Old 08-29-2006, 09:13 PM   #1
chrisada_to2a
Drives: 5 Doors Hatch
Sway bar
Just wonder if there any sway bar out for our car yet?
chrisada_to2a is offline   Reply With Quote
Old 08-29-2006, 09:20 PM   #2
riceboy
Drives: icebox
Lots of stuff is available check the vendors section..
riceboy is offline   Reply With Quote
Old 08-30-2006, 12:55 PM   #3
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
For liftback, I have seen the C-One carried by Supporting Vendor, John@BulletProof.
Old 08-30-2006, 01:11 PM   #4
BulletProofAuto
Drives: 00 itr
there is a front sway bar available from C-One, quality is excellent from this company. I would expect sooner or later(likely later) for cusco to come out with some as well.
http://www.bulletproofautomotive.com...il.php?ID=5231
BulletProofAuto is offline   Reply With Quote
Old 08-30-2006, 08:02 PM   #5
chrisada_to2a
Cusco actually released a sway bar for a liftback already, at least they already got them in stock where i live (Bangkok, Thailand). I heard they are couple of 5 doors that already install it. I will most likely got one within a week or so. Thanks for the reply guys :D
Old 08-30-2006, 08:18 PM   #6
BulletProofAuto
Drives: 00 itr
i'm sure they have but cusco usa doesn't release it until they have test fitted it.
Old 08-31-2006, 07:32 PM   #7
AE86Yaris
Drives: 85 AE86/blazing blue 07
my yaris neede a rear sway bar yesterday and i didn't even own it then ;)
any idea if the Progress rear sway for the scion xa and xb will fit ?
AE86Yaris is offline   Reply With Quote
Old 08-31-2006, 10:50 PM   #8
johnnyfive
johnnyfive's Avatar
with a rear torsion beam suspension, are you really going to see much gain by adding a rear sway bar?
johnnyfive is offline   Reply With Quote
Old 09-01-2006, 07:53 AM   #9
Chris07LB
Chris07LB's Avatar
Be better off with a rear strut bar, or lower bumper bar.
Both offered by C-One, and pic's and prices on BulletProof's site above ^.
Old 09-01-2006, 05:28 PM   #10
AE86Yaris
strut braces mearly increase chassis rigidty
sway bars increase wheel rate on the inside tire in a turn thus helping rotation
i'd rather have the rotation than rigidity
Old 09-03-2006, 01:21 PM   #11
Chris07LB
Chris07LB's Avatar
Like already mentioned, good luck feeling much of a difference with the way our rear set up is.
Old 09-04-2006, 09:47 AM   #12
03Z33
03Z33's Avatar
Drives: TCR10
One of the best upgrades you can make to a VW Golf/Jetta is adding a rear trailing arm "sway bar" or "torsion bar". These are not your typical sway bar but are actually welded or bolted into the torsion beam to stiffen it up.
From looking at the Yaris beam, this can be easily made to fit, and I'll be looking into it soon. I also realize that it's important to keep some of the "flex" in the beam since it does help with steering and direction, but with the soft rubber bushes in the leading arm joints and the angle they meet up at, I'm sure a little stiffening can only help!
I'll see if I can find some pictures of the bar installed on VW's for reference.
Old 09-05-2006, 12:03 AM   #13
heylookitsjames
maintenance of momentum
Drives: 2007 5spd 3dr
some of those MkII bars are pretty trick... some have sliding mount heim joints to minimize binding. It would be awesome to see some of that technology make it over to japanese cars... There is a company called Shine that makes a sway bar for the VW rear trailing arms that mounts above the arm and does not reduce ground clearance at all.
heylookitsjames is offline   Reply With Quote
Old 09-05-2006, 07:34 PM   #14
AE86Yaris
right on nice to see someone doing something to make these things actually handle better
i've been trying to see if i can adapt a scion xA/xB rear sway bar since they hare basically the same supesnion setup, but first i got to find someone to let me look at there undercarriage
For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. TRD_Yaris Items for Sale by private party 6 05-06-2010 06:43 PM
c one motorsport performance bars badhabitz Performance Modifications 17 08-23-2006 10:31 PM
