Old 01-26-2009, 12:05 PM   #37
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
Originally Posted by Split View Post
you need an extremely high offset for these cars. i would think that a 215mm tire would fit at +50mm offset and a 205mm tire should fit at a +45mm offset. The width of the wheel itself doesn't matter too much. It really matters what's mounted on it. You could technically stretch some 215's onto a 9"inch wheel, but there's no point.. you may as well just run an 8" wheel. I personally plan on buying just a 16x7 for summer next year with 205mm tires.
In the front you're right.
we're running a 7" +25mm now with a 205 in the rear and it fits nicely. (coilovers).
I guess ultimately I'll need to find some lower offset wheels to really "push" the limits of what "fits" and then decide from there.
too bad my 17x10s are drilled for 5x114 and 5x100
Russelt3hPirate is offline   Reply With Quote
Old 01-26-2009, 12:22 PM   #38
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
so 16x7 with 205/50/16 is good with trd spring ( 1.5" drop)..
Old 01-26-2009, 12:27 PM   #39
Russelt3hPirate
l33t3st Asshole
depends on the offset.
+43 or so you should be fine.
+35 you run the risk of rubbing.
Old 01-26-2009, 12:47 PM   #40
marcus
toyota
marcus's Avatar
so 16x7 with 205/50/16 is good with trd spring ( 1.5" drop).. oh yah its +40 offset.
Old 01-26-2009, 01:39 PM   #41
Russelt3hPirate
l33t3st Asshole
you "should" be fine although a slightly higher offset would be better if you're worried about rubbing.
may need to add a little camber if you do rub.
Old 03-13-2009, 05:16 PM   #42
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
so, have you found 15X9's yet?
Originally Posted by xnamerxx
you nailed it sir.
Old 03-13-2009, 05:37 PM   #43
Russelt3hPirate
l33t3st Asshole
no :(
I think we can make it work with the right tire size/offset and camber up front.
and saggio showed we can pull the rear fender a good bit.
I've got the 15x9s picked out, just need to figure out what's needed to actually get it to "fit"
well that and finding the $$ to do it :lol:
Old 03-13-2009, 06:02 PM   #44
Tamago
Tamago's Avatar
Drives: ZZW30
no :(
what wheels?
you nailed it sir.
Old 03-13-2009, 06:17 PM   #45
Russelt3hPirate
l33t3st Asshole
what wheels?
top secret. :)
15s though.
Old 03-19-2009, 03:48 PM   #46
Split
Drives: 2008 Yaris Sedan
Exclamation
Rota is pretty good about offering high offsets. Same with BBS if you can afford it. You might be able to find an 8"width wheel with a +48mm offset from them.
Split is offline   Reply With Quote
Old 03-19-2009, 04:15 PM   #47
Tamago
Tamago's Avatar
Drives: ZZW30
lolol IBRUSSELL
you nailed it sir.
Old 03-25-2009, 10:11 AM   #48
Russelt3hPirate
l33t3st Asshole
you wont see Rota's on the Yaris.
Support the real companies.
Old 03-28-2009, 08:41 PM   #49
edie
Drives: Toyota
So will 15 by 8 inch 43 offset fit on a yaris with coilovers?
The wheels wil be wearing 195/50/15 tyres on them
edie is offline   Reply With Quote
Old 03-30-2009, 05:17 PM   #50
Split
i've never owned rotas before. i have BBS RGR's on my IS300.. but seeing as the Yaris is a FWD Econobox, i think Rota will be just fine.
Old 03-30-2009, 10:08 PM   #51
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Originally Posted by REM View Post
Thanks guys. I just canceled my order for the 18s. I think I found some that I'm going to go with: 17x7 with an offset of 45. Those should work if I go with 205 tires , right?
Good choice. 18's are just way to big for our cars especially 18's that wide
Old 04-25-2009, 12:56 PM   #52
ChinoCharles
Drives: LB
BUMP
I need as much rubber as humanly possible on the road. I'm OK with running a staggered offset and even wheel size if raking the car forward a bit would improve traction. Any suggestions?
Old 04-25-2009, 01:05 PM   #53
Tamago
Tamago's Avatar
Drives: ZZW30
BUMP
225 45 15 on a 15X7 +35
why do you want staggered?
you nailed it sir.
Old 04-25-2009, 01:08 PM   #54
ChinoCharles
Drives: LB
Currently my fronts are pretty much flush, but the rears sit inwards moreso than the front, so a different offset for the front and rear would be ideal, no?
Glad you're here to respond to this Tamago.
05 AU Yaris Stock Speakers + Alpine iDA-X001 thatfilthyspringbok In Car Entertainment + Electronics (audio / video / alarm) 2 09-10-2007 09:06 AM
Yaris Body Kit Available in US - SEMA Yaris DJFMedia Cosmetic Modifications (Exterior/Interior) 26 10-21-2006 03:00 PM
