Old 03-01-2007, 08:28 PM   #73
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
http://www.yarisworld.com/forums/sho...58&postcount=1
Old 03-01-2007, 11:34 PM   #74
evilreign
Drives: Yaris
Damn those side markers look good. Nice and bright too, I likes..
evilreign is offline   Reply With Quote
Old 03-02-2007, 10:01 AM   #75
gravylegs
Drives: 2007 Yaris Liftback RS
Thanks Chris! This is now on the list of things to do!
gravylegs is offline   Reply With Quote
Old 07-22-2007, 02:52 PM   #76
reggaetonfreak
El Yoe
reggaetonfreak's Avatar
Drives: Yaris Hatchback
thank you so much for this, i have a white lb too, lol
Cuban to the bone, sitting in a Yaris, ahi si hay!!...
reggaetonfreak is offline   Reply With Quote
Old 07-22-2007, 07:49 PM   #77
Jerkratt
Jerkratt's Avatar
i have spiderlite... tail light led's i have the 3 arm x2's wedge brake ones that fit the stock socket and im using the 5 arm x2 with my aftermarket tails diff socket. been trying to get rid of my 3 arms... cant use them anymore
"It hurts more when its wet"
Old 07-22-2007, 08:19 PM   #78
Chris07LB
Chris07LB's Avatar
Originally Posted by Chris07LB View Post
bump 4 noobies
Old 01-17-2009, 01:41 AM   #79
Wirenut07
Slave To The Groove
Drives: 07 S
Repeater Lamps
Has anyone installed them on a sadan?
Wirenut07 is offline   Reply With Quote
Old 01-17-2009, 02:10 AM   #80
alright, another bump for the updated thread, since I sell these since those old days (smoked or clear):
Old 01-17-2009, 10:37 AM   #81
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Garm are these plug and play???
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 01-17-2009, 02:32 PM   #82
bikegerm
bikegerm's Avatar
Drives: 2007 Meteor LB
Side marker LED lights
I installed these and love 'em. Here's a few pics. The connector on the right is the connector on your smoked leds'. It needs to plug into the connector on the left which is from the wiring harness inside the fender well. You'll have to slightly modify your connector on the smoked led lights. I used a dremmel tool to cut away the shroud exposing the pins. and they plugged right in to the wiring harness connector. I used some electrical tape to hold them together. Remember there is polarity here.
Randy LeRoy
www.airshowmastering.com
randy@airshowmastering.com
bikegerm is offline   Reply With Quote
Old 01-17-2009, 04:57 PM   #83
I just stripped the two wires, removed both harnesses, and taped it all together -- still working fine after a few months, only took 10 minutes per side.
Old 01-17-2009, 05:18 PM   #84
kimona
kimona's Avatar
Drives: 2014 White VITZ
I'm still waiting for someone to install some BMW sidemarkers... a popular mod in Japan.
Old 01-17-2009, 05:29 PM   #85
that would be cool. I can also get Silvia side markers, which would rock!
Old 01-17-2009, 05:45 PM   #86
kimona
kimona's Avatar
Yup, the Sylvia side markers would be very cool!
Old 01-17-2009, 11:43 PM   #87
Jerkratt
Jerkratt's Avatar
can u get a part number on those side markers... thers a BMW dealer right around the corner from my pizza delivery job in maywood... MIGHT be able to get a discount on them
Old 01-19-2009, 10:21 PM   #88
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Jerkratt, you should be the tester for those BMW side markers. It'd be perfect w/ your black setup ^_^. I'm waiting for those too.
Old 01-19-2009, 11:40 PM   #89
Jerkratt
Jerkratt's Avatar
i printed out the picture of the markers... ima go there tomorrow cause its my day off and check it out
Old 01-20-2009, 03:46 AM   #90
Chris07LB
Chris07LB's Avatar
I have a set here.. tried it years ago, and unless you flip them, and can cover some of the hole left behind in our stock fenders, "she no workie!"
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 07:17 PM
Smoke your own tail lights ChinoCharles Cosmetic Modifications (Exterior/Interior) 9 01-16-2007 12:00 AM
xb side marker swap? funkstrong Cosmetic Modifications (Exterior/Interior) 4 10-25-2006 12:32 PM
Fog Lights - only right hand side JayCee Cosmetic Modifications (Exterior/Interior) 3 09-26-2006 06:44 PM
Side Turn Signal Lights bigsky2 Cosmetic Modifications (Exterior/Interior) 15 08-24-2006 07:06 PM
