Old 08-16-2006, 08:28 PM   #19
jmew0ng
Drives: Scion FRS
that apex i box isn't making sense to me.. is it just a metal box so that way all connecting wires can come to one source than maybe compared to mikochu's setup (scionlife diy)?
jmew0ng is offline   Reply With Quote
Old 08-16-2006, 08:35 PM   #20
Linkseal
Drives: DBA-NCP91
Send a message via MSN to Linkseal
Ya...for cheaper way to Ground your car is DIY for sure...My Apexi Kit was taken out from my used STI...so...don't waste it...
Linkseal is offline   Reply With Quote
Old 08-17-2006, 02:15 AM   #21
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Do you think that an automotive store will also have these connectors?From all the stuff needed, I think that they are the hardest to find.
Old 08-17-2006, 04:54 AM   #22
paultyler_82
Drives: 07 Meteorite Metallic Yaris LB
Basically, yes, its just a box that all connecting wires come to so it looks a bit cleaner, and most of them have all kinds of power filters and stuff in them just like a high end home theater surge protector, but the difference between the box and a DIY is unnoticable, far as I can tell, besides, with a DIY, you can hide your wires and make it still look stock.
paultyler_82 is offline   Reply With Quote
Old 08-17-2006, 07:38 AM   #23
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Look on eBay. None of this is "hard to find."
4ga. amp wire, buy it in a 25' length.
4ga. terminal connectors.
shrink wrap for the terminals.
and a wire crimper, or vise also works..
Do you guys have a radio shack out there?
Old 08-17-2006, 12:54 PM   #24
Katana
Katana's Avatar
Oh yeah we have!So do you think that I should search there?
Old 08-17-2006, 01:26 PM   #25
Katana
Katana's Avatar
Guys from these wires, what should I choose?
http://www.radioshack.com/category/i...227&cp=2032058
EDIT:I think this works
http://www.radioshack.com/search/ind...speaker%20wire
Old 08-17-2006, 01:38 PM   #26
SimmZ
Drives: 2k3 Cavalier & 2k2 Echo
4GA is too much for nothing! Use some 8GA and it will be perfect. 4GA wire is stiff and hard to fold. 8GA wire is much more smooth and easy to install everywhere throught the engine bay components.
And please... do not pay expensive price to get some red or blue translucent wires... c'mon... go into a hardware store and buy some flat black ground wire used for welding machines. You'll pay 10¢ a feet for the black wire instead of 1.00$ a feet for translucent red/blue wire.
2003 Chevy Cavalier Ecotec - His car!
2002 Toyota Echo Sedan - Her car... FOR SALE!
SimmZ is offline   Reply With Quote
Old 08-17-2006, 01:52 PM   #27
Chris07LB
Chris07LB's Avatar
CORRECTION! 8ga. (Stinger wire) is what I used... Doh!
Old 08-17-2006, 02:20 PM   #28
jmew0ng
Drives: Scion FRS
use 4GA to pretend you have some kind of super audio equipment :D lol
I had it on my echo to hook up to amp.. it looked neat, but that was about it :|
being the dork I am, I went to buy some 8GA wires based on color >.>
Old 08-17-2006, 07:10 PM   #29
SimmZ
I even use 8GA for my 300w-RMS amplifier... so don't be affraid, it can handle a ground. I don't look on my Echo, but based on pictures above I think even the main chassis ground seem to be 8GA. Probably only the starter use 4GA.
Old 08-17-2006, 08:12 PM   #30
jmew0ng
Drives: Scion FRS
Are there benefits from choosing different grounding points compared to others?
or maybe more grounding points?
Old 08-18-2006, 01:39 AM   #31
Katana
Katana's Avatar
In order to ask these cables in Greek, how can I define the 8GA thing?Does it have to do with the number of cables inside?
Old 08-18-2006, 07:11 AM   #32
Chris07LB
Chris07LB's Avatar
Gauge, is the thickness of the wire.... It will also be written on the wire (size).
Old 08-18-2006, 08:30 AM   #33
Katana
Katana's Avatar
Οk tnx for the answer.
I'll se what I can do.
Old 08-30-2006, 05:29 PM   #34
MWill517
MWill517's Avatar
Drives: '07 Yaris Sedan Barcelona Red
Like so many here, worried about warranty issues. Would a grounding kit need to be removed before takeing your car in for service? Or with it being only grounding and passive for the most part, would it be a non-issue in the case of getting service or warrany work?
MWill517 is offline   Reply With Quote
Old 08-30-2006, 07:31 PM   #35
paultyler_82
I had a site that sold wiring in many guages with all kinds of different solid color insulation and striped insulation... I need to find that link again, prices were pretty cheap, 10-50 cents per ft. depending on quality, guage, and type of insulation.
Old 08-30-2006, 09:36 PM   #36
jmew0ng
Drives: Scion FRS
Do they provide pre crimped rings and heatshrunk-heatshrinks... because I'm having a tough time crimping mine together :\
For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. TRD_Yaris Items for Sale by private party 6 05-06-2010 06:43 PM
Radio Install Harness and Kit redbluff In Car Entertainment + Electronics (audio / video / alarm) 16 08-06-2009 02:40 AM
Trim/Dash Kit (for single DIN headunit) for Yaris yet? bigsky2 In Car Entertainment + Electronics (audio / video / alarm) 46 09-01-2006 07:30 AM
Just Finished Grounding KIt YES and YEs jbann Performance Modifications 14 08-16-2006 12:39 AM
Any front bumper/ hood stone chip issues? Where could I get Clear Bra kit? tifosi360 General Yaris / Vitz Discussion 9 08-07-2006 02:43 PM
