Old 08-17-2006, 10:35 AM   #1
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Light Bulb Specs?
I don't undestand why Toyota elected not to put the number for the bulbs in the liftback manual. Does anyone have them?
Old 08-17-2006, 10:38 AM   #2
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Tisk tisk... I am only an email away.
2007 TOYOTA Yaris (Hatchback)
High & low beam headlamp
9003 / H4
Parking light
2825
Front turn signal
7507A
Rear turn signal
7507A
Tail light
7443
Stop light
7443
Fog/Driving light
H11-55W
License plate
2825
Back up light
7440
Front sidemarker
2825
Dome light
DE3022
DE3175
Trunk/Cargo area
DE3022
Old 08-17-2006, 11:53 AM   #3
Violin
Violin's Avatar
Thanks!
How small were the hands of the engineers who designed this car? I can barely get my hand in to remove the tail light bulbs and will have to remove parts to get at the headlights.
Old 08-17-2006, 12:42 PM   #4
Chris07LB
Chris07LB's Avatar
Originally Posted by Violin
Thanks!
It is easier to just remove the tail light assy., to replace the bulbs.
Two 10mm nuts, and they pop right out.
Old 08-17-2006, 04:54 PM   #5
JustAnotherAsian
now in HD
Drives: not yaris!
Send a message via AIM to JustAnotherAsian
can you sub in 194 bulbs for those 2825 bulbs?
JustAnotherAsian is offline   Reply With Quote
Old 08-17-2006, 06:10 PM   #6
Chris07LB
Chris07LB's Avatar
If you are talking about the side markers, then NO. Liftback side markers can be removed from the fenders, but the bulbs cannot be removed from the side markers... it is a sealed assy., from Toyota.
Now if you are talking about the liscence plate light, YES.. they can be replaced.
BTW - 194 wedge bulb is the same as a 2825 bulb.
Old 03-10-2007, 05:27 PM   #7
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
Backup light looks like 7507A to me not 7440, but maybe I'm crazy. I am about to get in there again and pull it all out.
SPONSORED BY
Old 03-10-2007, 06:23 PM   #8
Chris07LB
Chris07LB's Avatar
Front turn signal
7507A
Rear turn signal
7507A
Back up light
7440
Old 03-10-2007, 07:01 PM   #9
brickhardmeat
Lonesome Cowboy
There must be different kinds of 7440 bulbs. The ones I got are a wedge base. The stock one's are the twist in kind (look just like the turns but clear)
SPONSORED BY
Old 03-10-2007, 07:02 PM   #10
brickhardmeat
Lonesome Cowboy
The stoplight is a wedge base and it is a 7443 but the reverse light is not a wedge base.
SPONSORED BY
Old 03-11-2007, 09:10 PM   #11
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
i just managed to use 1156 bulbs(clear) in the front and rear turn signals.it takes some twisting but it goes in and works......
http://www.carid.com/toyota-accessories/
site has a FEW interesting yaris items.....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 03-11-2007, 11:26 PM   #12
brickhardmeat
Lonesome Cowboy
I was wondering if those would work also I think the 1156 and 1157 and 7507 and 7506 are all very close. Not sure if they all have the single circuit base though. I think a BAU15 is also the same as the 7507. er, overload
SPONSORED BY
Old 03-12-2007, 06:53 AM   #13
sambo42xa
Drives: 07 YARIS Automatic/LiftBac/Red
Thnx. Chris07LB, I just wrote all this down and tucked it away in my manual.
sambo42xa
Southern, NH
sambo42xa
sambo42xa is offline   Reply With Quote
Old 03-12-2007, 09:18 AM   #14
Chris07LB
Chris07LB's Avatar
You guys just need to be aware of the bulb base pins... some are offset, some are straight. It doesnt take much but these little differences will decide if they fit or not.
Choose wisely before buying just anything that "looks close."
Old 03-12-2007, 01:53 PM   #15
luckydlb
Drives: 3dr Black Yaris Liftback
what about the center consol lights...that light up the heat and stuff?
luckydlb is offline   Reply With Quote
Old 03-12-2007, 04:02 PM   #16
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
doesn't look close, 1156 fits our front/rear turns.....
Old 03-12-2007, 07:19 PM   #17
sambo42xa
, what, now I got to write a new list???
sambo42xa
Southern, NH
sambo42xa
Old 03-12-2007, 07:53 PM   #18
brickhardmeat
Lonesome Cowboy
I used 7507 in the front which is the same as the rear. I know this for a fact. The reverse I am going to freakin pull right now. I swear it is the same type bulb, a 7507.
There is only one type of 7507 , the pins are offset.
SPONSORED BY
MAINT REQD light PSU Yaris DIY / Maintenance / Service 9 12-24-2008 05:48 PM
Interior Light Kit... for Canadian version?! Jem_hadar Cosmetic Modifications (Exterior/Interior) 5 08-17-2006 02:20 AM
light covers KSIbucky Cosmetic Modifications (Exterior/Interior) 7 06-07-2006 05:08 AM
