>=75% city driving, please share your numbers
For those of you interested, here is a table showing MPG (last 90 day average) of our members who drive Yaris mostly in city.
Toyota Yaris City MPG Anyone can participate and share your numbers. |
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
I drive about 75% highway and average 41 MPG. I have an auto tranny and I'm not yet convinced the auto tranny Yaris uses DFCO. However, auto tranny drivers can utilized VVTi programming to eeek out higher MPG. If the car thinks your in acceleration mode, the timing is set for that. However if the car thinks your in cruise mode (speed maintenence) it will reset the valve timing accordingly and this means higher MPG. So the trick is to get into cruise mode faster. From a red light I will accelerate a bit faster then most up to 2-3 miles over the posted speed limit, then back off the gas peddle until the car reaches the posted limit, then feather the gas peddle from there just to maintain the posted speed. My realtime MPG at 40 MPH is 53+ MPG. When I drive on the freeway, my realtime MPG on flat land at 60 MPH is 46-52 MPG. Following behind a semi truck (drafting) will give me a realtime MPG of 70+.
Compulsive Washer
99% city driving. See sig. Easily the worst mileage in YW (well, maybe except for the auto-x crowd.), more so if you take into account the fact that my engine is a 1.3.
36mpg all-city in the summer months with an intake...yaris 3dr 5spd
![]() Drives: 2008 Toyota Yaris, automatic Join Date: Oct 2008
75% city driving I'm only getting 26mpg.
![]() 50% I'm getting 32mpg. 32mpg is the best I've ever had, and I've had this consistently, so driving is pretty consistent as well. I am driving a new car, 2008 sedan with auto transmission. Only 2200 miles on it right now. I hope the mpg improves significantly or I should have bought a corolla. |
![]() ![]() ![]() Drives: 2007 Yaris Liftback Join Date: Oct 2008
I'm curious to see how much my mpg goes up on the highway, I'll keep a log of my mileage... I am taking a little roadtrip to Ms. for thanksgiving. I mainly drive about 75-80% city...
I really LOVE this car!!!
Drives: 08 Bayou Blue LB AT Join Date: Oct 2008
This tank was 35.81.
Finally broke that 34 mpg average today. Pretty good for an automatic and pretty much all city driving. 35 mpg here I come. |
![]() ![]() ![]() Drives: '08 Yaris MM 3d Lb, auto Join Date: Oct 2008
I work 9 days straight which is 100% city driving and get 35-36 MPG, then I get 5 days off which is 100% highway driving everyday to visit my parents who live 30 miles away who are elderly and I get 38-41 MPG, both with A/C off, except on really hot days. The lower of the two numbers reflects when the A/C is used. No hypermileage, just doing the speedlimit. Hope this helps... I know you wanted 75% city but I would be guessing.
Hackers suck! |
![]() ![]() Drives: 2008 Yaris LB 5 speed Join Date: Oct 2008
Congratts! I know you've been at this a while...
MetalShark
Drives: 2008 Yaris LB Join Date: Oct 2008
100 % city mileage
I just finished three weeks of work commuting. 33 miles per day. for 15 days. My average mileage was 43 at each fill up. I used all the hypermilling tricks you read about here. I use cruise and in the 16 miles one way I hit about three lights red. I average 40 mph. I changed from Mobil-1 5w-30 to Amsoil 5w-20 today.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header. |
Not really here...
Drives: 2008 Blazing Blue S hatchback Join Date: Oct 2008
I just got 37.25 MPG on 100% city street driving. That was with a lot of red lights too. It's this driving technique that is new to me called driving slower than hell. I shifted at or under 2000rpm's the whole time and kept the car under 65 at all times.
Liberate Tutemet Ex Infernis. |
All city driving. '07 Yaris LB with 5 spd. 31 to 33mpg on every tank.
'07 Polar White Liftback, 15in Alloy Wheels, Exhaust Tip, Cruise Control, Tinted Windows, TRD Valve Caps, PadsPlus Pads, |
![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
95% city if not higher. Short trips. 31-35 mpg Depending on my mood and destinations. Last tank was 29 tho...Not really concerned since gas is so cheap though. lol.
Compulsive Washer
I still hold the crappiest mileage title!
...yay? |
What?
City mileage depends mostly on how you drive. Highway mileage depends on how you drive and on what speed you're driving.
I can get 40+ in the city without trying too hard. Highway... just depends on the speed. Keep the speed down below 60, it can be 48 or more. Cruising interstate speeds of 75-80, it will be closer to 38. |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
I am guessing that city driving on the first tank is about 80%.
It's hard to say if I am really city driving, as the road to work has some stretches of 45 mph and very few stoplights. With that said, my first tank of gas yielded a 41.1 mpg !!! ![]() My old car, a 92 Geo Metro, got around 44-46 mpg city, and 48-51 mpg hwy. My new Yaris is not as good on gas, but is a much nicer car.
i get 37 mpg average on my 08 sedan auto
08 junction produce belta almost done and ready for paint 06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp 90 crx sir ls vtec turbo 755 hp mecp masters certified |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
50% city 50% highway
average = 42mpg. |
| Fuel Economy | swng | Fuel Economy Forum | 2089 | 01-23-2015 06:41 PM |
