![]() ![]() ![]() Drives: Polar White Yaris HB Join Date: Dec 2008
Which rim offset would you pick???
I am looking for a lightweight 15" rim. There are a few choices and I am trying to decide which would work best for me.
I use 195/55/15 Michelin Exaltos Would you guys choose +35,37,41, or 42????? The Enkei RPF1 are the most reasonable $200 and about 9.5lb! Thanks in advance |
Mr. Clean
How wide? +42 is good for a 7" width.
Cool, the 42+ offset wheels are 15x7!
I have +42 for my 16x7" ssrs. Could use a 10mm spacer in the rear, but no biggie.
With ET42, you're safer up front to run 205mm tyres in the future.
With the 195/55/15 ties, will a +35 be a problem with rubbing in the front???
Would you like to tell us something about your suspension set-up first?
I am using NF210 spring in front - mild 1.1" drop
I wouldn't go lower than ET37 (up front) with a 195mm tyre.
If you're not into rotating, you could stagger the offsets for a better fitment. It's a very common practice in Japan. |
| Does Rim offset affect performace? | bosbik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 01-02-2009 02:31 PM |
| Can't seem to pick rim color | ZING | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 12-16-2008 10:49 AM |
| offset... | Keymaster | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 02-01-2007 01:53 AM |
| Rim sizing - what size to get for OE equivalent? | jay | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 11-20-2006 03:25 PM |
| max width and offset? | Fat Felixxx | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 06-08-2006 03:43 PM |
