![]() ![]() Drives: SLOOWZ Join Date: Aug 2006
Anyone tried to appy Apexi SAFC or anything similar on their YARIIIII??
Does it work ??
Why to use it?
![]() ![]() ![]() Drives: 07 Meteorite Metallic Yaris LB Join Date: Jul 2006
I beleive Power Enterprise's CamCon works on our car and can modify the VVT-i engagement points.
#4 | |
i m not sure .. |
Sounds nice idea.
Like a VTEC controller for Hondas, eh?
#7 | |
yes,exactly,but i m just not sure it can be applied on yaris or not... |
Im almost positive it wotn help the Yaris much. We hooked up one on the Celica, VVTL-I GTS didnt do anything but actually cause problems. Might be different for the yaris, but If it works let me know :)
#9 | |
what problem does it cause? i would like to make sure it helps before i buy it ...cause i know it helps on Vtec engine,but just not sure it helps on VVTi or not |
Ι think you won't have steady engine rpms.
#11 | |
I 've seen people installed on ECHO on the nets before with the pen-shape turbo timer...why they installed a turbo timer on a NA echo...with SAFC... i don't know...may be it gives a ricer impression??that's why i m asking since the SAFC has a good looking and if it really helps the engine i will go for it, but if not..i won't |
Without being a mechanic, I am of the opinion that it won't help.
What the...?
Drives: '06 Blazing Blue 3 door RS. Join Date: Oct 2006
there is a big difference between Vtec and VVt-i. an engine with a performance based thing like Vtec and an economy based thing like VVt-i place it in two different worlds.
think about how they both work. honda's will change the valve train to a bigger lift and bigger overlap at a specified RPM, it never changes unless you have an aftermarket ECU that you can change the engagement point. VVt-i will only change the timing of each cam and its constantly evolving during engine operation. you want more power in these things, buy a compresser, or swap in something else... |
...exactly!
VVTrouble
VVTi - controlled by the TPS (throttle position sensor)
Vtec - controlled by engine RPMs The VVTi advances timing and starts the valve overlap as soon as you put your foot (about) 3/4 of the way to the floor and returns to "normal" when cruising....theres no real way to change the engagement time Vtec is a whole seperate cam profile where the camshft actually slides over to a more aggressive profile (Vtec camshafts have 3 sets of lobes for each cylinder). So with an aftermarket controller you can activate the aggressive cam profile sooner getting a bit more power Toyota VVTi (1JZGTE) HKS cams: ![]() Honda B16A cams (3 lobes per cylinder): |
I know that overriding the ECU on Nissan engines to modify the CVVT helps performance, but maybe Nissan goes about things a different way, basically, CVVT advances the cams forward under heavy throttle to give more performance, until it senses knock, then it retards the cam back a bit.
What the...?
i'm sorry,
there is a huge difference between valve overlap and bigger lift on a third lobe then there is in a variable overlap system like VVT-i. VVT-i does nothing for adding more lift... there is nothing that says that VVT-i adds power. VTEC does... |
#18 | |
and actually, all engines that use some sort of variable cam timing system like Toyota's VVT-i or Nissan's CVVT, use such a system for the performance benefit, it's there to squeeze a few extra horses out of the engine at high RPMs or hard throttle. Although it may not be as noticable in the VVT-i engine as it is in one of Nissan's CVVT engines (they can advance and retard BOTH the intake and exhaust valve cams) or in Honda's VTEC (of course the added benefit of variable lift.) but it is there for the same reason, it is a much more noticable difference on a Dual VVT-i or a VVTL-i engine, of course. |
