Old 03-23-2006, 08:40 AM   #1
DJ_SpaRky
Resident Scion Guy
DJ_SpaRky's Avatar
Drives: 2008 Mazda3 S Sport
ECU for the 1NZ-FE in the Yaris
I know that the ECU for the Scion variant is a 64-bit "learning" unit & the Echo variant is a 16-bit non-"learning" unit, my question is which will the USDM Yaris (LB mainly) have?
the reason that I ask is I know that the 64-bit one sucks for FI or NA tuning, & that you can't piggyback most aftermerket fuel computers, they just don't work. I'm hoping for the 16-bit version, because it can be piggybacked & is OK for tuning.
Code:
DiabolicJourney_SpaRky
DJ_SpaRky is offline   Reply With Quote
Old 03-23-2006, 09:37 AM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
So what you are saying is that if it is the 64 bit one to mod it your going to have to get a entire new chipset. Ouch.
Old 03-23-2006, 11:08 AM   #3
DJ_SpaRky
Resident Scion Guy
DJ_SpaRky's Avatar
well, not really, then 16-bit Echo one should work fine. the 64-bit one does other things on the Scions that the Echo & the Yaris don't have, like TCS & VSC, so you wouldn't lose those because the car never had them.
Code:
Old 03-23-2006, 07:11 PM   #4
why?
why?'s Avatar
Drives: Yaris LB
I mean that you will need to change the chip.
If it is the 64 bit chip, it will need to be swapped out to get mods to work.
Old 03-23-2006, 10:14 PM   #5
echo_hrs
Around the universe...
Drives: Uber-Evolved Pokemon
Well, based on those handy Yaris Technical PDFs posted a while back, the Yaris ECM is a 32-Bit CPU, with a whole slew of piggyback ECUs placed throughout the chassis connected via a BUS...
Cheers
echo_hrs is offline   Reply With Quote
Old 03-24-2006, 07:14 AM   #6
DJ_SpaRky
Resident Scion Guy
DJ_SpaRky's Avatar
oh, then yeah, but there might be some stuff that doesn't work with the swapped one.
Code:
Old 03-24-2006, 07:15 AM   #7
DJ_SpaRky
Resident Scion Guy
DJ_SpaRky's Avatar
Cheers
I saw that, mye question then is, is it a "Learning" ECU? does it adjust AFR based on TPS postion?
Code:
Old 03-30-2006, 07:48 AM   #8
DJ_SpaRky
Resident Scion Guy
DJ_SpaRky's Avatar
So I read thru the PDFs & saw nothing about it adjusting to the driving style, but I still need to read up on ETCS it might compensate for the style & so the ECU doesn't need to. That would be a good thing.
Code:
Old 05-17-2006, 11:59 AM   #9
Calidrifter
Drives: 1997 Nissan 240sx
stoopid learning ECU thats what killed the Celica, well that and the freaking DBW throttle.
Calidrifter is offline   Reply With Quote
Old 05-17-2006, 04:47 PM   #10
Idjiit
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback
You mean like the one in the Yaris?
Idjiit is offline   Reply With Quote
Old 05-17-2006, 09:23 PM   #11
Calidrifter
yup that would be it. The thing is that it is so fucking hard to tune cars with that on there because all of tese components are being adjusted there. There is no real way of avoiding the situation. The thing that will mess with it the most is if you get a SRI/CAI (short ram intake/cold air intake) it will set the ECU off and you will get the check engine light, one of the most common complaints on the 03 and up celica which introduced the DBW system. And auto companies are not likely to go back to the old cable throttles since emissions standards are so tough now.
Old 05-21-2006, 01:17 AM   #12
Chickon
Drives: Mazda RX-8
Its not hard, as long as the demand is high, then people will start working on it.
All ECU today (well, most) are Learning ECU, it has nothing to do with the ECU *bits*, many(most?) auto people doesnt know computer quite well and thought that *more bits* is harder/smarter/better.
Anyway, what they need to do, simple, pull the AFR table out, reflash it. but that requires alot of reverse engineering, of which, not many company going to take the *risk* to do (cuz Auto companies can sue you as long as they found that you reverse engineering their software)
This is one of the problem right now, take my car, the rx8 as an example. so far, the ONLY piggy back system that works really well is the interceptor X(or, M800). E-Manage(NOT Ultimate, it simply does not work, and Greddy too lazy to do anything about it) works *somewhat* too but too many problems, most people with Greddy kit are screaming just because of that.
Someone just found the AFR code inside the ROM, and trying to reflash it.
so ....
Oh yes, Im sure alot of xA guys mod their stuff, go scionlife.com and ask around. Im sure they have something.
Chickon is offline   Reply With Quote
Old 07-28-2006, 03:22 AM   #13
paultyler_82
Drives: 07 Meteorite Metallic Yaris LB
Good news... last I checked, Steve Millen was working on tuning Toyotas DBW CPU units, it was kind of a requirement in their IS project. In thier IS project, they were using the V8 out of a GS sedan and a Supra manual rear end... well, the DBW on the GS' V8 was tuned for an automatic transmission and made the manual a tricky drive, so they've been working on tuning the boxes, and as I understand it, the Toyota DBW systems all use a related chipset, so there is hope yet on that front. As far as the ECU goes... I heard of a product that works hand in hand with systems such as GReddy's Emanage that will basically provide the ECUs with certain values that it needs to see and will intercept others, letting the Emanage or similar unit insert proper values as you see fit within your tuning program, defeating the ECU's learning function, not sure on the validity of this, I'll look into it though.
paultyler_82 is offline   Reply With Quote
Old 07-31-2006, 09:28 PM   #14
soros151
Another question... :D
soros151's Avatar
Drives: Scion tC 06
Who said you can't use Engine Management with the tC 64-bit ECU? Then, how is it that many 64-bit ECUs are boosted in Scion Life. It just takes some more effort, but it can be done.
*One tire nearer to my goal*
soros151 is offline   Reply With Quote
Old 08-09-2006, 07:49 AM   #15
DJ_SpaRky
Resident Scion Guy
DJ_SpaRky's Avatar
tC has a different motor 2AZ 2.4L, the timing and AFR will be way off, not to mention the harness
Code:
Old 08-09-2006, 11:15 AM   #16
soros151
soros151's Avatar
Drives: Scion tC 06
But they said, that you CAN'T use engine management without having a lot of troubles, which is false.
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 03:12 PM
is the yaris for me? sauruman New YARIS Purchase Forum 14 02-27-2006 08:27 PM
