Old 07-19-2006, 01:17 PM   #37
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I have just emailed the docs to Chino....it has a lot more than just the speaker stuff too....it might not be what you are truly looking for, but hopefully it helps ya.
Old 07-19-2006, 01:45 PM   #38
ChinoCharles
Drives: LB
Just uploaded the file... it is in TIF format just so you know.
http://www.luxlightandland.com/yaris...ERFORMANCE.tif
Old 07-19-2006, 02:15 PM   #39
ChinoCharles
Drives: LB
A side note... I have Windows XP and when I went to open this file it wanted to use Adobe Photoshop to do so, but when I did it was one page and the dimensions where all whacked out. If you right click on the file and go to Open with > Windows Picture and Fax Viewer you will be able to view all 14 pages of this file. By the looks of things, I had better get nice and drunk before trying to install new rear speakers. Jesus.
Old 07-20-2006, 07:25 AM   #40
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
When I changed the speakers in my hatchback, I used the frame of the stock speakers as a mounting bracket like Alexandre2k3 did.
The front was pretty simple – I just used longer screws to attach the new speakers into the old speaker housing (after gutting it). I had to break off the edge of the plastic rim all around for the 6½” speaker to fit inside.
The rear was a little trickier. I put 5¼” speaker in but the stock speakers were a little larger – maybe 5½” or 5¾” so the new speakers slid through the opening. I just used the mounting bracket that came with the MB Quarts and glued it upside down on the stock bracket using construction adhesive. Then I attached the new speaker to the bracket using screws.
I also put Dynamat Xtreme inside the door panels and the hatchback lid and some closed cell foam over the rear wheel wells. It really cut down road noise and eliminated that cheap sounding *ting* when closing the doors.
[MB Quart RCE-216's up front and RCE-213's in the back]
Old 07-20-2006, 08:21 AM   #41
fnkngrv
fnkngrv's Avatar
Well unfortunately for some people the docs that I had to post I believe were only associated with the Sedan.
Old 07-27-2006, 08:46 AM   #42
MacMaster761
Five-Star General
Drives: 07 Silver Streak Mica
Send a message via AIM to MacMaster761
speaker sizes???
how did you open up your dash like that, just curious?
how do you mount the speakers back on after you drill out the rivets?
did you need to buy another faceplate? how much and where did you get it?
is that enough questions?
thanks
MacMaster761 is offline   Reply With Quote
Old 08-03-2006, 01:57 PM   #43
fnkngrv
fnkngrv's Avatar
Yeah...I really need to know what the max depth would be that we can accept in the doors before I order mine. I am ready as soon as I have some good solid info.
Old 08-04-2006, 03:58 AM   #44
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
Hey i come from australia.......
just wondering where did you get those black plastic speaker mounts?? i need some for my rear speakers. Though the rear speakers is smaller than the front.
can anyone tell me where to get some for the back speakers?
I have a 2006 Yaris Hatch 3 door.
Old 08-04-2006, 09:12 AM   #45
fnkngrv
fnkngrv's Avatar
Try Crutchfield.com
Old 08-04-2006, 11:04 AM   #46
seriousfun
Drives: 2007 Yaris Liftback Black
Here's that .tif as a PDF.
seriousfun is offline   Reply With Quote
Old 08-15-2006, 09:45 PM   #47
MacMaster761
Five-Star General
hey guys, are all aftermarket headunits the same size if they are single din? Will a pioneer headunit work the same way?
what is the antenna thing for?? i found a 40-vw21 on circuit city.com, will that adapter work the same?
JWU '09 Baking and Pastry
Old 08-15-2006, 11:03 PM   #48
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
Yes all aftermarket HU are the same size if they are single din (1 DIN).
Just make absolutely sure your Pioneer is not the 1 1/2 DIN size which is for GM and Chrysler models.
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 08-17-2006, 10:05 AM   #49
Jem_hadar
MORDSITH
Jem_hadar's Avatar
Drives: 2007 Yaris Hatchback
Send a message via ICQ to Jem_hadar
Originally Posted by JaiTomato
I still have plenty of room in the trunk.
*jeaouls*
Look at all that truck space! I wish our Hatchs had more truck space... in particular, I really think the amount of hatch space in the VW Rabbit is fucking PERFECT.
Or the depth (how low the floor is) of the Fit's hatch space (bc they moved the fuel tank location under the vehicle) is bloody great too.
Man do I ever wish my Hatch had space like that in the rear! Nice set up, nice box, and yes, lots of space to spar! The best of ALL words man.
Jem
EDIT:
I cant get over how gorgeous/nice/beautiful your fucking subbox is! Its wonderful! If I ever decide to put in some subs, thats what I'd want my box to look like.
Where'd you get it? Purchase? Custom?
Jem_hadar is offline   Reply With Quote
Old 08-19-2006, 10:21 AM   #50
JaiTomato
JaiTomato's Avatar
Drives: 07 sedan-flint mica, 96VFR750
Originally Posted by Jem_hadar
*jeaouls*
I got the subbox from Crutchfield years ago when I put it together for my old Focus ZX3 hatch. It was a Q-Logic Dual 10" Hatch/Trunk Box.
Wow after seeing pictures on this forum..the Yaris' liftback's trunk space is really small compared to the sedan's. Once in a while I do need the space to load lots of stuff. As I described in a previous post, there are still lots of room left beside the subbox.
JaiTomato is offline   Reply With Quote
Stereo Upgrades....what to do!? gravylegs In Car Entertainment + Electronics (audio / video / alarm) 39 02-28-2010 12:58 PM
Security upgrade Ryu General Yaris / Vitz Discussion 7 05-09-2006 09:00 PM
security upgrade? got615 General Yaris / Vitz Discussion 4 04-27-2006 09:50 AM
aftermarket stereo kit? xCookiE General Yaris / Vitz Discussion 4 02-16-2006 10:33 PM
Factory Stereo and Audio kralmrax In Car Entertainment + Electronics (audio / video / alarm) 2 01-14-2006 01:06 AM
