Old 12-16-2008, 07:00 PM   #1
lh59
lh59's Avatar
Drives: 3 dr 1.3 2NZ
Storing car for 3 weeks, any special preparation?
I'm going off for a 3 weeks vacation and won't be driving my Yaris. Any special preparation for the car beside parking it in the garage and pump up the tires a bit?
lh59 is offline   Reply With Quote
Old 12-16-2008, 07:00 PM   #2
tuckevalastin
tuckevalastin's Avatar
Drives: 2008 Yaris Sedan
nope
Old 12-16-2008, 07:04 PM   #3
bigjimmysrock
Drives: 08 lb
change oil when you get back...
bigjimmysrock is offline   Reply With Quote
Old 12-16-2008, 07:04 PM   #4
wouldnt think so...
Old 12-16-2008, 08:25 PM   #5
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Battery may not like you when you get back. A trickle charger might help. Not sure how long it would take to drain the battery
Old 12-16-2008, 08:45 PM   #6
06silveryaris
Drives: 2006 yaris
make sure the lights are turned off
06silveryaris is offline   Reply With Quote
Old 12-16-2008, 08:48 PM   #7
tuckevalastin
a battery should be more than fine for 3 weeks
Old 12-16-2008, 08:48 PM   #8
MadMax
MadMax's Avatar
Three weeks? I wouldn't even bother pumping up the tires for that short amount of time...
And unless your battery is over three years old, it shouldn't be a problem either.
I park my cars for several weeks all the time due to work travel. My 10-yr-old Passat handled it fine, and I expect my Yaris would do likewise.
Cheers! M2
Old 12-16-2008, 08:54 PM   #9
i had the aveo parked for a couple months in winter (think -20c) and the battery was still fine
left the car sitting for almost 10months and everything else was fine...
i dont think parking for 3weeks youll really have to do anything at all, except lock the doors
Old 12-16-2008, 10:08 PM   #10
earljail
earljail's Avatar
Drives: 07 Yaris Hatch 5speed
If you have a fancy car alarm, it could run down your battery, so you might want to charge it when you get back.
earljail is offline   Reply With Quote
Old 12-16-2008, 11:16 PM   #11
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Disconnect the battery, it's not nessasary but it may stop a dumb thief while your away...
PetersRedYaris is offline   Reply With Quote
Old 12-16-2008, 11:29 PM   #12
Rich k
Rich k's Avatar
Drives: 07 3dr white Yaris 5spd stock
Send a message via AIM to Rich k
only one preperation, prepare for the possiblity of a little whif of that new car smell coming back again when you first open the door. Happened to me after a week of non use afer owning the car for a year and a half. Nice littls surprise.
Rich k is offline   Reply With Quote
Old 12-16-2008, 11:58 PM   #13
YAR1S
YAR1S's Avatar
prepare for the excitement when you set yours eyes on your like-new again yaris... it will miss you im sure and you... it.
:p
Old 12-17-2008, 11:25 AM   #14
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
if it's indoors: (yes I would say some of this is extreme but some people are just over cautious)
make sure all windows are rolled up and doors are shut
plug the exhaust tip with something or rubber band a rag or two over it
put the car on jack stands to avoid flat spotting the tires
remove the negative battery cable and wrap it in a rag or two and shove it down where it will not come in contact with metal
plug the intake tube or wrap rags around it
some people add fuel stabilizer it's really up to you
when you get back:
check the psi of all tires including spare
REMEMBER TO REMOVE PLUGS FROM INTAKE AND EXHAUST
run the car for about 5 minutes just idle in park to run fuel through the lines
when you first drive it again drive it w/o hard acceleration as the fuel maps will need to be relearned by ECM/PCM
Old 12-17-2008, 12:19 PM   #15
for three weeks?
I agree with disconnecting the battery, but that is all I do, and I store cars all the time for way longer than that.
Old 12-17-2008, 12:24 PM   #16
YAR1S
YAR1S's Avatar
definately make sure every opening is closed... dont want any critters taking up home.
Old 12-17-2008, 12:32 PM   #17
MadMax
MadMax's Avatar
for three weeks?
Yeah, that's way too extreme! I wouldn't do that list unless I was going to be gone for six months or a year.
Three weeks is nothing, and even a heavy alarm system shouldn't draw enough power during that time to drain the battery...
Old 12-18-2008, 01:18 AM   #18
Shroomster
Shroomster's Avatar
for three weeks?
notice I never said I did it but some people are that crazy.....
Response from Toyota on my special order drdavidr4u New YARIS Purchase Forum 14 04-27-2010 08:59 PM
Regular car wash, or Dealer car wash? Buckethead Wash, Wax, Detailing, Exterior Repairs 49 07-21-2007 12:46 PM
my car got stolen this morning leamsi New YARIS Purchase Forum 59 03-24-2007 02:50 AM
REALLY BAD CAR ACCIDENT! MacMaster761 General Yaris / Vitz Discussion 25 11-30-2006 11:20 AM
[Detail] [as to make ] Auto Laudering Sérgio Barros Wash, Wax, Detailing, Exterior Repairs 4 08-22-2006 03:56 AM
