Old 12-02-2008, 05:44 PM   #1
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
Rim and Tire Questions
i picked up a set of 15X7 +40 wheels
what size tire should i put on there? 205/50/15?
any help would be awesome
thanks!
Old 12-02-2008, 08:38 PM   #2
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
205/50's are ideal for that rim size. You will probably rub if the car is dropped, so either get some adjustable camber bolts for the front, cut the piece of the fender liner where your wheels are rubbing, or get some stiff shocks to reduce the rubbing. You could always go gor 195's, but you wont have much sidewall to protect the lips. Good Luck!
marlondog is offline   Reply With Quote
Old 12-02-2008, 08:45 PM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
Are you lowered?
You could always check the "Official YARIS wheel & tire guide".
Old 12-02-2008, 09:22 PM   #4
kustom play
Drives: 07 liftback
i didnt know we had a wheel and tire guide
really rubbing dropped on 15's?
not dropped yet but i was planning on it
Old 12-02-2008, 09:32 PM   #5
kimona
kimona's Avatar
Well, if you don't drop, then 205/50's are too short. Go with 205/55's.
If you plan to drop, then 205/50's will work on ET40 quite well, but ET42-45 would be better to avoid possible rubbing issues.
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 06:29 AM
Has anyone weighed stock rim w/o tire 50MPGDream Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 08-16-2007 03:56 AM
Tire Pressure Max deebrown DIY / Maintenance / Service 82 08-10-2007 09:44 AM
Need serious Tire and Rim help thomasward00 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 04-14-2007 01:29 AM
Rim sizing - what size to get for OE equivalent? jay Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 11-20-2006 03:25 PM
