Old 11-01-2008, 05:47 PM   #19
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
Well if you are going CB do not skimp on the money and go SSB Get a good side band unit. Galaxy or Ranger are top units.
Old 11-01-2008, 07:45 PM   #20
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Isn't SSB outside of normal 40-channel CB bands?
Old 11-01-2008, 08:22 PM   #21
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
SSB Upper side band/Lower side band yes but your range is alot greater. I would guess for your purpose stay with a regular CB but I do advise the upper end uniden or cobra that has mic gain.
Old 11-01-2008, 08:42 PM   #22
Sodium Duck
╚══════════RN
Yup, the Uniden has an RF gain, plus PA capabilities -- ooo. And it's DIN sized, with a front firing speaker, which works out awesome for me.
Old 11-01-2008, 09:31 PM   #23
Originally Posted by Sodium Duck View Post
Just checked up on a CB forum I post at. They say I can use a CB antenna for AM/FM, so I'll be ordering 2 antenna's soon. Woot.
I'm going to go with either a 3' or 4' Wilson FGT, going to a Uniden PRO538W, for anyone interested.
Anyone have a comment on what size to get? I propped a tape measure on the side view mirror at 3' and 4'. I like how they both look and still can't decide.
For best reception a dipole antenna's length should be a fraction of he wavelength (1/1, 1/2, 1/4, 1/8. etc.) of the signal. Considering that FM radio goes from 87.5 - 108.0 MHz:
1/2 Wave Dipole Antenna
87.5 MHz: 5ft 4 - 3/16in
108.0 MHz: 4ft 3 - 31/32in
3/8 Wave Dipole Antenna
87.5 MHz: 4ft 0 - 5/32in
108.0 MHz: 3ft 3 - 1/32in
Most vehicles which have a whip antenna, use a 1/4 wave dipole (@~97 MHz) which is about 29 inches long. When you are tuning over range, you usually try to select an antenna length in center of the band.
CB runs from 26.965 MHz to 27.405 MHz. An 1/8 Wave antenna would be 4ft. 3 - 21/32in @ the center frequency of 27.185 MHz.
So, if you are going to use a matching pair of antennas, the 4' ones would probably be the best compromise for both FM and CB...
Old 11-02-2008, 09:43 AM   #24
Sodium Duck
╚══════════RN
Scott, you always got the best info! haha -- 4 footers it is.
Old 11-29-2008, 12:54 PM   #25
si9yaris
Drives: Foreign
I want to remove my antenna mount also.
What other parts need to be removed before I can drop the back half of the headliner to access the antenna?
Do I need to remove all those parts described in the service manual?
What about the "special clip" for things like the "roof side inner garnish" that is referred to in the service manual. Do those really have to be replaced?
si9yaris is offline   Reply With Quote
Old 11-29-2008, 01:08 PM   #26
Sodium Duck
╚══════════RN
You pretty much have to remove your entire interior to do this. From the sill plastic at the bottom of the doors, all the way up to the plastic that rests on the headliner -- and also all the plastic pieces in the hatch area. It all comes out like the service manual says.
Yes.
No.
Old 11-30-2008, 12:59 AM   #27
WolfWings
WolfWings's Avatar
Drives: Silver 2007 3Dr - Gryph
It's worth it to pick up another ten body-panel-clips from the dealership before you go tearing the interior out though, it might be a buck to ask for some at the service counter generally.
And honestly, a well-tuned antenna system matters far, far, far more than length of antenna. I say that having run everything from a 2ft to a full 9ft antenna on my Yaris so far to date, I've stuck with the 2ft antenna in the stock AM/FM antenna position because that position gave by far the best reception when I was moving the magnetic-mount antenna all over the car to test-fit locations. And our Yaris doesn't have enough sheet-metal to gain any benefit beyond about a 4' antenna on the roof, on the sides of the car it's even worse. The roof at least is a large, flat, horizontal panel of sheet-metal which is crucial for CB reception on a vehicle!
And there's zero, I repeat, zero tuning needed for the recieve-only AM/FM side. Any long length of wire will work great for an antenna. All CB antenna's work wonderful for AM/FM reception, even a length of coat-hanger wedged into a CB antenna mount works fine. The only time an antenna needs to be tuned is for transmission efficiency and to protect the transmitter from burning out.
But if you're going for left-side/right-side, get two matching CB antenna's, right down to everything shrot of the color of the vinyl cover, tune them individually, then hook them up with a co-phasing harness and you'll get vastly better reception and be able to run a far larger antenna while still getting full benefit from it because they'll act as a fair bit of a ground-plane for each other.
And I know I told you a'while ago, the CB->AM/FM splitter box you're looking for is the AR-1A by FireStik. :-)
It's well and good and all to quote signal theory at me, but I've tried no less than five lengths of antenna's on my car starting with the 'definitive' 102" stainless-steel whip antenna, carefully tuned them all, and invested a few hundred dollars in testing stuff until I found what works very well for CB reception. I'm usually able to pull in 10 miles range easilly on the highway vehicle-to-vehicle, and I'm only using a shitty Radio Shack CB that only cost $25 five or six years ago. All on a FireStik FireFly FL-3 3' antenna, w/ their 'light' strength spring.
It just goes to show, money invested in a good antenna is better than money invested in a good radio. :-) I'm gonna try to hook up an old 23-channel SSB remote-head unit I salvaged from an ancient Volvo truck, if it still works that'll be glorious as it's from the days of CB being something you needed a license to operate so they were quite a bit more powerful than modern units. And 'remote head' means all the controls are on the mic, the main unit gets mounted behind the dash or in the truck area.
WolfWings is offline   Reply With Quote
Old 11-30-2008, 08:05 AM   #28
Sodium Duck
╚══════════RN
I actually decided to get into HAM radio instead, lol. The CB radio's I wanted simply wouldn't fit in the Yaris. But -- there are tons and tons of HAM radios that do, and you get far superior range. So I'm ditching the dual antenna idea. I'm instead going to get a hidden antenna and mount it in the drivers side mirror, and the ham antenna is easy. I'll prolly end up getting a simple glassmount, people say they get good results with them.
I think for my first radio I'm going to get into 2 meters. I know a local HAM, and he's going to show me his setup and get me going. Once I finish finals at school, I'll study a little and take the test then get on the air. Woo.
Old 11-30-2008, 08:24 AM   #29
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
i never understood why you need a license to talk on a cb or ham.. why is that? can you be fined or arrested for talking on one without it?
Old 11-30-2008, 08:50 AM   #30
Sodium Duck
╚══════════RN
CB doesn't need a license anymore - HAM does. Probably because with CB you just can't get your signal out far enough. With a repeater and 5 watts, a HAM can easily hit 50 miles. The guy I know runs a a couple hundred watts in high frequency, and he talks around the world.
"Why Do I need A License?
Written by ARRL
Sunday, 14 August 2005
Although the main purpose of the hobby is fun, it is called the "Amateur Radio Service" because it also has a serious face. The FCC created the "Service" to fill the need for a pool of experts who could provide backup emergency communications in times of need. In addition, the FCC acknowledged the ability of the hobby to advance communication and technical knowledge, and enhance international goodwill.
Last Updated ( Monday, 14 August 2006 )"
As an example, during Katrina, many HAM's were firing up their rigs to get communications out since traditional means of communication were all destroyed.
Removing Liftback Guage Cluster Surround Ran Kizama In Car Entertainment + Electronics (audio / video / alarm) 3 05-09-2007 08:25 PM
07 yaris liftback and 06 xa test drive extenny General Yaris / Vitz Discussion 12 05-31-2006 11:56 AM
American colors for the LIftback? debbiezan General Yaris / Vitz Discussion 4 02-25-2006 01:38 AM
