Spoiler installation gone wrong
Hey guys,
I got a RS Spoiler and wanted to install it on my yaris.... So I painted it (not the best paint job) and tried to install it It had two screws that needed to be drilled into the back of the yaris and put in. So I measured the screw width and drilled a 7 mm hole at the back. But the screw didnt go in.... So I took a 8mm drill bit and expanded the hole.... Now the screw is a bit loose ![]() ![]() Can you give me a way to fix this stupidness of mine? Also, I thought it will be fine, so I covered the top of the screw with a cap so that the screw doesnt fall out... now I cant access the screw |
3m tape
So you reckon I 3m tape the whole thing onto the roof of the car??
![]() ![]() ![]() ![]() Drives: Yaris YR Join Date: Oct 2008
I was gonna get an RS spoiler, but i'll prob be getting a panel and paint shop to do the work. Where did you end up getting yours from? Sorry to hear about the drillling problem, that kinda sucks.
![]() Mods: 17x7 ANZ Tazer Wheels with 215/40/17 Marangoni Tyres | AFE Air Intake System | NST Short Shifter Kit | NST Shifter Cable Bushing Kit | NST 10% Underdrive Crank Pulley | Pedders Sports Springs | Custom 2inch Cat-Back Walker Muffler with 2.5inch Xforce Twin Stainless Steel Tip | RS Side Skirts | RS Euro Spoiler | YRX Front Lip Spoiler | TRD Style Front Grill | 12mm Rear Hub Spacers | Ultra Racing 23mm Rear Sway Bar |
JDM yO!
Drives: '09 3dr. 5-spd Join Date: Oct 2008
Try some automotive double sided tape. You can pick up a roll at your local Bunnings for ~$6-7. Are the caps that you placed on, not removable?
Can't you just use a larger screw?
I ended up drilling holes from underneath and using bolts, washers and nuts -- my spoiler isn't EVER coming off.
from underneath... hmmm... that sounds like a plan as well... If I somehow strip the the back panel from the hatch, I should be able to see the bolts sticking in??
![]() ![]() ![]() Drives: Yaris 3Dr LiftBLACK Join Date: Jan 2009
| DIY Sedan Spoiler Install | Kaotic Lazagna | DIY / Maintenance / Service | 36 | 01-19-2020 11:35 PM |
| Liftback Spoiler Installation | Toddhata | Cosmetic Modifications (Exterior/Interior) | 25 | 08-09-2009 01:26 AM |
| RS SPOILER ... SAD | aznbabiegrlx0x0 | Cosmetic Modifications (Exterior/Interior) | 42 | 09-28-2007 09:49 PM |
| Rally style spoiler in white for sale!! | cheukli | Items for Sale by private party | 11 | 07-18-2007 09:02 AM |
