OK, so today I went out to Pep Boys to buy a Microfiber glove since my bro got one and said it works very well, so i decided to get one...
I get back in my car with my friend and decide to test it out on my semi-dusty dash. It worked just as planned. ![]() WTF!!???!? The display was like bleeding or something!? I was so upset! I couldn't come up with any other explanation other than the micro fiber glove and maybe some sort of static electricity messing with the display. My friend said she heard static when i was wiping away. As I'm driving away and calling my dealer to see if i can take it in tomorrow morning to get this taken care of i notice that the globs of bleeding are disappearing and it's going back to normal. Eventually the display looks normal again and there are no globs of crystal or whatever that stuff is made of. I'm so confused! What do you guys think caused this? The microfiber? Static electricity from it? Even though there is the plastic covering to protect the speedometer and what not... My brother uses the same one and this has not happened to him and the packaging of the glove has no warning of any type. I want to throw out that glove now, but i don't really know if it was the cause or it was just coincidence? A little help guys...
hmmm it may be static, acter all, these LCDs work by using electricity to turn them transparent or opaque.
As for your brother, if I recall properly, the LCD screen on the sedan is directly exposed, while on the LB, there is an angled plastic shield in front of the gauges?
#3 | |
Finally someone responded! lolAnd no i have the shield too! Just like the LB...that's why i was like wtf? Did it go through the plastic? lol
now that's just plain weird, I doubt a glove could generate that much static, unless you were really giving your dash a vigorous rub...
I guess, next time you use that glove, be sure to check the display, if it does it again, it's gotta be linked somehow...
Is that LCD??? Its bleeding from all sides so I doubt you might have accidentally pressed too hard, but ya that is weird.
H8R
You need some gas!
On that note if you're friend put too much pressure on the lcd that would also cause it to bleed. I've seen people do it to laptops and computers all to much, they'll go to point at something at the screen and poke it and then it'll mess up. |
Yeah but that's the thing, guys, go look in your car, you can't press directly on the LCD, there is a plastic window thing in the front of the gauges blocking access...
H8R
Doesn't make sense how it would happen to me then. Generally any type of static shock near direct or near direct contact to short anything. Regardless it should be under warranty, see if they're raplce the entire cluster for one with a tach :P
#9 | |
![]() ![]() Drives: '08 Polar White 3dr Join Date: Jun 2007
That's my guess. |
that is a possibility, I guess
*goes off to vigorously rub his cluster panel*
![]() ![]() ![]() ![]() Drives: Absolutely Red Liftback Join Date: Aug 2006
Thats why I use Swiffer to wipe the dust of the dash
![]() ![]() ![]() Drives: '07 Yaris S Sedan M5 Join Date: Jul 2007
Microfiber fabric is best for underwear, like microfiber seamless thong!
![]() I'm glad your LCD display is back to normal and thanks for the heads up about those cleaning stuff.
I usually use microfiber cloth for waxing and putting on rain-x.. i've yet to use it on the inside.
Don't Milk the Cat! -Said by me during a game of Cranium.
#14 |
Yeah, I didn't press hard or anything! I didn't even wipe the plastic shield thing just the actual dash in front of the speedometer. It's just odd because my brother uses the same thing in his LB...so unless the LCD's are made differently in the sedan than the LB that's all i can think of...and I'm scared to test it again in case this time it does not go back to normal!
#15 |
![]() ![]() ![]() Drives: 07 Yaris Liftback Join Date: Jul 2007
wtf. I use my mircofiber towel to wipe anything on my dashboard. Never to this problem before.
Toyota Yaris FTFW!! |
#16 | |
SEE WHAT I MEAN!? What's wrong with my car? Fix it.
#17 |
ya just send it my way.. and um.. i'll "fix" it.
#18 |
k, give me your address.
| How do you utilize the extra glove compartment? | fazali | General Yaris / Vitz Discussion | 144 | 05-24-2012 03:04 AM |
| What the hell does this mean? | Astroman | Off-topic / Other Cars / Everything else Discussions | 26 | 08-24-2007 12:34 PM |
| hitch wiring hell | twixt | DIY / Maintenance / Service | 9 | 06-02-2007 01:27 AM |
| Foglight housing and glass get hotter than Hell!!! | razzorjet2 | DIY / Maintenance / Service | 3 | 05-01-2007 10:48 PM |
| Hell Yeah! | Nutzoids | General Yaris / Vitz Discussion | 40 | 12-05-2006 03:54 PM |
