Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
How to fix a flat.
Common method for baloon tires..... starter fluid and a lighter ....... method has been used for years
some people are little slinkies. . . . .they are really good for nothing. . . .but they still bring a smile to your face when you push them down a flight of stairs. Come to the DARKSIDE..... We have candy ![]() ![]() |
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
My borther-in-law does that with the tires on his semi.
Making a decision without following it with an action is still a fantasy. |
That method scares me. A while back, I ran into a write-up on using a ratcheting nylon strap to squeeze the tire enough to seat the bead - It works like perfectly and you get to keep your eyebrows.
Are you serious? This is too gangster.
DON'T LIKE ME? TAKE A SEAT WITH THE REST OF THE BITCHES WHO ARE WAITING FOR ME TO GIVE A FUCK. Sponsored by: Micro Image http://microimageonline.com |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
The video's been removed, but I am sure it is the same method I've seen used numerous times on the trail with Jeeps. Sure, it's not the safest thing to do; but you do whatever it takes to get you home!
Cheers! M2 |
Beast
what happened in the video?
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
what is it physics or chemistry?
pour some HIGHLY flammable liquid into a tire throw a match it will 'explode' pulling all available oxygen for burning into the tire thusly causing a vacuum effect all this happening in milliseconds and causing the tire to seat itself from the force.... |
Just hit the play button. It says that the video has been removed, but when you hit play it does...
| DIY- rattle from lower windshield fix. | PetersRedYaris | DIY / Maintenance / Service | 3 | 08-21-2011 12:29 AM |
| Probably a dumb question - Flat spots | 33OH | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 12-22-2008 01:41 PM |
| Flat Key | MadMax | General Yaris / Vitz Discussion | 24 | 11-07-2008 06:40 PM |
| question about lb fold flat seats | roxy84 | General Yaris / Vitz Discussion | 7 | 05-29-2007 01:07 PM |
| Flat Black Steelies With Red Pinstripe? | blacksan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 05-21-2007 05:25 PM |
