Old 12-21-2008, 11:32 PM   #1
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
Where to go to rust proof my Yaris
dealer?
how much?
can you do it yourself?
Yawesh is offline   Reply With Quote
Old 12-22-2008, 01:39 AM   #2
adamkane
Adam
adamkane's Avatar
Drives: 2006 Yaris RS
Send a message via MSN to adamkane
Look into the electronic rust control modules.
adamkane is offline   Reply With Quote
Old 12-22-2008, 04:52 AM   #3
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Look for a dedicated rustproof service like Krownhttp://www.krown.com/#default
Or
Carwell http://www.carwell.com/
No idea where Suffolk is but i'm sure if you look in the telephone directory you'll find some kind of company that specializes in rust prevention.
These rust prevention places usually charge about $100, a Dealer is way too expensive and usually charges $4-$500 for the same job.
Doing it properly yourself is not going to work as you need a lift,special wands for application,special rust prevention fluid,air compressor,and a dedicated space thats going to become very oily very fast.
Heres where i go
http://www.antirouille.com/en/auto/
Old 12-22-2008, 07:03 AM   #4
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
Or
Heres where i go
thanks bro.
o yea i'm in nyc area
Old 12-22-2008, 09:48 AM   #5
kenkyd
kanye
Drives: 11 Corolla S
Send a message via AIM to kenkyd
whatever you do, dont go to a ziebart
kenkyd is offline   Reply With Quote
Old 12-22-2008, 10:43 AM   #6
jambo101
jambo101's Avatar
+1 ziebart sprayed on this tar like substance that eventually dried out and cracked creating more trouble than if you hadnt done anything..
The spray product should be either oil or very close in apperance to oil and should be applied on a yearly basis.A few garages use grease but its expensive.
Old 12-22-2008, 12:09 PM   #7
YarisSedan
Drives: 08 Yaris Sedan
What you could try doing is buying a few cans of black rustoleum aresol cans. And spray as much of the undercar you can get. Then after it drys purchase one of those hand pump insectiside sprayers. The kind with the long wand for reach places. Fill it witha sort of liquid white lithium grease. Something that is water resistant. You would have to use google on that one. And then spray liberally a coat under the car. All of this should only cost you 50 bucks. And then you can coat the undervehicle whenever you like. Say once every few months for pennys on the dollar what it would cost you to do it professionally.
New Yaris look? carnage08 Australia 7 10-19-2008 02:06 PM
Yaris Boosts Starter-Car Segment ketel0ne General Yaris / Vitz Discussion 0 08-04-2006 11:16 AM
