacturers seem to bend over backwards to make sure we know all tests are run using 93 octane fuel.
#99 |
Speed Wrenchin'
Wonder if there is some sorta tie-in with the oil companies? Make people think " Gee maybe I should use 93 too" Maybe the car manufactorors really are getting some gains from it, I certainly am not an expert, but everything that I and a lot of others know about engines points to no advantages for this application. Hey, I guess try it for yourselves, my only problem is that I hate to see people get burned more than we already are. This is my final answer.
#100 |
lol, you could be right. I wouldn't be surprised if the automobile manufacturers get a kickback from the oil companies, or they would've been sincere in finding alternatives to oil.
I prolly will test it when I finally do get my Yaris, which will hopefully be in May or June, but I don't have the money to preorder one, so we shall see. |
#101 |
It's all about VVTI
So far... I just switched back to 87... from 92.
But I did a lot less highway and much more city on 92 tank, so it's really hard to say. I did not notice any "significant" gain in milage on 92, not as much as my last car. Both roughly 560~80 clicks. ** And yeah, like I mentioned before, when I went back to the dealer, they are tryin' to make that chant in your ears "high octane, high octane....." **
Ziv on Vitz '06. |
#102 | |
I want JDM bumpers!
Drives: 5 Dr Yaris RS in Blazing Blue Join Date: Feb 2006
#103 | |
#104 | |
It's all about VVTI
Ziv on Vitz '06. |
#105 |
![]() ![]() ![]() ![]() ![]() Drives: 06 3-dr auto RS Join Date: Jan 2006
Latest tank: About 37.99 miles/imp.galon or about 32.75 miles/US galon or about 13.47 kms/liter or about 7.424 liters per 100 kms. My results have been quite consistent(=no improvement
#106 |
Speed Wrenchin'
Almost identical swng!
#107 |
swng and yariman, is that with an automatic or manual transmission.
#108 |
Speed Wrenchin'
Mine is an auto
