![]() Drives: 07 yaris Join Date: Jul 2006
Component Owners...Crossover Placement?
For those of you that installed 6 1/2 components up front, where did you stick the crossovers? The obvious place I thought was *in* the door or under the dash, but I was just wondering what others did with 'em?
under the rear seat.
mines are quite big, about the size of a Dlink DIR-615 router.
I mounted my crossovers on the doors. Why spend that much money on something you hide? BLING BLING BIOTCH!
Audio Junky
could go under the seats, under the dash, in the doors. I personally like a hidden spot that is easily accessible in case you ever have to mess with it.
Keep crossovers away from the center console tho.... have heard bad things about transmissions inducing wierd noises into inductors (the big coils). |
Mine are actually in the doors on the armrest. There is a shelf like thing there that they ride on easily without screwing them down. The door panel actually holds them in place once its re-installed.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
I put mine in there too, but just to make sure, used strip of weather-proof 3M double sided tape on each crossover.
The Hated One
Drives: 07 White Manual Sedan Join Date: Sep 2006
in the doors. the infinity crossovers i have are not adjustable, they are fixed, so i didnt see the need to put them in a easily accessable place like under the dash. they do have a db boost for the tweeters, but i have yet to find a amp or deck that wasnt overly bright with the db boost on the tweets.
so, mounted to the inside of the door!
Indeed, infinity crossovers are pretty small :)
when i still had a hatch.. |
| i have a q to US owners | FlyingDevil | New YARIS Purchase Forum | 33 | 03-26-2009 09:20 PM |
| Where are all the Alberta owners ? | Dbeau | Canada | 18 | 02-20-2009 01:07 AM |
| Doctors Vs Gun Owners | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 0 | 01-29-2009 07:36 AM |
| READ YOUR OWNERS MANUAL!! | MadMax | General Yaris / Vitz Discussion | 29 | 12-14-2008 10:38 PM |
| Component or coaxial speakers? | eflb55 | In Car Entertainment + Electronics (audio / video / alarm) | 12 | 12-11-2006 09:40 PM |
