#127 |
![]() ![]() ![]() ![]() Drives: 06 yaris 5-dr le man Join Date: Mar 2006
it's pretty clear to me that honda has raised the bar as far as subcompacts are concerned with the release of the new fit,
the yaris is still a great car and when considering overall price (from sticker to operating costs) is still the better choice. i think the future of subcompacts is that they will be outfitted with more of the amenities of larger, more expensive vehicles and people will pay for it in the name of better fuel economy, the fit clearly is moving in this direction. i don't think it's too subjective to say that the new 09 fit is the better car, but it is more expensive. |
#128 |
toyota
mpg = yaris is better
price overall = yaris is better looks wise= yaris rear end is better..i kinna like the new front for the phit. 0-60= as far as i know the yaris can do 8.5 sec which is same as the new phit now if we gonna talk about interior then the phit win that foh sure.. |
#129 | |
- The Black Ship Yaris - |
#130 |
![]() ![]() ![]() Drives: 2007 Yaris/2009 Phit Sport Join Date: Jun 2007
The Phit is an economy car...the Mini (much more expensive) is essentially a sports car. You're comparing apples & oranges. If you want to compare, you need to look at the Yaris, Versa, Aveo, Accent & Phit. The Mini (which I love, I think it's terribly cute) is in a different class.
#131 | |
![]() ![]() ![]() ![]() ![]() Drives: LB-Auto-PWR-ABS-Cruise-Springs Join Date: Aug 2006
The Yaris seems to get better city MPGs when NOT hypermiling. Normal driving by normal people. (ie - Folks who would never want or use a ScanGuage, like my wife) The Fit shines in MPGs on the Highway when NOT hypermiling. The Fit has 5 gears with what seems to be overdrive as well since my RPMs will drop when cruising eventhough i'm already in 5th gear. My Yaris, with cruise control wont get much above 40MPG at 65MPH. The Fit just loves 65MPH and gets close to 50MPG at 60 MPH with cruise control. If you do mostly highway travel, the Fit may be your buddy, by about 10MPG. If you are city mostly, the Yaris is the car for you.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum |
#132 |
toyota
i did not know that.. the new fit with 118hp can do 50mpg on hwy.. wow.. then again i did 45 mpg going 100 km/hr 95% on hwy on the way to camping last summer ..and thats me not using hypermill though..
#133 | |
My jaw dropped to the ground when I calculated this. I may be doing a Roanoke trip shortly so I can do another pure highway test. I will be going through rural highways with some lights. My Yaris has gotten wicked MPGs while hypermiling this route, like 46 MPG. This will be an interesting test.
#134 |
voodoo - Were you using crusie or foot control. With Foot Control you can get better MPGs. I am using cruise control in both cars to be fair. Now I do have Michelin HydroEdge tires on my Yaris that are slightly wider than stock, so that may be affecting my MPGs. On my Yaris they are pumped to 44PSI. On my Fit I have not touched the stock tire pressure. Haven't even removed a valve stem cap. With the Fit Sports low profile tires, I don't think I'm going to inflate them over the reccomended PSI just for ride comfort. The Fit is a little rough over rough roads, but in a good way.
#135 |
Good Point. My brother has a nice Craftsman digital tire gauge and I just bought a new tire pump.
#136 | |
the best i've been able to achieve on the highway in my yaris (manual) is 45 mpg (u.s. gallon), that's travelling a top speed of 110 km/h are you saying that you aren't adjusting your driving to get such good numbers? |
#137 | |
my trips are usually fairly short though, so this could be where i'm really taking a hit on the FE. i can achieve the mid 40's on the highway, but not travelling faster than 110 km/h (that would be around 70 mph i think), anything over 110 my FE drops significantly. i've had the yaris now for 3 years and have tracked the FE since the car was new, so i pretty much know what to expect depending on driving conditions and the time of year- that's why i found your numbers a bit high. |
#138 |
Fruit Fly
#139 |
that's probably what it is, my city trips are probably under 20 km round trips.
i don't have a scanguage either, but you're probably going to get a more precise reading by just crunching the numbers after filling up- i would like to try out a scangauge to see specifically what kind of driving is giving me the best FE, but to spend a couple hundred bucks on it is not worth it even in the long run. it would be nice to buy one as a group and give everyone a month with it to help them improve their driving, then pass it on to the next person. |
#140 |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
I'd choose my silver egg over any other car in it's class anyday. It's small, inexpensive, good on gas, reliable, ..and surprisingly a chick magnet (wasn't expecting that, but I'm not complaining
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
#141 | |
MORDSITH
Drives: 2007 Yaris Hatchback Join Date: Apr 2006
Its fuel economy is 1-2 mpgs off a Yaris (Canadian ratings anyways). And that equates to "irresponsible" gearing. C'mon hahahahaha that comment's a joke.
2007 Yaris Hatchback 5 Door LE, Manual, Package B, Bayou Blue Metallic |
#142 |
Yaris EPA Estimates are 29/35
Fit EPA Estimates are 28/35 1MPG off in the city... WOW! Not much difference there. We all know these numbers are not real world, but it does mean they are close in MPGs.
#143 |
i did read that while the new fit has more horsepower, the engine is more efficient now and gets better fuel economy than the previous generation despite having more power.
i'm not sure what technical changes were made to achieve this. |
#144 |
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
less emissions too
. There's days I could use a catalytic converter . Especially after fast foods . . Roll down that window !!!
| Yaris vs Fit vs Versa | SimplyYaris | General Yaris / Vitz Discussion | 45 | 07-15-2010 10:27 PM |
| Lower Mainland Yaris, Echo, Fit, Mini, meet | mojoyaris | Canada | 24 | 11-02-2008 01:16 AM |
| Good Bye Thomas Thread | uncleyaris | General Yaris / Vitz Discussion | 27 | 07-05-2007 08:38 PM |
