Old 03-12-2009, 08:28 AM   #1
bieniman
bieniman's Avatar
Drives: vitz rs 1500 2001
Temperature Guage install
HI Guys,
I Own a Vitz RS 1.5 2001,
There is no temperature gauge installed, just an "idiot light",
so I want to install a aftermarket gauge,a triple mini gauge set (SUNPRO).
Can I use the original temperature sender and connect it to the new gauge?
Because I still want the option of the "idiot light".
bieniman is offline   Reply With Quote
Old 03-12-2009, 11:26 AM   #2
You'd probably get better results by putting in your own sensor in the coolant line
Old 03-12-2009, 02:24 PM   #3
mark schofield
Drives: 03 Echo, 04 Scion xA, 02 Range
depending on what the other two gauges are that come with the triple mini gauge set, you might be better off with a scangauge.
mark schofield is offline   Reply With Quote
Old 03-12-2009, 02:45 PM   #4
I'm assuming you mean water temp and not oil temp? Your oil "idiot" light is for pressure, not temperature.
Either way, a decent gauge will come with a new sensor calibrated correctly for that gauge.
Tags
gauge, idiot light, sender, temperature, vitz rs 1.5
Pictures from Sundays 2-member meetup & vinyl install in Portland Astroman Photo-Video-Media Gallery 20 02-08-2010 01:55 AM
srs / airbag light after head unit install? KwonSau In Car Entertainment + Electronics (audio / video / alarm) 7 12-24-2008 02:04 AM
where can i install these power locks? songa New England 1 12-04-2008 12:41 PM
Water temperature Bob_VT General Yaris / Vitz Discussion 11 11-03-2008 03:17 PM
HOLEY COW 674.75 to install TRD lowering springs dbaxter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 08-09-2006 12:40 PM
