Old 01-28-2009, 08:51 PM   #19
kimona
kimona's Avatar
Drives: 2014 White VITZ
Originally Posted by firemachine69 View Post
I can't see 215-45-17 fitting... That's way-oversized for the Yaris!
OEM 17" tyres: 205/45/17 = 24.3"
215/45/17 = 24.6" (At just 1.6% taller than OEM fitment, this is well within the recommended 3% tolerance).
Old 01-28-2009, 08:56 PM   #20
Marfulion
Drives: 2008 Yaris Sedan
what are these OEM 17" tires u ppl talking about??
Marfulion is offline   Reply With Quote
Old 01-28-2009, 09:28 PM   #21
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
I'd go by what the base has, as I sincerely doubt they change the ECU when you upgrade to the larger rim package. They're likely using an over-inflated size to begin with...
Old 01-28-2009, 11:47 PM   #22
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
OEM offset is +51. OEM tyre size is 195/50/16.
With 205/50/16 rubber, you can generally run +42 safely with no up-front poke and no rubbing.
With 195/50/16, you're generally safe with +38.
To answer Tamago's question: Yes, a couple of mm's makes a significant difference on these cars.
You are correct, but all of which you have posted is really dependant on the wheel width, which you have not listed.
Also, OEM 16's don't exist, 15's or 17's only. What is the width of the +51 offset OEM wheel? I'm guessing 5.5 or 6 inches for the 15's and 6.5 for the 17's???
Old 01-28-2009, 11:47 PM   #23
PetersRedYaris
European Yaris TS factory wheels...
Old 01-29-2009, 07:44 AM   #24
kimona
kimona's Avatar
These are the OEM wheel sizes, offsets, and tyre sizes:
14x5, ET45, 175/65/14
15x5.5, ET45, 185/60/15
16x6, ET51, 195/50/16
17x6.5, ET51, 205/45/17
TRD Option 18x7.5, ET42, 215/35/18
Old 01-29-2009, 12:01 PM   #25
yxmach
Drives: yaris sedan
Is 17X7, +42, 205/45 will give any problems with stock suspension?
yxmach is offline   Reply With Quote
Old 01-29-2009, 12:19 PM   #26
kimona
kimona's Avatar
Very good fitment with little to no chance of rubbing on stock suspension.
Old 01-29-2009, 12:40 PM   #27
bxrich
bx in the house
Drives: toyota yaris sedan
what about 17x7.5 4x100 42 offset on 215/40-17 is this a good size on stock struts & trd springs
bxrich is offline   Reply With Quote
Old 01-29-2009, 12:52 PM   #28
yxmach
Drives: yaris sedan
Thanks kimona....
Old 01-29-2009, 02:05 PM   #29
yxmach
Drives: yaris sedan
If i lower the ride via NF210, will it rub?
Old 01-30-2009, 04:28 PM   #30
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
Well Bought rims Evoke GT17" off Ebay. for tires got Sunny SN3800 215/45/ZR17
Just Got to wait till wheels get here to take to the tire shop to put the rubber on :D
In All
Wheels Shipped $399
Tires - $290.83
$689.83
Not Bad I Think :D
Arkhangel is offline   Reply With Quote
Old 01-31-2009, 04:19 AM   #31
andries
aka Jack Wolfskin
Drives: Yaris
Send a message via MSN to andries
I have stock offset 51 with 205/45/17. (rims 6.5 x 17") That gives NO rubbing
andries is offline   Reply With Quote
Old 05-02-2009, 03:08 AM   #32
Nudger
Drives: NCP91R
So what about 205/40/17 at 7", +43 offset. on stock... Then lowered on Vogland springs at 35mm?
Any thoughts
Nudger is offline   Reply With Quote
Old 05-02-2009, 11:09 AM   #33
gmodder
Riceman43
Drives: 2009 Yaris 3door
In All
Wheels Shipped $399
Tires - $290.83
$689.83
Not Bad I Think :D
Nice wheels except for the multi holes...But i really dont like wheels that you can see the lug nuts anyway...
gmodder is offline   Reply With Quote
Old 05-02-2009, 01:29 PM   #34
RHDVIPbB
Right beside you, wave
Drives: 08 PBM Yaris Sedan
Have a set of Enkei PK6 rims from a friends xB. I was using them to test fit on my sedan. He has 215/45/17 tires and they didn't rub on my Yaris. The rims are 40 offset. Didn't get to drive too far, but I didn't hear any rubbing and even checked my inner fender liner and saw no damage.
Old 05-02-2009, 10:32 PM   #35
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
I have the same size tires and I rub lowered on Tanabe df210s.
Old 05-05-2009, 01:06 PM   #36
ad23
Drives: Toyota Vios
I am on 215/40/17 and it will not rub ... not sure about 45 though ...
ad23 is offline   Reply With Quote
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 01:30 PM
