Old 09-23-2007, 09:13 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
oil filter a little loose
I changed the oil f and I notcd it was not really that tight.
I only tighten by hand because the oil wrench will damage the filter if you use those cleats on the new filter.Wasnt leaking though. what do you all use for added tighten.??
I use Mobile 1. I roll up on a block of some kind on the right front wheel and thats enough to get under there.I have
70k on mine and no probs at all. What would you recommend for a synthetic super high quality tranny oil???
yaris9876 is offline   Reply With Quote
Old 09-23-2007, 11:06 PM   #2
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
If it doesn't leak, that is tight enough!
Old 09-23-2007, 11:54 PM   #3
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
They don't need to be very tight, just snug using ONLY your hand. Filter wrenches are only for removing the old filter as they seem to tighten themselves over the course of 3000 - 5000 miles.
PetersRedYaris is offline   Reply With Quote
Old 09-24-2007, 03:41 AM   #4
RogueYaris
Drives: 2015 Abs Red
what do you mean by not really that tight? was it loose and jiggling or were you simply able to take it off with your hand instead of having to take a wrench to it?
RogueYaris is offline   Reply With Quote
Old 09-24-2007, 07:13 AM   #5
drecian
drecian's Avatar
Drives: '07 YR 3dr
On the instructions on the box of the Toyota branded oil filter, it said to tighten by hand THEN tighten a further 3/4 of a turn...
*shrug*
"I drive a silver egg"
"Huh?"
"An egg... You know; pretty much round, but with a pointy end; jeez..."
drecian is offline   Reply With Quote
Old 09-24-2007, 10:00 PM   #6
TLyttle
TLyttle's Avatar
I have been installing oil filters since they were bypass, using a roll of buttwipe as a filter medium, and the instructions for spin-ons has always been the same: turn on by hand until gasket contacts the block, then another 3/4-1 turn. Some people can't generate enough torque to make that extra, some can put another turn-and-a-half by hand (don't armwrestle that guy, or gal!). So the guide is ~1 turn. They usually recommend that one checks after a few miles to make sure it isn't leaking, a step that most people don't follow.
Old 09-24-2007, 11:34 PM   #7
punch
punch's Avatar
Drives: 2007 Yaris Sedan "D" package
strap wrench....
out of respect for nutzoid, I changed my avatar.
punch is offline   Reply With Quote
What about the oil filter???? Driver DIY / Maintenance / Service 28 10-24-2008 12:45 AM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 04:25 PM
Oil and Filter Change jonr0613 DIY / Maintenance / Service 6 02-10-2007 08:12 AM
don't think the dealer changed oil filter on first change gonzo452001 DIY / Maintenance / Service 0 01-13-2007 12:44 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 09:16 PM
