Old 03-18-2009, 10:53 AM   #19
regal
Drives: 09 Yaris 3 Dr White LB
IMO you shouldn't be drving like this until at least 1k miles. You are not going to get a good seat on your piston rings. You will actually get better compression and milage if you drive the first 1k miles hard with a lot of accelerations to seat the rings.
regal is offline   Reply With Quote
Old 03-26-2009, 07:51 AM   #20
YarisOwnersDad
Is now a Corolla S Owner
Drives: 2010 Corolla S
To each his (or her) own, but I have no desire to run my car (a Cobalt, but brand doesn't matter for this discussion) down to the very last drop in the fuel tank.
As someone mentioned earlier, the fuel pump is cooled by the gas in the tank, and running the tank level too low can be harmful to it.
They say that in cold weather it is good to keep the tank above the 1/4 tank level to reduce condensation of moisture in the tank. Where there is no fuel, there is air, and air has moisture in it. When the air cools, it will not hold the moisture, and condensation occurs, which puts water in your gas.
Also, why take the chance of running out of gas?
Maybe I'm just missing something? Why would a person want to run the tank down to the last drop before filling up?
Tom
YarisOwnersDad is offline   Reply With Quote
Old 03-26-2009, 11:47 AM   #21
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
I agree. When I see that last bar flash, I'm looking to fill up soon.
Old 03-26-2009, 12:03 PM   #22
firebob
Drives: 09 yaris
IMO If you run the tank down to low then yes the fuel pump has no gas to cool it. But you’re more likely to suck the stuff up in the bottom of the tank and on the bright side it should all fall back down as your fill the car up the next time.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week.
firebob is offline   Reply With Quote
Old 03-27-2009, 12:42 AM   #23
captainm27
Drives: 2008 Sedan A/T Silver
Don't worry about the last bar. The blinking just lets you know that it will soon switch to battery power.
captainm27 is offline   Reply With Quote
-Mileage Thread- -Log your mileage, year, model, color, any problems here... Kal-El DIY / Maintenance / Service 322 07-20-2016 10:07 AM
Sedan better gas mileage than LB? 5 month gas chart included flint_mica_manual General Yaris / Vitz Discussion 24 03-09-2009 08:24 AM
Performance mods that won't affect/will hardly affect gas mileage?? Mr.Yaris Performance Modifications 15 07-30-2007 12:32 AM
Tired of poor gas mileage & buying premium gas. Boosted Peon New YARIS Purchase Forum 29 08-25-2006 08:59 PM
Fuel / Temp / Mileage Gauge - Special LED Readings? bigsky2 General Yaris / Vitz Discussion 3 05-31-2006 09:04 AM
