Old 10-22-2008, 05:52 PM   #19
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Originally Posted by marlondog View Post
Is your car scraping less in the front now that you have these shocks? Are you able to leave a drive-way without scraping?
There is going to be no change over slow speed driveways speedbumps, etc.
There is less tire rub and bottoming out over fast bumps and dips.
Old 10-23-2008, 10:35 AM   #20
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Would it be worth getting these shocks if I were using Tanabe Nf springs?
marlondog is offline   Reply With Quote
Old 10-23-2008, 11:31 AM   #21
largeorangefont
Break'em off some.
If you want better handling, yes.
Old 09-08-2010, 01:34 PM   #22
daddz07
Drives: Yaris 2008
Send a message via Yahoo to daddz07
Originally Posted by largeorangefont View Post
Yes, these are a much better deal than the TRD parts.
If you end up getting them and need them installed, PM me.
FREE??
daddz07 is offline   Reply With Quote
Old 09-08-2010, 08:46 PM   #23
yarrr
Drives: 07 sedan
You should have cut them a bit even with the TRD springs. You will bottom out a bit less if you cut them, but you wont feel any difference under normal driving.
TRD spring instructions say don't cut the bumpstops.
yarrr is offline   Reply With Quote
Old 09-08-2010, 11:55 PM   #24
sleey0
Drives: 2008 Yaris LB
I would cut the stops, fwiw.
sleey0 is offline   Reply With Quote
Old 09-09-2010, 12:03 AM   #25
^ TRD only drops 1.5", probably not enough to need to cut the bumpstops.
To compare, the Tanabe DF210 instructions (1.8" drop) specifically call for cutting the stops in half.
and.... the thread lives on!
Tokico Information nemesisz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-25-2007 08:21 AM
driving impressions Mead General Yaris / Vitz Discussion 14 05-06-2007 06:37 PM
