Old 01-12-2009, 09:16 PM   #55
Dyno'd on MUSKOKAs sedan. Printed copy of chart won't scan in worth shit, but will have electronic version sent to me later.
In a nut shell:
- base line stock 97.15 whp/101.77 ft-lbs torque
- with intake 101.12 whp/104.07 ft-lbs torque
Graph shows nice even gains throughout the power curve.
not bad....4whp and 2.5tq....
Old 01-12-2009, 11:29 PM   #56
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
Where do I need to send my arm and leg
Ever blown out an R-200 diff god know's I have
ztrack157 is offline   Reply With Quote
Old 01-13-2009, 06:05 AM   #57
lol, matrix guys saw you there last night too, eh?
Old 01-13-2009, 07:27 AM   #58
MUSKOKA800
MUSKOKA800's Avatar
Yes, a couple Matrix were tested prior to my Yaris.
Regarding the Yaris results;
If my baseline HP seems a bit higher than others results keep in mind that I had the TRD Axle-back in place. Otherwise no power-adders in place.
Also the OEM air filter element was put back in for the base-line test. I normally run with a K&N drop-in.
Old 01-13-2009, 10:20 AM   #59
Tamago
Tamago's Avatar
Drives: UZJ100
In a nut shell:
that sounds like a seriously mis-calibrated dyno..
97whp on a STOCK AUTOMATIC 1nzfe that is rated at 106 AT THE CRANK??????? sorry, i call B.S.
edit: read that you had a muffler.. still isn't gonna make up for the 10 or so extra HP you show..
Old 01-13-2009, 10:31 AM   #60
Thej3sta2
Thej3sta2's Avatar
Drives: Soon to be LFA
/\ /\ /\ mmm so angry
Thej3sta2 is offline   Reply With Quote
Old 01-13-2009, 10:40 AM   #61
Tamago
Tamago's Avatar
Drives: UZJ100
nah, it's just a mis-calibrated dyno.. either way, good numbers from the intake.. even if they aren't accurate
Old 01-13-2009, 11:29 AM   #62
First off, I can't speak to the calibration of the dyno, but regardless the difference between the two runs is where the meat lies.
Second, my HB is the automatic and served as the subject car for development. The sedan on the dyno last night is a 5 spd.
Old 01-13-2009, 02:32 PM   #63
MUSKOKA800
MUSKOKA800's Avatar
FYI, it's a 5 speed, not automatic. And interesting because one of the Matrix guys was pissed, claiming his tested much higher on another dyno so???
In any case it's a know fact that no two dyno's will read the same. Different machine, different temps, different air, different operator...
The purpose of these tests were to compare baseline hp and that generated with the Jet Stream Intake installed. The pulls were accomplished within minutes of each other with only the time to switch the intakes between tests.
Old 01-13-2009, 08:43 PM   #64
ya, i saw the dyno for that xrs...was woefully low
yours makes some sense for a trd axle back and 5spd...5whp over stock doesnt seem too out of the range of plausibility for the yaris...
were you guys open to the outdoors? were the dyno's SAE corrected? how cold was it? likely about -10C and low humidity?
not bad gains though muskoka
Old 01-14-2009, 07:27 AM   #65
MUSKOKA800
MUSKOKA800's Avatar
The shop doors were openned regularily to move vehicles about. Outside was likely about -3C that day. Humidity???. Inside the shop was around 17-18C. Can't comment on whether the dyno was SAE corrected. I was just there as a donor 5 speed car to test the intake. And for the experience.
Old 01-14-2009, 08:58 AM   #66
just sayin that if the dyno wasnt SAE corrected, itll run a few hp higher....but given the matrix guys were runnin low....but in 4th gear doesnt make sense to me
anyways, the key is in the difference over stock anyhow....so the PRM like most other intakes at a few hp and tq at the wheels over stock.....
sidebar: typically, the matrix guys use forrest and forrest racing in kitchener as their gospel. i dynoed my xrs in london one time and ran about 180whp while comparing 03 and 04 xrs ecu's. that was about 10whp higher than i ran at forrest and forrest. matrix guys wouldnt except 100whp/L, lol. so at any rate, i took it for what my test was originally for: and that was to compare power curves of 03 and 04 xrs ecu's....
Old 01-14-2009, 06:25 PM   #67
+1
Whether or not we are getting a 'true' whp reading for the Yaris here is not the point. This was a test to measure, back to back, the difference between two setups.
Old 01-14-2009, 06:27 PM   #68
have dyno sheet yet?
Old 01-14-2009, 07:30 PM   #69
Best I currently have is a crap scan. Had to play with colour hue to make both run lines visible.
Edit - 2008/01/18 new copy of graph received and is now shown.
Last edited by WeeYari; 01-18-2009 at 05:11 PM. Reason: new copy of graph received.
Old 01-14-2009, 07:31 PM   #70
neato.
Old 01-14-2009, 07:57 PM   #71
Don't know how the xrs that was there felt about his numbers. Was interesting to see his results from 3 setups tho. I think these are the right numbers.
Stock 146.43 whp
AEM SRI 149.34 whp
AEM pipe + PRM filter 153.30 whp
Old 01-14-2009, 08:00 PM   #72
Stock 146.43 whp
AEM SRI 149.34 whp
ya, thats low for an 03 xrs....usually dyno 157-ish stock....
here's mine from london
looking for toronto car for prototype CAI jetstreamer Canada 24 02-21-2009 02:02 PM
Which CAI and Exhaust should I purchase? bakedwookie Performance Modifications 17 08-05-2007 02:00 PM
TRD CAI & TRD Qiuck Shift Polar Items for Sale by private party 7 08-02-2007 06:03 PM
SRI vs CAI sklau Performance Modifications 5 07-04-2007 01:24 AM
CAI Question? falkor_99 General Yaris / Vitz Discussion 5 04-23-2007 03:59 PM
