Old 04-05-2009, 09:04 PM   #1
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
GI: 1nz/1zz TB spacer
Throttle body spacer that fits both 1zz and 1nz TB's and can be made to order with a tap for a nitrous nozzle.
I need to guage interest on the first order so i can create accurate pricing.
I need to know who would be interested, and an approximate amount that people would be willing to pay.
1. mikenacarato
2. yarstar
3. miniTRD - Clark
4. tk-421
5. YarisSedan
6.
7.
8.
Old 04-05-2009, 11:37 PM   #2
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i would definately be on the list for sure. the issue is $$ though. :(
mikenacarato is offline   Reply With Quote
Old 04-06-2009, 01:19 AM   #3
fuji
fuji's Avatar
Drives: Polar White Yaris HB
If you can hook up nitro, I would be up for it as well.
fuji is offline   Reply With Quote
Old 04-06-2009, 01:43 AM   #4
way to go!
Old 04-06-2009, 01:55 AM   #5
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
I'm glad we are generating interest in this, hopefully we can add another performance part to the 1NZ-FE and 1ZZ Arsenal.
Old 04-06-2009, 01:57 AM   #6
dallas
Drives: Yaris Hatch /Landrover D2
Can we specify who's fogger we want to use as there are critical design differences between brands?
dallas is offline   Reply With Quote
Old 04-06-2009, 01:58 AM   #7
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Can you design one that smoothly transitions the 1zz throttle body to the 1nz intake manifold. It seems like there's an abrupt transition for those who are putting the 1zz throttle bodies on their Yaris.
Old 04-06-2009, 02:25 AM   #8
jkuchta
Drives: 2007 Yaris hatch (red)
^+1
jkuchta is offline   Reply With Quote
Old 04-06-2009, 02:43 AM   #9
mikenacarato
SIPNDEW
Drives: 15 STI
^+2 :)
Old 04-06-2009, 05:20 AM   #10
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Interested!
Old 04-06-2009, 07:51 AM   #11
yarstar
Drives: 2008 Absolute Red HB
VERY interested!
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 04-06-2009, 08:22 AM   #12
AlexNet0
AlexNet0's Avatar
I suppose you could, as long as it was provided to us when you ordered it, because we need to make sure the threads match perfectly so when you screw in the fogger, its facing the right way. We were planning on using a right-angle fogger.
Old 04-06-2009, 08:35 PM   #13
AlexNet0
AlexNet0's Avatar
I dont think I know quite what you mean.
do you mean a middle ground? a slight restriction on the 1zz tb while still more flow than the 1nz TB?
or like a port match?
Old 04-07-2009, 12:51 PM   #14
AlexNet0
AlexNet0's Avatar
bump
Old 04-07-2009, 01:48 PM   #15
LtNoogie
LtNoogie's Avatar
If I'm not mistaken, the 1zz TB is a larger opening size. It is being bolted to the 1nz intake manifold which has a smaller opening. I figured that an abrupt interface from larger diameter to smaller diameter would cause unwanted turbulence at the transition.
My question was... can your adapter plate taper from the larger diameter opening to the smaller diameter opening to lessen the turbulence?
Old 04-07-2009, 02:31 PM   #16
yarstar
Noogie may be on to something with that low turbulence idea.
What do you think Alex?
Old 04-07-2009, 05:52 PM   #17
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
He is on to something, otherwise all the spacer will do to the guys with the 1zz tb is allow the air to come at the intake manifold at a higher velocity and when it enters, it would be more turbulent than it is without a spacer. the spacer could/would actually cause a larger disturbance to the entering air.
taper would pretty much be required for those of us with the 1zz tb.
Wanted: Forced Induction
Old 04-07-2009, 05:53 PM   #18
AlexNet0
AlexNet0's Avatar
I could alter it or make a different one that did that, but I think that the opening on the Intake mani actually matches that of the 1zz TB, I actually didnt look at the size differences of the TB and intake mani, so if someone else who has recently done the mod who actually looked could tell us, that would be awesome.
1ZZ Throttle Body Spacer tk-421 Performance Modifications 34 07-11-2017 09:48 PM
Ideal Spacer Width For the Rear? tk-421 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 01-27-2009 05:59 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
