Old 10-23-2008, 08:14 PM   #1
Appalachian Trail 2007
Appalachian Trail 2007's Avatar
Drives: 2008 Yaris LB
Throttle position used as cruise control? HELP
I need some help with a project I'm working on. I'm trying to figure out a way to install a dial of some sort to control the throttle position. It would act as a type of cruise control though my speed would fluctuate as the terrain changed. I know that the yaris has a drive by wire throttle system so I'm wondering if any of you have seen something that would electronically lock-in a throttle position and disengage when the clutch or brake were pressed.
Thanks for any help
-Dave
3,441,567,453 posts BH (Before Hack)
Appalachian Trail 2007 is offline   Reply With Quote
Old 10-23-2008, 10:57 PM   #2
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
just buy a cruise control its cheaper and prolly ten times easier to hook up
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-23-2008, 11:19 PM   #3
thanks for the help but I don't want a cruise control...I want a throttle control
Old 10-24-2008, 02:20 PM   #4
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
Jam a wooden doorstop next to the gas pedal...
Reddog99 is offline   Reply With Quote
Old 10-24-2008, 06:18 PM   #5
ddongbap
Wait, I don't get what hes saying. A cruise control IS a throttle control. A cruise control also turns off when you tap the brake, or hit the clutch. Soo... I don't quite understand what else he could be looking for.
Old 10-24-2008, 08:04 PM   #6
battleversiontc
thats what i was saying
Old 10-24-2008, 09:53 PM   #7
Cruise control regulates the vehicle speed by controlling the throttle. He wants to just control the throttle position without worrying about speed. I assume that the purpose would be to allow tight control of fuel usage.
Besides the brake killing it, I would think to keep it safe you would also need to have a vehicle speed cut-off to keep it from running away when going down hill.
Old 10-24-2008, 09:55 PM   #8
exactly CTScott, thank you for the first useful post
Old 10-25-2008, 12:20 AM   #9
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
You're probably thinking of a throttle lock like what is commonly is used on many motorcycles. Unfortunately, all the bikes that use those have throttle cables, not electrical "fly-by-wire" throttle controls.
All modern cruise controls make use of computerized "black boxes" to control the vehicle speed, either built-in or aftermarket (the Rostra comes to mind, with two boxes). What you're asking for would be quite an engineering project. And you would probably the only customer...
Old 11-09-2008, 06:32 AM   #10
metalshark
MetalShark
throttle control
What you are looking for is a potentiometer with the same resistance curve as your throttle pedal sensor. You'd need to use an ohmmeter to measure the resistance of the pedal to get the right one. Then you need a 12 volt ice-cube relay with a start button and a seal-in to transfer control from the pedal to your new dial. The brake light switch could be used to disengage your control transfer relay if it had a resister in it's ground path of the right size. I've thought about doing this project as a DIY. You can get better mileage with this setup under hyper-mile concepts because you scrub off speed up hill and pick up speed down hill. I've already got Rostra cruise, but I think your a-barkin up the right tree with this concept.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Old 11-09-2008, 07:46 AM   #11
Look through the technical manuals posted in the DIY section. The electronic throttle uses two circuits (for safety in case one fails) and seems pretty straightforward...
Old 11-10-2008, 12:10 AM   #12
thank you both for your help perhaps I'll actually be able to pull it off.
Yaris.. Cruise Control. peanut New YARIS Purchase Forum 28 11-26-2017 07:17 AM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
Cruise Control in the LB RobotMan In Car Entertainment + Electronics (audio / video / alarm) 1 09-30-2007 03:43 PM
Rostra Cruise Control install done on MT AlexK DIY / Maintenance / Service 34 09-18-2007 04:21 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
