Old 08-20-2006, 07:58 AM   #1
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Rolling Fenders
Does anyone with lowered Hatbacks or Sedan have a need to roll the fenders in the front or the rear???
Old 08-20-2006, 10:24 AM   #2
riceboy
Drives: icebox
I don't think anyone has had to roll their fenders.. check out cardomain.com there's a guy on there from PR with 20's without any extra work,...
riceboy is offline   Reply With Quote
Old 08-20-2006, 03:13 PM   #3
OxyG3nE
Drives: Toyota Yaris 2007
Send a message via AIM to OxyG3nE Send a message via MSN to OxyG3nE
ill need to do this cuz my tire are rubbering ;p
OxyG3nE is offline   Reply With Quote
Old 08-20-2006, 07:08 PM   #4
SimmZ
Drives: 2k3 Cavalier & 2k2 Echo
I think rolling fender is a great thing to do for safety. Cause fender as stock are cutting like a knife. If you rub your tire hardly on it, you can blow it easily and have an accident.
2003 Chevy Cavalier Ecotec - His car!
2002 Toyota Echo Sedan - Her car... FOR SALE!
SimmZ is offline   Reply With Quote
Old 08-20-2006, 07:13 PM   #5
riceboy
Drives: icebox
well someone break out a bat.. and let's make it a DIY..
Old 08-20-2006, 07:15 PM   #6
slvryaris
slvryaris's Avatar
Are they rubbing on the metal or on the plastic??
Old 08-20-2006, 08:49 PM   #7
slvryaris
slvryaris's Avatar
Rubbing is the issue that I was debating with my 17x7 wheels at +40mm offset and 215/40 tires.
Old 08-20-2006, 09:10 PM   #8
OxyG3nE
on the plastic !! i waited a week to see the damage on the worst road i could fine and the resulat is that the metal was not touch only the plastic so im just gonna cut a part of it
Old 08-20-2006, 09:23 PM   #9
slvryaris
slvryaris's Avatar
Good idea... U can always lay something in the engine bay to make sure that none of the electronics under the hood gets wet.
Old 08-20-2006, 09:40 PM   #10
OxyG3nE
yeah i only need to remove a inch of plastic so wont do too much damage i thing.. maybe this winter its gonna be different .. (maybe ill just roll the fender and when i put my winter wheel ill clip everythinkg back.. so no snow will go in it ..
Old 08-21-2006, 01:23 PM   #11
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Old Skool fender rolling at its best!
Most shops will use a fender roller (bolts onto the rotor) for around $20 a corner... if you want to do it right, and not risk fukin up the paint!
Old 08-21-2006, 01:58 PM   #12
SimmZ
Right! It's a "must-have" for 17" with lowered suspension! A real great 80$ investment for safety and to prevent breaking your new car!!
Old 08-28-2006, 12:46 AM   #13
DollaZo
DollaZo's Avatar
Drives: Toyota Yaris YRS
has anyone put 17/215/40 on their Yaris? Im getting mine installed in 3 days time and they insure me that I will have no problems.
DollaZo is offline   Reply With Quote
Old 08-28-2006, 05:45 PM   #14
bigsky2
Cousin Vitz
bigsky2's Avatar
215-40-R17 not a good tire size.
Tire will stick out beyond the rim (as viewing from the sidewall).
Best to go with 205-40-R17.
