#649 | |
Small Car Lover
I sometimes put the car in neutral (I have an auto as well). Anyway rarely or even at all I put my car in neutral at highway speeds but if there is little traffic I will put it in neutral and coast to a stop. It will harm your tranny if you're going highway speeds and you coast in neutral and if you accelerate then put it in drive its hard on the tranny but then again doing that in general hurts or wears the parts down faster. Hope that makes sense. When you reach lower speeds and slowing down you can down shift and use engine breaking instead of neutral, then put it in neutral while sitting there. I guess remember if coasting in neutral can be dangerous in case you have to make an evasive manevure so don't do it in heavy traffic (rush hour) but I guess that's a give-in cause I'm sure if traffic was that heavy you can't really coast. I probably confused you even more but that's what I'm here for
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will. |
#650 |
uhhmmm i've heard about some techniques in down and upshifting on automatic trannies... but how do you do that? do you flick the gas pedal or something? sorry this will be my last OT post :D
#651 | |
![]() ![]() ![]() Drives: 07 yaris sedan (silver) STICK Join Date: Aug 2006
nope I just put it on IGN III
#652 | |
It's heel toe downshifting. For ex: When coming off the highway for your exit, you put your car on the outside curve going in *to the apex* and put the clutch in, BLIP the throttle. < On the yaris you have to kinda hold it there for a millisecond since it takes time for the throttle body response to open up* then shift down to the next gear and release the clutch. Doing this puts less strain on the gears when you slow down or come to a stop. If you are doing it correctly< and I mean CORRECTLY, your car will come to a SMOOTH transition without budging to a stop or when exiting off an off ramp. Any budge and transfer of motion to the front and your tranny's hurtin.
#653 |
hmmm haven't done it but i think i can imagine how you do it from the way you explained it :) i probly need a lil more practice.. thanks guys for sharing anyways :)
#654 | |
Small Car Lover
For automactic you just move the shifter selector down to 2nd, or L gear, some cars are set up 3rd, 2nd, and L, but either way its obviously a lower gear. DON'T have your foot on the gas while shifting to a lower gear or even up. Position D is obviously the most ideal selection for driving, I've heard some people trying to drive their cars like a stick with an auto...starting in L gear then going up to Drive, but don't, it puts more wear and tear on your tranny and its just not made for that cause well, its an Automactic! Anyway as I said earlier, don't be shifting at high speeds, its not good for the tranny cause its taking a beating to the high reving engine-at least for auto. Hope tha helps
#655 | |
sorry i read the member's post too quickly. Thought me was asking for a manual
#656 | |
#657 |
Bears eat beets.
Drives: Yaris LB Join Date: Aug 2006
best tank yet...
drove up to burlington, vt this weekend for a race. had my bike/wheels on the hatch rack.
414.1miles / 9.36gal = 44.2mpg!!!
Free veggie starter kit! |
#658 | |
Bears eat beets.
i have hurd the same things regarding coasting in an Auto. Best to listen to someone that drives one... maybe they can chime in..
#659 |
Okay I just filled up the gas.
446.8 miles @ $2.25 /gallon total gallons 9.68 46.15 mpg Guys I just broke my record from 434 to 446.8 and could have gone further to my actual goal which was 460 miles, DAMNIT I was that close!
#660 | |
![]() ![]() ![]() ![]() ![]() Drives: LB-Auto-PWR-ABS-Cruise-Springs Join Date: Aug 2006
#661 |
first tank 38.6
second tank 37.8 third tank 39.7 It gettin better |
#662 |
![]() Drives: '07 HB Manual Yarrrrris Join Date: Aug 2006
What am I doing wrong? Note that I haven't been using A/C.
First tank: 34.4 mpg Second tank: 36.0 mpg Third tank: 35.2 mpg I have a manual shift '07 hatchback. 90% of my driving is at highway speeds, half at around 60 mph, and half at around 75 mph. My shift protocol is to go into 2nd at 10 mph, 3rd at 20 mph, 4th at 30 mph, and 5th at 40 mph. Help? :) --Rob
Yarrrrrris!
#663 | |
Bears eat beets.
additionally, i coast whenever possible, and try to "look ahead" for my stoplights, so that i rarely end up stopping... i just coast slowly untill its green...
#664 | |
OUCH, since it's a liftback, you guys really need that Tachometer.
#665 | |
![]() ![]() ![]() Drives: two yaris liftbacks Join Date: Jan 2006
#666 | |
![]() ![]() ![]() Drives: 07 Yaris Liftback Join Date: Aug 2006
