Old 09-15-2006, 10:05 AM   #19
pauljk
Drives: Yaris LB automatic
For what it's worth, I've had a Rostra on my auto liftback since the beginning of August, and have had no problem with it. It's been a great addition.
pauljk is offline   Reply With Quote
Old 09-15-2006, 10:23 AM   #20
ketel0ne
ketel0ne's Avatar
Drives: 2007 Liftback Blazing Blue
Did you install it or did you have it done?
ketel0ne is offline   Reply With Quote
Old 09-16-2006, 10:26 PM   #21
AlexK
Drives: 2007 Yaris Sedan 5MT
Well I have emailed and called Rostra (left a detailed message) with no response from them for two weeks. Their customer service is definitely lacking.
One time my RPMs did stick at 3000 while coasting in neutral without the CC connected. I will reconnect it and try again. At least it's very easy to connect, no splicing required just a connector.
AlexK is offline   Reply With Quote
Old 11-03-2006, 10:43 PM   #22
OK Yaris
Well, I installed my cruise tonight. Easy install and it works great. Everyone who owns one of these cruise controls should probably become familiar with how the connectors plug in above the gas pedal. Looking at the diagram, I can see how a malfunctioning cruise control unit could leave you on the side of the road, with no pedal control. Even folks who had there units dealer installed may want to check it out, just so you know how to bypass it if you suspect the cruise box has gone bad.
I give this mod a
OK Yaris is offline   Reply With Quote
Old 11-04-2006, 08:35 PM   #23
YamilR
YamilR's Avatar
I love mine...no problems whatsoever
Old 11-19-2006, 05:56 AM   #24
spkrman
Drives: 1
if this pans out as just one defective unit here... or car issue... It'll be one of my next mods!
Old 11-19-2006, 10:44 AM   #25
Toyotech
Your Toyota Technician
Drives: 06 Cobalt SS/SC, 06 Rolla S
Send a message via AIM to Toyotech
sounds like it could be a bad install, i am yet to come across a bad cc unit that we've installed... especially on a DBW vehicle..
Toyotech is offline   Reply With Quote
Old 11-20-2006, 05:49 AM   #26
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
sounds like a bad conection there you plug it in to the tps to me . I have been thinking about getting one myself that's really the only thing my car needs that it doesn't have
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
Old 12-02-2006, 10:37 PM   #27
gonzo452001
Installed mine this morning works great so far i thought the wire taps were hard to get on there should be special pliers to hold them so you can get them into tight places couldn't squeeze hard enough to get them on by hand it was 25F out there this morning sure that didn't help any.
oem style foglights
Scan GaugeII
Old 12-24-2006, 10:39 PM   #28
TC-LIFTBACK
Just got mine installed. Ordered it from the distrubutor # on the rosta website. Got it shipped for $190, they said they gave me a discount because I'm in Minnesota.
Some suggestions on the Manual install...
1. You have to remove the steering column to screw the nut onto the cruise control stalk.
2. Make sure that you correctly reconnect those wierd black lever things on the junction box if you remove them to easily get the connections done the T-Taps.
3. I used a 12mm bolt on the steering stalk as a ground (I also used this as a ground on my heated seat install with no problems before (DIY to come soon)
4. I'd print off the instructions in color. It'll be alot easier.
5. I'm not sure what the Yellow wire was supposed to connected to on the Manual transmission one but if anybody know's, please post it in this posting.
6. You should get lots of light in there to be able to work properly.
The cruise works very well and I'm pumped to use it on long car trips. Werd.
TC-LIFTBACK is offline   Reply With Quote
Old 12-25-2006, 08:49 AM   #29
gonzo452001
the yellow wire is for the tach. I also printed out the color instructions
oem style foglights
Scan GaugeII
Old 12-26-2006, 07:37 AM   #30
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
I got a kit for Christmas. Can't wait to install it!
Old 12-28-2006, 10:06 PM   #31
gonzo452001
Dim light on all the time
I noticed this morning with my cruise control off there was a very dim light on the LED maybe it has always done this and I just noticed Has anybody else noticed this .Its a rostra I put in my self.
oem style foglights
Scan GaugeII
Old 12-29-2006, 02:56 PM   #32
spkrman
Drives: 1
Originally Posted by TC-LIFTBACK View Post
I dropped Rostra an email regarding a group buy on this baby. Looks like the ebay price has gone down to $230-235 shiped for MT/AT.
Let's hope this works out.
Let's get a group buy on this puppy!
-Ben
now, this is something that I would like to get into :)
Old 05-12-2007, 10:34 PM   #33
Snappy
Drives: 2 Yaris Hatchbacks
Yellow Wire
My self install went great except for the yellow tach wire. The instructions were a little unclear, what you are tapping is the backside of the OBD (scanner) port, and the instruction illustration shows the wire you tap is in the upper right of the port. That is true, but it is as viewed from the plug-in face of the gauge (as seen lying on your back with your head on the floormat!) If you are sitting in the driver's seat, looking in the space where the small item box is, the wire you tap is at the upper LEFT of the port. My first test drive resulted in great cruise control, except when I pushed the clutch pedal in, the engine revved up to redline! (At least it was easy to fix, just pop out the small item storage box and re-tap.) With the right wire, pushing in the clutch during cruise results in a real brief rev then the engine speed drops down quick. One tip: to take the panel under the steering column out, unsnap it starting at the top, fold it down, and a hinged bottom piece has two hidden screws that need to be removed. The bottom of the junction box that the main cruise module tapes to is also the main inside fuse box, so I tried to keep the wires off to the side to allow easy fuse box access. I paid 230 for the cruise from the distributor mentioned on the first page of this thread. So far, I like it a lot. You have to turn it on every time you start the car, I guess.
Snappy is offline   Reply With Quote
Old 05-13-2007, 07:22 AM   #34
gonzo452001
I was confussed about that also I looked at somebodys post about installing a tach
oem style foglights
Scan GaugeII
Old 09-18-2007, 03:21 PM   #35
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
diy needed
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
Liftback - Easiest Way to Get a Tach and Cruise Control... weeze-dog General Yaris / Vitz Discussion 60 10-20-2006 05:40 PM
price for sub/amp install PSU Yaris In Car Entertainment + Electronics (audio / video / alarm) 14 08-09-2006 12:39 PM
