Old 11-23-2008, 07:23 AM   #109
well this thread is already way off topic, so...
I only recently discovered the Princess Bride... I very often saw the quote "Hello, My name is Inigo Montoya..." but had no idea where it was from excellent movie, its cult status is certainly not inconceivable!
BTW thinkgeek.com now has a Dread Pirate Roberts articulated action figure
Now, back to your regular supercharger programming!
Old 11-23-2008, 09:30 AM   #110
SIPNGAS
I LOVE my Yaris!
SIPNGAS's Avatar
Drives: 2007 Polar White LB
Yeah..we did get a bit off-topic, huh?
LT, will you be working on the SC again today? We're all waiting!
Lisa
aka SIPNGAS
Old 11-23-2008, 09:33 AM   #111
SIPNGAS
I LOVE my Yaris!
SIPNGAS's Avatar
OMG!! Thomas!! I *love* that website!! Did you see the Office Space Kit?? Wow, I know what everyone in my Cubeville is getting from me for Christmas. FABULOUS!!
Lisa
aka SIPNGAS
Old 11-23-2008, 12:23 PM   #112
SIPNGAS
I LOVE my Yaris!
SIPNGAS's Avatar
Good luck today!
Lisa
aka SIPNGAS
Old 11-23-2008, 12:46 PM   #113
I might drop by, I promise not to wrestle with your car again... maybe the dog though...
Old 11-23-2008, 02:31 PM   #114
mrbond
mrbond's Avatar
As soon as I saw the CAI I also questoned it. I will also try to get an answer about that for you today.
Hey Garm, did you ever get in contact with Blitz to see if the compressor was compatible with the 2 pc CAI's?
Old 11-23-2008, 04:04 PM   #115
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Garm, we are leaving the shop (1:10). There are only two wires left to do and there's a conflict with the instructions that I have to ask the guys about that have done the install.
Old 11-23-2008, 07:25 PM   #116
LtNoogie
LtNoogie's Avatar
The S/C Activation Box stays inside the car so I run the loose wires through the wire loom.
Up on the firewall above and to the left of the ECU was a rubber plug that plugged a hole leading to the interior of the car. I pulled the plug out and from the inside slit a vertical and horizontal opening in the carpet that covers the hole.
I found the perfect gromment at Pep Boys that had a tapered side that pushed easily into the hole. I push the wire loom through that gromment and into the engine compartment.
There are four wires in the bundle that come from the S/C Activation Box. The instructions say:
"8. Run all the wires, except the red wire from the activation box, to the passenger side glove box area. (Leave the red wire on the driver’s side for now.)"
So we leave the red wire inside the car for now.
The blue wire that comes from the S/C Activation Box has a barrel crimp connector at the end of it, so I thought. There is another identical blue wire that comes off of the relay assembly that feeds through the grommet to go inside the car. The relay assembly stays in the engine compartment.
When I tried to crimp the blue wire from the engine compartment to the barrel crimp connector from the S/C Activation Box, the wire keeps falling out of the crimp. So, we cut off the crimp connector and solder the two ends of the blue wires together and shrink wrap the new connection.
Inside the engine compartment we slowly start snipping wires in the ECU harness, each of us double-checking the other to make sure we are snipping the correct wire. The new wires from the Fuel Control Unit connector harness are soldered one one by one onto the snipped ECU wires and the bundle shrink wrapped.
One wire from the Fuel Control Unit connector harness has to be spliced into the blue wire that went from the relay assembly to the interior of the car. We had to cut the blue wire and make a three-way blue wire connection. The third leg goes to the green wire from the Fuel Control Unit connector harness.
This completes all the wires that goe into the large ECU harness connector. Next, we remove the shroud from the small ECU harness connector by releasing two tabs and cutting the tie strap that ties the back of it to the harness.
So there's only one yellow wire from the interior S/C Activation Box to connect to the small ECU connector and one red wire from the Fuel Control Unit connector harness to connect to the small ECU connector.
But if you notice, there's another red wire from the interior S/C Activation Box that's supposed to also connect to the same red wire that came from the Fuel Control Unit connector harness.
This is the same red wire the instructions said to leave inside the car so the instructions don't match the wiring diagram.
Those of you who have done this installation, did you route the red wire from inside the car through the firewall and connect as the wiring diagram shows? If that's the case, why did the instructions say to leave the red wire inside the car and not push it through with the rest of the bundle?
Old 11-23-2008, 07:30 PM   #117
LtNoogie
LtNoogie's Avatar
Although cutting/soldering/shrink wrapping wired connections makes for more reliable joints, not everyone has all the tools to do the job right. My brother and I come from a defense industry background so we have most of the tools of the trade. This may be harder on a typical college student.
Old 11-23-2008, 09:24 PM   #118
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Ooooh, bustin out the good soldering equipment...
Is the red wire power (or ignition power)? In which case you could find one inside the car. Test it...
Old 11-23-2008, 09:30 PM   #119
mrbond
mrbond's Avatar
Woooh, Noogie, looking at all this wiring and not understanding any of it makes me understand your joke about keeping the car stock! @_@
Old 11-24-2008, 12:55 AM   #120
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Hey Noogie! Looking good! Two soldering stations?! If ever any of my crimps fail, I'm totally gonna undo everything and go this route as well.
But to answer your question, I fed the activation switch's red wire back into the engine bay and spliced into the ECU connection mentioned in the installation guide. Others found an IG+ source inside the passenger cabin to splice into (someone used the cigarette lighter as well).
Good use for the wiring loom! Different from me... I used my included loom to wrap the power wire from the battery over to the relay near the 'charger. For the 4 wires going into the cabin, I wrapped them with electrical tape near the grommet, and they're just bundled together inside the car.
Anyhow... again, nice writeup. And get ready... you'll be making boost in less than 24 hours!
2006 Red Blitzed RS 5-door
Old 11-24-2008, 01:15 AM   #121
LtNoogie
LtNoogie's Avatar
Yeah, where my brother used to work, they were never allowed to strip wires with cutters due the risk of nicking wires. All stripping had to be done by melting the insulation. The HoTweezers is that device.
The soldering iron is a standard adjustable Weller soldering station. The last thing is a heat gun.
You also see a spool of solder, solder wick, a solder sucker, and flux remover. Off camera is a jar of flux. Lastly, there's a bag of assorted sized shrink tubing.
It is tight working in that ECU connector but we learned that you can pull some extra wire length out of the harness to give more wire to work with. It was a bit slow but we wanted it to look like it does at work.
Old 11-24-2008, 01:18 AM   #122
It's attention to detail like that, that creates a solid, long-lasting project
My approach would be to twist wires together and wrap with electrical tape, that's why I don't do wiring
Old 11-24-2008, 01:24 AM   #123
LtNoogie
LtNoogie's Avatar
Thomas, do NOT do electrical work on your car!
Old 11-24-2008, 01:41 AM   #124
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Here's a question for all you Blitz owners: what did you use to cut up your engine cover? I bought a Dremel, and a few bits to cut soft things like plastic & wood. Anyhow, worked ok, but the bit gets hot and starts melting plastic and gets plastic goo everywhere, and is hard to make nice even cuts. What did other people use? Band saw? Hack saw? More patience? Let me know... I'm halfway done, and want it to come out nice!
Old 11-24-2008, 01:47 AM   #125
LtNoogie
LtNoogie's Avatar
I'm switching to a custom aluminum cover. I'm going to have it anodized blue and have some lettering etched into it.
We'll tackle that after the car's running.
Old 11-24-2008, 02:11 AM   #126
TEHxFALLEN V1.2
TEHxFALLEN V1.2's Avatar
Drives: '08 Lexus IS-F
I've been reading your thread, Long!
I love how you're doing this with your brother, with no goofing off whatsoever. Maybe you guys should be an official Blitz s/c installation center!
Sponsored by: Micro Image
http://microimageonline.com
Who has installed Megan Coilovers? Thirty-Nine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 103 03-01-2010 06:50 AM
Blitz s/c info cont'd cali yaris Forced Induction Forum 36 03-10-2009 12:33 AM
Blitz S/C on 08 Yaris whooppee777 Forced Induction Forum 12 11-26-2008 01:45 PM
Which options are dealer installed? grampi New YARIS Purchase Forum 4 07-30-2007 01:23 AM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 07:45 AM
