#19 |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
Correct.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#20 |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
last I checked, unless there is a parasitic drain the battery is only actively engaged in the power circuit during starting
the alternator is supplying the power for everything else there after. |
#21 |
ekodrvr
Drives: 2002 white subaru impreza wrx Join Date: Feb 2009
honestly, that depends on how much power you use when you run the car... it actually takes about 40 amps just to RUN a car... let alone the stereo, wipers, headlights, heater/ac, etc... however, in a perfect world, when you run nothing but the car, you might save gas, but with anything in life, you probably will not save a noticable amount of gas... also, the battery will be charged when you go to start the car, but it will use some power to start the car...
#22 | |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2007
this might be of interest to some hypermillers... http://ecomodder.com/forum/showthrea...tml#post109942 this guy just got a deepcycle bat and a switch to kill the alternator, he trickle charges the battery at home, some how ends up on top |
#23 |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris sedan Join Date: Jun 2007
Probably not a lot. Now that we have all these major advances in electronics (lights, sound systems, etc), alternators don't have much work to do as before. If you dumped the water pump off that belt and converted it to electric, you would gain quite a bit, but I doubt if you would notice the difference...
#24 | |
#25 | |
Audio Junky
Stereo's are no more efficient than they were 10 years ago.... and if you go back 25 years ago people were putting in smaller systems, and thus a smaller load. The past 25 years has seen more and more electronics go into cars just to keep them turned on.... There is a ton of overhead spent electrically on computers.... Compare a domestic car from the 70's to a modern car.... Check the amperage draw while they are turned off... the 70's car will show about a milliamp due to a clock needing power... the modern car will be 5-20times that. That's when its turned off. Furthermore... alternators in modern cars aren't built with as much headroom as they were 20+ years ago. Things are getting harder. |
#26 | |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
#27 |
Every solar trickle charger that I've seen uses a voltage-sensitive diode to prevent overcharging.
#28 |
Then it's probably not taking enough charge to get all goosed out about. You can charge a battery all day long at 15.5 volts but soon as you kill the power it'll drop back off to around 13 volts or less, so I can't imagine a solar powered battery minder being able to do much with an already fully charged battery...I assume the battery is in good condition, the charging system is working properly and no parasitic drainage.
#29 |
![]() Drives: Future Yaris! Join Date: Oct 2009
Being a super hypermiller, yes this would work.
Over at ecomodder, the consensus of completely removing the alternator is of a gain in mpg's of 10%. yes those are real numbers tested in very effective ways. So yes, that would work. BUT, I doubt solar panels (with their MAX current efficiency of only 16% could make enough power to replace the power needed). Then what happens when its cloudy outside? If you only drive at night? etc etc etc |
#30 |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
Dont those solar trickle chargers plug into the lighter socket? if so is the circuit still active when the car is turned off?
#31 | |
yes some plug in, some connect to the batter directly. and no, when the key is off, the cigarette lighter circuit is not active. |
#32 |
For it to be beneficial it would have to be on the whole time (nothing major, a simple $40 charge controller online and a wire lead to the + and one to the - side of the battery and your done)... otherwise it would be a barely any help if you just have it while driving. The sun needs time and unless you ALWAYS drive between 11am and 2pm... your not getting the best of things.
Covering the whole roof/hood of my yaris is one of my objectives combined with a deep cycle battery on my way to completely remove the alternator- then I can remove the a/c and water pump pulley AND the crank pulley and replace those with electric motors (except the crank pulley, of course) |
#33 | |
...OR I'd just be happy with what Toyota engineered and not make life anymore complicated.
#34 |
37HSSV
Honestly, wtf has the Prius done!?
Now everyone wants Solar power on their car!!!
07 Toyota Yaris Hatchback -sold- 11 Mazdaspeed 3 -SRI/TIP, 3 inch TBI, Custom FMIC, Tuned by Cobb Accessport, HKS ssq2 BOV, Upgraded HPFP- Clean stock look... Killer performance. |
