Old 12-22-2008, 02:24 PM   #1
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Engine Cleaning
I am going to clean the engine off and was curious on the block and on the head there is like some kind of white crap all over it kind of like pitting but its white. Does anyone have any idea what it might be and how to clean it, and the best stuff to use on the head cover.
Old 12-22-2008, 02:28 PM   #2
kou
Drives: 08 lb
simple green works great on engines and is biodigradable/non toxic.
Old 12-22-2008, 05:01 PM   #3
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
My best guess on the white is that it is just something the tires probably spashed up on the block. Do they salt the roads where you live, that's a common cause of white specks under the hood of a Jeep I have. I've cleaned my engine several times already and always use Simple Green. Always try and clean the engine when it's cold or at least not too hot-the shock of cold water on a hot block is not a good combination. I usually put a plastic grocery sack over the alternator-just don't forget to remove it.
UTVitz is offline   Reply With Quote
Old 12-22-2008, 05:19 PM   #4
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
If rinsing off any product you apply to the engine make sure its just tap pressure as high pressure wands have a nasty habit of infiltrating electrical connections.Any automotive engine cleaner will work for the metal parts and an Armoral type product will make the plastic and rubber bits look clean.
Old 12-22-2008, 05:26 PM   #5
Honestly, the engine isn't that big, so I use baby wipes. Cheaper than cleaners of the same purpose and the quanity is more. It takes about a good half hour to do the engine. Do it once every two weeks or so and it'll take about 15 minutes
Old 01-05-2009, 01:37 PM   #6
msfire671
ONE LOVE...YARiS LOVE!!!
msfire671's Avatar
Drives: Toyota Yaris
Send a message via MSN to msfire671 Send a message via Yahoo to msfire671
wow...baby wipes. i ned to try that.
msfire671 is offline   Reply With Quote
Old 01-05-2009, 11:35 PM   #7
TheSilkySmooth
TheSilkySmooth's Avatar
Prob Aluminum oxide. You always take a chance when you wash your engine. I dont show mine - and I don't wash it.
' ... smell it, smell it, SMELL IT - now TAKe it! ...'
Old 01-06-2009, 10:43 AM   #8
And they smell so fresh too
Old 01-06-2009, 01:19 PM   #9
CB900F2
Drives: 08 Sedan
I had the same white stuff from new.. it is like a powder material.. I will try this spring to spray the motor down with SimpleGreen and the wash it off..
p.s... mine is not pitting the aluminum as I can wipe it off with my finger...
CB900F2 is offline   Reply With Quote
Old 01-06-2009, 06:15 PM   #10
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
so now my ass AND my engine will be clean. NICE.......
Old 01-06-2009, 06:42 PM   #11
Cutting costs and going green in the same breath. Should be right up your ally right about now,
Old 01-07-2009, 04:24 PM   #12
ROCKLAND TOYOTA
TRIM HUNTER
your right about that. any day now!!
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 10:08 AM
DIY: Engine Grille Block BailOut DIY / Maintenance / Service 39 11-11-2017 10:33 PM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 06:34 AM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-24-2009 12:30 AM
90% on short trip. What to do to protect engine? lh59 DIY / Maintenance / Service 22 12-17-2008 10:02 AM
