![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
How did you run the wideband A/F cable into the car?
I just got a wideband A/F gauge and the sensor unit needs about a 1 inch hole to feed through. The other end is a rectangular plug and needs a 1 1/4" square hole.
I figured the 1" hole would be easer. I'll be getting a bung welded to my midpipe right after the Megan header. The exterior cable with the two ends mentioned above is only about a foot long. Is there a large enough feedthrough that exists or did you guys drill new holes into the car? TIA
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
Who said Yaris was slow?
should move this to the FI section
It applies to anyone who wants to install gauges but is looking for a DYI on running wiring into the interior.
BTW. I've already used the hole in the firewall that is next to the ECU.
Is there a rubber floor plug? Sorry, I no longer own my Yaris. Also, You could buy a correctly sized rubber gromet and get a 1inch hole saw drill bit...
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
passenger side, where the floorboard meets up with the firewall there is a hole and grommet that you can use.... I seem to remember, but I am not sure, as I no longer have my yaris anymore and the wife will not let me lay a hand on hers
Thanks, Red and Black Yaris. I'll look under the car.
what did you end up doing for this?
I haven't. It took me too long to change the plugs and the intake, plus clean up the S/C cable that I did not get a chance to get to it. I can't have anything loose in the car for AutoX and having a gauge laying on the floor won't cut it. I think I'll get a chance next Saturday and will take it to the muffler shop. It should be easier to see my options when the car is up on the lift.
Start another Oil Thread!
i cut the stock o2 sensor grommet open (secondary) and slipped the wideband in with stock wiring, then glued it back shut
| big older car vs little newer car | xed | General Yaris / Vitz Discussion | 9 | 09-16-2007 05:35 AM |
| New Siphon Mag: Yaris vs. xA vs. Versa vs. Fit @ Streets of Willow | Ran Kizama | General Yaris / Vitz Discussion | 9 | 06-18-2007 01:42 AM |
| where to run amp positive cable??? | punch | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 12-21-2006 08:50 PM |
| Harman Kardon Drive + Play for IPOD | sroberts | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 07-01-2006 02:05 PM |
| Buying a first car..lol | Blenjar | Off-topic / Other Cars / Everything else Discussions | 11 | 06-14-2006 12:58 AM |
