"Stealth Runner"
What kind of break in mpg did you get?
Im curious to see what you guys are getting
First fill up i got 32 mpg and 2nd fill up was getting 33 mpg you guys get about the same? |
What the Pho?
Drives: '08 Meteorite Metallic MT LB Join Date: Oct 2008
I bought mine last October and my first tank i got 36.5 mpg the second tank 40 mpg.
So far this winter i have been averaging 36 to 37 mpg but most of my commute is highway. |
![]() ![]() ![]() Drives: 2008 Blazing Blue 3dr LB MT Join Date: Nov 2008
The dealer filled up the first tank when i purchased mine and saw 37mpg. The second tank which I filled to one click netted 39. Now I get between 41 and 43 mpg but I drive slower (65mph average) and 80 percent on the Hwy.
Sometimes you have to spit on your hands, raise the black flag, and start slashing throats |
That is exactly what I got. 32-33, and it has pretty much stayed consistent since. Went up a touch.
![]() ![]() ![]() Drives: 2008 Yaris 3-door Meteorite Join Date: Oct 2008
Averaging 32-36 here, and I'd bet that's the norm; those here claiming to get up to 50 mpg must be yanking our chains, LOL. If these cars regularly got 40 mpg (or more), the stickers on the windows would be touting that claim. Kind of disappointing, since my old car got 40, but the Yaris is so darned cute!
'09 5dr
Drives: 2009 Yaris 5-Door Bayou Blue Join Date: Oct 2008
I bought mine in October 2008. I'm getting 35-37 so far.
2009 5-Door Yaris LB Bayou Blue Pearl 2009 5-Door Yaris LB Black Sand Pearl |
what does the sticker say? 29 city and 36 highway?
Audio Junky
my first 3 tanks were all around 36... once I started using DFCO.. it jumped to 40. Slowly over the next 4 months it went as high as 44. Most of the change is due to driving habits.. there might have been as much as 3mpg due to break in & synthetic oil... the rest is due to warm climate & driving habits.
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
1st tank filled by dealer(s) for both '08 automatic sedan and '08 5speed manual L.B. averaged litte over 43 . Drove those very conservatively for the break in period of 500 miles . Drove different speeds and tried to keep under 3 r.p.m.s as much as possible . Don't think we've duplicated that yet , close but no cigar . That was with the conventional factory oil . Use syn for both now . Sometimes ponder if they would get better mileage by going back to regular oil .
. Just stick with the syn. Lot of short trips . Less traveling with winter weather .
![]() ![]() Drives: 2008 Yaris LB 5 speed Join Date: Oct 2008
![]() ![]() ![]() ![]() Drives: Yaris 5 door liftback Join Date: Jan 2009
with AT
31 mpg first tank 32 mpg second tank 34 mpg third tank Last edited by Yar Is Word; 02-24-2009 at 01:12 AM. |
![]() ![]() Drives: 2008 Yaris LB 5M Join Date: Oct 2008
Drove mine home from the dealer the evening of August 1, 08. I threw the first tank out because the dealer filled it; it was 38.18 mpg for 336 miles. The 4 tanks after that averaged 42.1 mpg (41.22 – 42.74). Mileage jumped a little and the next 14 fill-ups averaged 44.6 mpg (42.92 – 45.63). I also go the ScanGauge at this time so that might account for the jump. I fill-up once a week and average 330 miles/week. The last tank, with just over 6,500 miles on the odometer, might have made another jump. Out of nowhere I seem to be getting better MPG numbers, set 3 straight days of record high mpg on my 30 mile commute. I did not change anything about my driving to warrant it and the weather was not much different than the previous weeks. Last tank was 315 miles and calculated to 46.91 mpg. I was thinking maybe I filled up inconsistently (less gas due to pump shutting off earlier or something) but this week I am still getting higher than usual commute mpg numbers. Current tank as of this morning the SG2 reports 46.7 mpg average. It has been very accurate about mileage (distance driven), tank mpg, and gas used after the first few fill-ups were used to calibrate it.
Now, I’m working for these mpg numbers not just driving. No engine off coasting or pulse and glide techniques… yet. Just driving with a really light pedal, using momentum for the hills, 42 psi in the tires and using the brake pedal as little as possible. I do have two sections where I can take it out of gear and coast for about ¾ of a mile but that’s about it. Most of my driving is in traffic so I do have to go at least the speed limit. I can see where people are getting over 50 mpg with flat terrain driving, taking it easy on the skinny pedal and using advanced hypermiling techniques. They are working for it but it is possible even with the 1.5 gasser we have as our only engine option. The EPA estimates don’t reflect the high mpg figures some drivers are getting because they drive a little differently than ‘regular’ folks. I operate my motor vehicle with safely getting the highest possible mpg as my priority. I don’t drive with getting there as fast as possible as a priority. My commute takes me 5 minutes more each way, 10 minutes a day or about an hour a week. Time well spent as I am more relaxed and much more aware of vehicles around me on the roads. |
![]() ![]() Drives: 2009 Yaris 3 door M/T Join Date: Jan 2009
I'm currently on my 5th tank of gas and so far have been getting 37-38mpg per tank consistently, regardless of driving conditions.
#14 |
![]() Drives: 2009 3dr Red 5spd Join Date: Jan 2009
I got mine last week and got 38.94 mpg on the first tank. Should do better once I remember to take it out of 4th gear. Coming from a Scion XA forth gear feels like my old 5th gear. I do mostly highway to and from work.
#15 |
#16 |
'09 5dr
I have a feeling drt1120 is talking about putting on 5th gear instead of 4th of 5-speed manual and otterhere is talking about putting on D isntead of 3 of 4-speed auto.
#17 |
Second tank 40.9 but still forget to take it out of 4th. After going 105k miles in my XA it is going to be a hard habit to break.
#18 |
"Stealth Runner"
how many of you guys are doing city or highway?
i do mostly city and traffic i realized and im still netting around 32mpg with 1700 on the odometer |
| My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 07:31 PM |
| Help me see 55 mpg! | Loren | Fuel Economy Forum | 76 | 04-02-2009 05:23 PM |
| Anyone from Missouri? MPG problems inside | 4MPG | Fuel Economy Forum | 31 | 12-17-2008 06:48 PM |
| Toyota Yaris achieves over 84 mpg in MPG Marathon | tk-421 | Off-topic / Other Cars / Everything else Discussions | 5 | 11-17-2008 08:41 PM |
| Toyota Yaris MPG Review at www.mpgomatic.com | aca72 | Fuel Economy Forum | 23 | 10-31-2008 04:59 PM |
