Old 04-09-2009, 09:29 PM   #19
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
All this means crap to me . Just tell me what the photon output is ...........
Old 04-10-2009, 12:58 AM   #20
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
well , you want to have a constant 60mA right? Remember Ohms law V=IR right? then 12V divided by 60mA equals 200Ohms. Now for the power you can use like you said I^2R or V X I. 60mA^2 X 200Ohms = 0.72Watt
If you use an 18ohm resistor you only dropping 1.08V
200ohms is calculated for a fixed resistor burning all that current (so no LED's in that circuit, just a resistor alone). The way you can factor in LED's is that you need to subtract all the forward voltage drops and resistor handles the leftover voltage. If you want to look at it that way, assume the LED's were dropping 3.5V at 60mA (these specific ones are not dropping that exact value, but let's assume anyways).
V = 12 - 3.5 - 3.5 - 3.5 = 1.5V. This is the leftover voltage you will use a resistor to deal with. So V/I = R, 1.5V / 0.06A = 25 ohms. So 3 LED's + 25 ohms for that circuit.
Since LED's are a function of current, I usually will use an ammeter and potentiometer to dial in the desired current. China LED's don't have nice and pretty voltage to current charts to work with, and their bins are always different, so it's always a guess and check.
taKuto is offline   Reply With Quote
Old 04-10-2009, 10:51 AM   #21
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
The voltage drops are still pretty average for a white LED (3.4-3.8V typical), it's current that usually varies. I got the LED's off some random china supplier from ebay. 10mm 5 chip white LED's i think.
Old 04-10-2009, 06:48 PM   #22
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
yup, but china stuff is still much cheaper :)
only things i've been browsing on digikey are the offerings from cree. I might pickup some P4's to play with. The higher powered offerings from cree are far too expensive off digikey, i'd rather get them from china suppliers such as dealextreme.
Old 04-11-2009, 02:30 AM   #23
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
I was going for digital/analog hardware but changed focus to power systems
Old 04-11-2009, 11:53 AM   #24
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
university of toronto
Old 04-16-2009, 12:07 AM   #25
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Hahhaha... j/k. Whatever. Nice pics, taKuto. Nice cutoff too... *is* it a kit? Or a retro?
2006 Red Blitzed RS 5-door
Old 04-16-2009, 12:42 AM   #26
red_rims
Black Yaris
red_rims's Avatar
Drives: Black Yaris
sick
red_rims is offline   Reply With Quote
Old 04-16-2009, 02:14 AM   #27
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Old 04-16-2009, 01:32 PM   #28
mastaofdisasta
mastaofdisasta's Avatar
Drives: yaris
Current is equal within one series circuit. Voltage drops on each LED. For my setup it's 3 LED's per circuit, so 60mA flows through all three LED's. Each LED gets 60mA and drop some voltage. A resistor drops the rest to maintain the current value (i believe i used 18ohms, cant remember) since the power source is a regulated 12V LM7812. These LED's are multichip, china overrates them at 100mA, so I run them at 60mA.
Man i work at radioshack and have no idea what the hell yall are talking bout
ballin on a budget.
mastaofdisasta is offline   Reply With Quote
Old 04-16-2009, 03:23 PM   #29
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
TL projectors with philips ultinons running off hella gen 3 ballasts. OEM purple power!
mastaofdisasta, just basic circuit theory, time for you to brush up! :)
FS: Parting out 05 echo hatch VANCOUVER blackvitzrs Items for Sale by private party 12 03-05-2010 10:14 AM
LF: Yaris / Vitz / Echo hatch accessories / parts! Keej_05RS General Yaris / Vitz Discussion 3 12-08-2008 09:43 PM
FS-2005 Toyota Echo Hatch aka "Panda Vitz" FOR SALE 3cyltrbo Items for Sale by private party 12 08-21-2007 05:48 PM
TRD Turbo ECHo Hatch - Yaris TS CASTREX General Yaris / Vitz Discussion 12 04-03-2007 11:04 AM
Toyota Echo or Scion Xa/Xb for aftermarket HU receiver kit? ceboyd In Car Entertainment + Electronics (audio / video / alarm) 7 12-08-2006 02:13 PM
