Old 02-28-2009, 09:08 PM   #1
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
My DynaPack Dyno Results.
Well I finally went to get my car dyno'd. I got it done at Munkey Wurks. It was on a Dynapack Dyno. They say that the Dynapack dyno gives more accurate numbers than the dynojet. I don't know if it's true or not, but it seems to be true. I didn't even break it into the 90whp mark. My best pull was 89.9 whp. I wanted to shoot myself. My mods include: 87 octane, royal purple, aFe intake, NST underdrive/WT/ALT pulleys, Blitz Nur Spec S axleback.
89.9 max whp
95.7 max torque
Pictures of the day..
Video from today:
Click watch in HD!!!!!
http://www.youtube.com/watch?v=u2EN2TyddrA
I'm not going to dyno my car again until my blitz S/C, NST crank lite pulley, aftermarket headers, and a 2.25" cat back set up is hooked up.
Yes, i've purchased the blitz s/c kit. It's being shipped out on monday. I will now join the club of pre-ignition and mysterious noises. Wish me luck.
Old 02-28-2009, 09:30 PM   #2
Has anyone ever run a completely stock Yaris on the Dynapack for a baseline comparison?
Old 02-28-2009, 09:59 PM   #3
PETERPOOP
PETERPOOP's Avatar
Not sure. All the dyno results on the dyno thread are done on the dynojet. I am also curious to know the numbers of a stock yaris on a dynapack.
Old 02-28-2009, 10:20 PM   #4
shoulda run the car to redline...
Old 02-28-2009, 10:24 PM   #5
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
congrats on the new kit and i think its the first time ive seen your car.what size wheels are those and i agree on the redline comment.
forget the wheel size i see how they had your car hooked up now....
Old 02-28-2009, 10:27 PM   #6
oh, and what the heck gear did they run it in?
Old 02-28-2009, 10:43 PM   #7
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Thanks for sharing!
I hope people appreciate your efforts to share your experiences.
It looks like you're near Dole Cannery?
Old 02-28-2009, 11:05 PM   #8
1nz
Drives: Vios
maybe its because of the 87 octane fuel
Please visit us @:
greddyvios.blogspot.com
1nz is offline   Reply With Quote
Old 02-28-2009, 11:44 PM   #9
PETERPOOP
PETERPOOP's Avatar
It is near dole cannery. Right across the street from home depot and next to best buy.
It was ran in 3rd gear. It wasn't ran to redline because I wasn't sure where redline was. I told him 6100rpm to be safe. When viewing all of the dyno charts on the dyno thread, everyone peaks right at 6k or a little before, i see none of them peaking higher than 6k. Also the guy doing the dyno said it doesn't really matter which gear it is in with a dynapack, but moreso with a dynojet. However, he usually pulls cars in 4th gear if they have an aftermarket ECU.
I ran 87 because the blitz s/c purchase was an unexpected purchase. If i knew far in advance that I was getting this kit, I would have circulated 92 many times before the dyno run.
This low number is fine. I will be returning to the same dyno and telling them to rev it to 6300rpm next time? I will have the blitz s/c, headers, 92 or 91 octane with some lucas mixed in there, an NST lite pulley, ngk iridium tip 7 heat spark plugs, and either a cat back/nitto midpipe/ or custom exhaust setup running 2.25" piping. Either way, i will know my current HP numbers at that time, and that's all that matters. And I KNOWWWW i'll break atleast 90whp! hah
Old 03-01-2009, 12:16 AM   #10
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
thank you for saying what i didn't feel like topping!
with such high torque numbers it sounds like you could do with a tune there!
Originally Posted by xnamerxx
you nailed it sir.
Old 03-01-2009, 12:18 AM   #11
PETERPOOP
PETERPOOP's Avatar
What's wrong with high torque numbers?
The guy doing the dyno said the ECU was doing all sorts of stuff during the pulls and the restricted stock exhaust piping with the cats came into play.
But he did say how much he liked my wheels, suspension, stance, and torque numbers.
Old 03-01-2009, 12:22 AM   #12
Tamago
Tamago's Avatar
Drives: ZZW30
not a thing
what i'm saying is.. if you yield high torque numbers and low hp numbers, there's something wrong with your tune.
remember
horsepower is just torqueXrpm/5252
you nailed it sir.
Old 03-01-2009, 12:25 AM   #13
PETERPOOP
PETERPOOP's Avatar
Well once I put everything else on, and the torque numbers still remain quite high, I will look into getting a tune. Can that be done with the blitz kit since it's pretuned?
Old 03-01-2009, 12:30 AM   #14
Tamago
Tamago's Avatar
Drives: ZZW30
possibly. if you can alter your air/fuel ratios, definitely
check the hp differences between 5 pulls, and all i did was remove fuel.. wish i'd known the turbo was blown :(
you nailed it sir.
Old 03-01-2009, 12:37 AM   #15
PETERPOOP
PETERPOOP's Avatar
so you were running rich at first? did you have a wideband a/f gauge to determine this during your pulls, or could you tell with the dyno?
Old 03-01-2009, 02:08 AM   #16
So Tamago's real name is Jenni
I think your result is whp, not bhp PeterPoop
Old 03-01-2009, 03:16 AM   #17
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Way to go PeterPoop. I'm glad you got a baseline of your car. I wanted to shoot myself after pulling 90 hp before the S/C. It's sobering because the car "feels" so fast. I can't wait for your dyno chart after the S/C.
I'm jealous of your numbers, Tamago, but I'm confused. What do you mean you removed fuel? You drained fuel from your tank? You changed octane?
Old 03-01-2009, 03:27 AM   #18
LtNoogie
LtNoogie's Avatar
More importantly Peter, how come you wore your t-shirt inside out?
TS/Xd Long Tube Header & Intake dyno results richardholdener Yaris TS Talk 21 01-06-2009 06:28 AM
NST Pulley Dyno Results richardholdener Performance Modifications 51 12-18-2008 10:11 PM
Long Tube Header Dyno results & Photo richardholdener Performance Modifications 59 11-26-2008 06:27 PM
dyno results are in!!!! turboyaris Performance Modifications 105 04-01-2007 07:03 PM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 11:14 AM
