Old 10-28-2008, 12:37 PM   #19
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
It'll probably look better on a dark coloured car than one of the lighter-coloured cars. The rubber strip would probably be quite obvious in the gap between the bumper and bonnet.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 10-28-2008, 12:59 PM   #20
Aothachos
Drives: 2008 Yaris Sedan
Send a message via AIM to Aothachos Send a message via Yahoo to Aothachos
i would so do this deffinatly
Aothachos is offline   Reply With Quote
Old 10-28-2008, 01:03 PM   #21
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
Originally Posted by ROCKLAND TOYOTA View Post
i just looked at the camry ones we have and it just might work. its a little bit wider than yours but it can be trimmed. part number is 53395-06010..........
this looks to be a possibility for a toyota part....
Old 10-28-2008, 01:35 PM   #22
kou
Drives: 08 lb
i cant find part# sorry. jc whitney sells alot of weather seals this would be a good place to look.
Old 10-28-2008, 01:36 PM   #23
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
Hey Rockland, u mentioned the camry part could prolly be trimmed. Is that rubber flexible enough to bend to the shape of the Yaris hood where it would put? Did I DIY thread get started for this yet? How much and where to get that camry part so we can do this also if we don't have access to an old nissan layin around...
wsladaritz is offline   Reply With Quote
Old 10-28-2008, 01:40 PM   #24
kou
Drives: 08 lb
the idea started with the new camry. they have the hood seal which rockland is taking about.
Old 10-28-2008, 01:47 PM   #25
Stoln
Drives: 2007 5 Door Hatch
I did a search for the rubbeer seal for the cowl to hood and the following is the part number: 53383B SEAL, HOOD TO COWL TOP
53383-52050 NCP91 1 $16.28. Is this the part you are referring to, Klink10? I found the info at www.toyodiy.com My car is a 2007 5 door Canadian RS so the part number may vary but check this site out and enter your car info.
Stoln is offline   Reply With Quote
Old 10-28-2008, 01:52 PM   #26
kou
Drives: 08 lb
that seal is not as sturdy. you will need more clips to hold it in position.
Old 10-28-2008, 02:09 PM   #27
ChinoCharles
Drives: LB
Nice. Keep this thread rolling... more info! More info!
Old 10-28-2008, 02:21 PM   #28
Stoln
Kou,
What Nissan did you borrow the seal from. Hopefully you remember this since the part number is not on the tip of your tongue.
Old 10-28-2008, 02:23 PM   #29
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
i was just thinking about doing that!
Old 10-28-2008, 02:25 PM   #30
kou
Drives: 08 lb
i found 2 #'s i am going to check at nissan which it is so that i can see the image to make sure its the right one. get the info up later.
Old 10-28-2008, 03:08 PM   #31
Stoln
Awesome, thanks for getting this info for us, maybe you could do a DIY of the one you did so we can see where you drilled and how you managed to bend it to match the curves of the car
Old 10-28-2008, 04:05 PM   #32
Thej3sta2
Thej3sta2's Avatar
Drives: Soon to be LFA
that would be tight son
Thej3sta2 is offline   Reply With Quote
Old 10-28-2008, 04:43 PM   #33
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
+1. Cool clean mod kou. looks like stock, should be stock.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 10-28-2008, 05:50 PM   #34
kou
Drives: 08 lb
DIY in diy section.
Old 10-28-2008, 05:57 PM   #35
IsLNdbOi
IsLNdbOi's Avatar
Too bad they don't make white rubber strips like this...
Old 10-28-2008, 05:58 PM   #36
kou
Drives: 08 lb
i dont think it would look as bad as the gap.
underhood weather stripping drifto General Yaris / Vitz Discussion 3 04-18-2007 10:36 PM
