Old 03-07-2009, 03:18 AM   #19
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Here's what you're looking for with increased ground clearance:
Me likey the trim on that Yaris!
Old 03-07-2009, 07:03 AM   #20
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
lol...i run 215/40R17 tires...and i dont know off hand the size, but i had some 15" snow tires left over from a previous car, and they were TALL...they fit on the 15" steelies i bought for the snowstorm we had, but the tires were almost enough to rub the fenders when the car wasnt lowered...the 17"s i have a couple inches gap, the 15"s i had about 1",lol.
it handled just fine in the snow and ice...i went everywhere, untill the snow got to 10". at that point i parked the car for fear of high siding it.
i would say if you want cool looks but more clearance at times, air ride or hydralics. air ride would prolly work fine and be cheaper i bet. you dont need to bounce up and down, just have adjustable ride height, and air ride would do that.
Old 03-07-2009, 10:22 PM   #21
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Can you say, "Citroen"? That was decades ago, it worked then it would work now.
Old 03-09-2009, 02:19 PM   #22
MUSKOKA800
MUSKOKA800's Avatar
OEM 185/60/15 = 23.7", while 195/75/14 = 25.5"
For snows, you'd probably be best with 175/70/14 = 23.7", or 185/70/14 = 24.3"
Thanks Kimona!
Unfortunitely similar sizes don't mean same height from one tire manf. to another. I'll be taking a tape measure when I go shopping for taller snows next fall.
Old 03-10-2009, 03:43 AM   #23
fuji
fuji's Avatar
Drives: Polar White Yaris HB
If you want to raise you yaris, you could try rubber coil spring spacers. They are readily avalible in one inch thickness
fuji is offline   Reply With Quote
Old 03-10-2009, 11:45 AM   #24
Yaris-x
Yaris-x's Avatar
Drives: 2008 Yaris HB
FYI 175, 185, 195, 0r 215 all have the same outer Diameter That is the width of the tire in snow you want narrow tires I run 175 in the winter and I pass 4x4 suv's all day I live in Syracuse NY the snow belt of the world. so 175 = 175mm of width 65 is the tire height so 65 = 65% of 175 and R14 obviously is the rim size
In snow wide tires are bad the wider the tire the bigger contact patch and the weight of the vehicle is spread over a larger area and the car is more likely to float on the snow causing a more unstable ride (My wifes xA is on 195 tires and I learned the hard way her car is horrible in snow) with narrow tires the car's weight is focused on a smaller area and the car is more likely to cut threw the snow.
Yaris-x is offline   Reply With Quote
Old 03-10-2009, 01:10 PM   #25
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Originally Posted by Yaris-x View Post
FYI 175, 185, 195, 0r 215 all have the same outer Diameter...
Are you serious?? Please don't spread misinformation, and learn how to read a tire size.
2006 Red Blitzed RS 5-door
Old 03-10-2009, 02:06 PM   #26
SeaYa
Is about to 'SeaYa' later
SeaYa's Avatar
Drives: 08 MT Sedan
FYI 175, 185, 195, 0r 215 all have the same outer Diameter ...
Doc is right, YX: the outer diameter is related to the sidewall ratio...so the only way for them to have the same outer diameter is IF you could get customized sidewall ratios for all those different sizes....ie: 61, 58, 55, 50.
SeaYa is offline   Reply With Quote
Old 03-10-2009, 05:26 PM   #27
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
If you change the ride height with spring spacers, or airbags etc, then you will need a wheel alignment after every change in height. If you change it by different profile tyres, you will not need a wheel alignment.
rob323 is offline   Reply With Quote
Old 03-11-2009, 11:00 AM   #28
Yaris-x
Yaris-x's Avatar
I'm not saying your wrong but the first number is not telling you the diameter. But yes going from 175 55 to 195 55 is a bigger diameter because 55% of 175 is different than 55% of 195. I am not spreading misinformation but he is better getting a taller 175 if possible. In snow it is not good to increase the width of a tire even if it gives you a inch taller tire
Dual ground electrode spark plugs Kitt DIY / Maintenance / Service 15 02-09-2009 12:08 PM
12/20/08 Buddy Club USA 5th Anniversary Clearance SALE DuckinOut California 3 12-18-2008 01:25 AM
FREE GROUND SHIPPING TO YARISWORLD MEMBERS zetaproducts.net ZetaProducts.Net 10 12-05-2008 10:29 AM
Installed the Tanabe Strut bar but had to remove my ground wire kit.. vacantj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-01-2007 02:56 PM
Can you purchase the Ground Effects for S Sedan? formerechoowner Cosmetic Modifications (Exterior/Interior) 1 04-18-2007 11:15 PM
