Old 08-10-2006, 07:02 PM   #19
ketel0ne
ketel0ne's Avatar
Drives: 2007 Liftback Blazing Blue
Originally Posted by pauljk
Got my Scangauge last night! :-)
And, my last tank came in at 37.5. My best so far. Maybe the temps in the high 90s we'd been having torpedoed my mileage. (I was seeing low 30s for awhile)
ketelOne:
With your 15 wheels, did you find the default speed/miles reading on the SG was dead on? I checked miles for a 5 mile stretch against mile markers on freeway this morning, and it was right on! So, I guess that means I can believe it's speed readouts without adjustment.
Paul
P.S. I'm also interested in how others have routed the cable. So far mine's in the drivers glovebox, with cable trailing down the front. Not a great long term arrangement.
Congrats on your tank, higher air temp should produce higher mpg, but you will use your AC more.
Yep speed and miles dead on.
My cable is the same way at least for the time being.
ketel0ne is offline   Reply With Quote
Old 08-10-2006, 07:06 PM   #20
ketel0ne
ketel0ne's Avatar
Originally Posted by fnkngrv
I know nothing about this equipment...does it compile previous data stored then from when the vehicle first left production?
It is mostly a real time guage for:
Fuel Economy
» Fuel Rate
» Battery Voltage
» Coolant Temperature
» Intake Air Temperature
» Engine Speed (RPM)
» Vehicle speed (MPH)
» Manifold Pressure
(not available on some vehicles)
» Engine Load
» Throttle Position
» Ignition Timing
» Open/Closed Loop
and a trip computer for:
» Maximum Speed
» Average Speed
» Maximum Coolant Temperature
» Maximum RPM
» Driving Time
» Driving Distance
» Fuel Used
» Trip Fuel Economy
» Distance to Empty
» Time to Empty
» Fuel to Empty
and finally a scan code reader:
» Reads Trouble Codes
» Reads conditions that set the Trouble Code
» Clears Trouble Codes
» Turns off "Check Engine" light
» Tells you when vehicle is "Ready" to pass OBDII testing
» Make and store up to 10 rewritable special codes
to send to the vehicle computer
Old 08-10-2006, 09:48 PM   #21
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
Drives: 2007 Yaris Liftback and S13's
ketelOne:
Paul
MY Cable is also trailing down along the left side of Steering Column..not exactly pretty right now but i've got it "taut" enough that i never even touch it with my knee. It looks like it will BE REALLY EASY to run the cable behind the plastic dash and drill a hole directly into the driver's glove compartment (<--only on a Yaris..driver's GC...hehe). If i can find another Driver's GC Cover, I will cut it so that my Tachometer and Scangauge fit flush into it, and PROPERLY run the cables so that the Driver's GC is still accessible and useable for storage.
Thanks for all the help over the years, YarisWorld!!!
TRD_Yaris is offline   Reply With Quote
Old 08-12-2006, 07:23 AM   #22
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
darn you, echo hrs why you gotta "one-up" me? i really like your setup..you REALLY did a great job.
Old 08-12-2006, 09:18 AM   #23
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Beautiful work!
Old 08-12-2006, 12:01 PM   #24
tds12
This is my other ride.
tds12's Avatar
Drives: Wht, M, Power 2007 yaris HB
mount
I mounted mine resting on the stearing column directly behind the steering wheel. Took some drawer liner from the wife. Doubled it up to get a little lift. One drop of super glue to the scan guage. Scotch tape the liner to the column. I now have a tach and MPH in the normal positon. The scan guage weighs nothing so one small piece of scotch tape holds it on the stearing column.
tds12 is offline   Reply With Quote
Old 08-12-2006, 12:56 PM   #25
tds12
tds12's Avatar
Install photo
My scanguage mounting.
Old 03-16-2007, 02:20 PM   #26
365Motorwerks
Drives: Small and Black
If anybody still or now wants on of these little beautys just get in touch with me, I'll have a deal in the sponsor section in the classified!
And again echo_hrs has done a great job on that faceplate! Awesome mount!
365Motorwerks is offline   Reply With Quote
Old 04-03-2007, 07:31 PM   #27
AustinYaris
Drives: 2007 Yaris LB Manual
How are you guys installing these? How come I don't see any wires in any of the installs. Is everyone cutting holes in the area behind the Scangauge?
AustinYaris is offline   Reply With Quote
Old 04-03-2007, 07:49 PM   #28
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
Mine is on the steering column also. I ran the wire behind the gauge on top of the column easy to get it thu the crack between the dash and steering column you just push it thu from under the dash couldn't be easyer could be wrote better I am sure
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
Old 04-03-2007, 09:16 PM   #29
AustinYaris
Most likely, that's what I'll do too. I wonder how everyone else that didn't mount it on the steering wheel column did it. I saw a pic of one on the forums mounted right in front of the speedometer, and couldn't see any wires.
Can't wait to get mine in a few days.
Old 04-03-2007, 10:17 PM   #30
uncleyaris
How much this thing cost?
Old 04-03-2007, 11:04 PM   #31
365Motorwerks
Check it out in the sponsor classified... http://www.yarisworld.com/forums/showthread.php?t=4312
Old 04-08-2007, 10:52 PM   #32
AustinYaris
Got my ScanGuage2 finally. Here's my set up. I just stuck the wire under the steering wheel column.
Old 04-09-2007, 05:36 AM   #33
gonzo452001
You didn't have to come out on the outside like that cable is plenty long enough to keep it on the inside and still plug it in
oem style foglights
Scan GaugeII
Old 04-09-2007, 05:46 PM   #34
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
I just hit 47.2 the other day,try and beat that,I still had half a tank left.
I can get 40mpg with moderate accelaration,and 70-75mph on the road.
eco is offline   Reply With Quote
Old 04-09-2007, 05:58 PM   #35
AustinYaris
Got it done... thanks... I didn't realize that panel underneath the steering column detaches so easily.
Old 04-09-2007, 11:32 PM   #36
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
can this thing read my tires Pressure?
jamal1984 is offline   Reply With Quote
