Old 03-12-2009, 04:47 PM   #37
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Anyone could suggest me a quality oil pressure sensor to be used on the 1NZFE?
The sensor must be compatable with the G-TECH PRO EGS gauge http://www.gtechpro.com/egs.html
Parmas is offline   Reply With Quote
Old 03-16-2009, 02:05 AM   #38
Parmas
Parmas's Avatar
Since no suggestions were posted I decided to go with the R-spec High precision pressure sensor http://www.rspec.co.uk/index.php?mai...roducts_id=487
During a discussion with my electrical manager on the car engine management he said that the stock ecu is needed for basic activity like radiator fan power on, dashboard tach and fuel pump power on. So my question is, could the stock ecu interfere with the upgraded ecu in any means?
Wiring is expected to be ready by tommorrow
Old 03-16-2009, 09:26 AM   #39
As for the sensor, did you email G Tech Pro for what sensor would be compatible?
This depends on what management you are using. I'm having my standalone control fans and pumps but not the dashboard stock gauges (which are all CAN). I'll probably need an aftermarket fuel gauge.
Old 03-31-2009, 07:11 PM   #40
Parmas
Parmas's Avatar
UPDATE:
Wiring about to finish. It only remains the high tension and then we go!
BOV and coil pack installed! A turbo shield was installed aswell to prevent brake lines and other main wiring overheating
BTW I am told that the 1NZFE internal springs are compatable with the celica ones? Anyone knows something about?
Old 03-31-2009, 07:54 PM   #41
nice progress! ^ You have some wiring to clean up!
Old 04-01-2009, 07:10 PM   #42
Parmas
Parmas's Avatar
Thanks garm will organize the wiring neatly this week!
Old 04-01-2009, 09:45 PM   #43
Looks like the fuel gauge works ok without the ECU in the car in mine. Don't know about the speedometer yet, will hope for the best.
Old 04-02-2009, 07:34 AM   #44
Parmas
Parmas's Avatar
In my case the stock ecu controls basically the dash electronics. The only thing will not work is the tach in that case I have an aftermarket one.
Old 04-04-2009, 09:32 PM   #45
Parmas
Parmas's Avatar
Finally today we managed to start engine. We tuned the idling and worked stable. One thing that impressed me is that although the exhuast is cut out from the middle straight tru, the engine was really smooth, at least I expected to be many more louder than that.
Tomorrow will get some pics for the complete setup.
Old 04-05-2009, 08:38 AM   #46
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
your ride is off the chart man, can't wait to see the final result. please keep us posted!
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 04-05-2009, 09:07 AM   #47
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
mm, yummy...turbo 1nz
Old 04-08-2009, 08:21 AM   #48
Parmas
Parmas's Avatar
Here are some recent pics of the complete setup.
The fuel pressure regulator was not installed because the stock one can hold about 17psi of boost. When I have some more cash ready I will upgrade the intake mainfold and the regulator at once.
Because of cash tune up is moved to 2 or more weeks ahead which in the meantime I will install all the gauges necassary and a dedicated computer system into the car to monitor and control the ecu in realtime.
Old 04-08-2009, 09:10 AM   #49
Parmas, I see your engine has a separate distributor for the spark plugs, was this stock on your car?
Old 04-08-2009, 09:21 AM   #50
ChinoCharles
Drives: LB
Vroom vroom!
Old 04-08-2009, 06:41 PM   #51
Parmas
Parmas's Avatar
No it was upgraded to a coil pack setup which normally used on a ferrari 360
Old 04-08-2009, 09:56 PM   #52
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
How are you increasing the fuel pressure in relation to boost pressure if you are not using an aftermarket fpr?
rob323 is offline   Reply With Quote
Old 04-09-2009, 05:30 AM   #53
Parmas
Parmas's Avatar
The stock regulator is capable of handle a good amount of fuel at 17psi max. When exceeding the 17psi then you need an aftermarket one (at least on the old yaris version)
Old 04-09-2009, 06:15 AM   #54
rob323
But the stock reg can't increase the fuel pressure to compensate for boost as it doesn't reference manifold pressure. I don't have access to my manuals atm, what is the stock fuel pressure for an echo?
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
