Old 04-15-2009, 08:23 AM   #1
severous01
AFE cai intake....pros/cons
hey all....i just installed an AFE intake on my car...i wanted all to know my thoughts on the subject. for any of those interested or maybe thinkin of buyin a used kit like i did...
any way, on to the good bad and uglies. im gonna list everything to the last detials i can think of so bear with me.
cons...
installation instructions sucked. not that u really needed them but i got confused reviewing them...and yes i've done several of these on several models of cars.
next would be the thing bounces around like a marble in a tin can...and yes i installed it correctly. i'm hitting the bumper support, OEM airbox bracketry and the radiator. so when the engine shakes....it hits everything.
the mounting screw threads in the intake decided they wanted to come loose and spin freely with the bolt. so my MAF isnt as tightly secured as i want it, but at least i know it's not gonna come off...the thing spins with the bolt lol.
there is no place for EVAP purge solenoid to mount so i gotta 'rig' it up somehow.
last but not least, what's the deal with the airbox inlet being right there behind the radiator? as if the air bypassing it or the headlight wouldnt be enough.
pros...
once i decided to throw the instructions away and run with it...installation took me about 35 min. the kit is relatively solid, mounts easily.
i had a noticeable power increase, not nearly as much as my v8 car but it's worth the price if u can get them used.
i'm sure that if i can keep my foot off the throttle then i'll get a decent mileage increase. instead of choking the engine with wavy tube work and restrictive air elements, there's nothing stopping the pistons from sucking any amount of air that atmosphere can provide.
so for anyone thinking of getting one...i waited and found one used for a good price...about 200 bux off retail...and it was definitly worth it for me. pro's outweigh cons...i can get some foam tape and fix my rattles, and i can also find a place to zip-tie my EVAP stuff...
Old 04-15-2009, 09:21 AM   #2
hatchbackkid82
Drives: .
Hmmmmmm........ I installed this kit in my car too. Doesn't bounce around at all in my car. The weapon r intake i had did, that's why i got rid of it. i think this is one the best intakes you can buy
Old 04-15-2009, 10:44 AM   #3
mrbond
mrbond's Avatar
What I ended up having to do with the mounting point on the battery was take a large bolt (10 - 13mm) and put it in between the battery and the AFE mounting point. It stopped all vibrations. That was probably the one thing I disliked about the kit, other than the instructions. Glad to see it arrived :)
- A Toyota Yaris
- A whut Yaris?
Old 04-15-2009, 03:12 PM   #4
severous01
thaks bond. it's great and in great condition...i'm getting way better FE out of the thing. i usually get around 74mi t the first 1/8 mark, and i hit over 85 today. highway driving.
well, after carefully looking at it there's a hole in the very bottom that is directly over a hole in the original airbox mount. i think i'm gonna get some hose and a bolt/nut and mount another mounting point. i did stop one rubbing issue, right on the frame for the bumper support. i bent the little tab where it mounts by the headlight and that fixed most of it...still when i'm not shifting right into first and the car shakes it'll rattle...oh well. it's definitely worth the performance and fuel economy.
and i'm not gonna stick a bolt in there, although a good idea to stop the rattle, it's gonna cause rust...and who knows what if it actually comes loose.
Old 04-16-2009, 12:28 AM   #5
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
You must have gotten fucked with your intake I didn't have a single issue with mine except for having to rig a line with a cable tie to hold it.
Old 04-16-2009, 12:33 AM   #6
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
ditto.
see what happens when you try to save a dollar?
You got it for 200$ off retail? They are 174$ brand new on microimage. Shipped
http://shop.microimageonline.com/pro...2&productId=74
Old 04-16-2009, 01:48 AM   #7
red_rims
Black Yaris
red_rims's Avatar
Drives: Black Yaris
dude i bought AEMs. They work well for my car. Here in Cali it doesnt rain much so AEM long ram intake is cool for me. Im thinking about buying AFE for raining season next year though.
red_rims is offline   Reply With Quote
Old 04-16-2009, 02:11 AM   #8
PHXDEMON
PHXDEMON's Avatar
I have driven through beleive it or not a couple heavy patches of rain on the AZ freeways and not even a drop of rain got into the box that surrounds my afe intake
Old 04-16-2009, 09:42 AM   #9
severous01
well the cheapest i found on ebay is like 275 bux. so...ya, i got it for almost 200 off retail. and everything is there, nuts, bolts, spacers, washers, all that jazz...
but there is still nowhere to put the solenoid, and i'm gonna have to rig it to make it right....as far as i can see is that there is NO PRODUCT ON THE MARKET that provides a place for the solenoid. they all relocate it, which is what i'm gonna have to do.
not a problem, just wasnt expecting to do any 'rigging' on my car with a CAI
Old 04-16-2009, 04:21 PM   #10
Edgarm87
Drives: 2008 Stock Yaris Sedan
Hi everyone, I'm new here and I have a stock '08 yaris 4Dr.
Does anyone know if there is a risk in putting a CAI? such as ruining the engine somehow or burning a sensor? I want to get the Fujita CAI for my car but I am not sure if I should or not.
Also, I just want my car to sound cool..would an intake make any difference in the sound my motor makes?
Thanks for your help and time!
-E
Edgarm87 is offline   Reply With Quote
Old 04-16-2009, 05:45 PM   #11
33OH
Drives: '08 Yaris
-E
The only risk is if water gets into the engine via your intake. Any short ram intake, such as the AFE talked about in this thread (http://shop.microimageonline.com/pro...2&productId=74), will reduce the risk of hydrolocking.
Also, yes, the intake makes your car sound "cool". It gives it a very throaty, deep noise.
Old 06-24-2009, 10:53 AM   #12
vten
I got the afe intake and CEL !!
"the mounting screw threads in the intake decided they wanted to come loose and spin freely with the bolt....the thing spins with the bolt ... " if they make the maf housing with a metal, that would be a different story....
Im gonna get the AEM from Garm ....
Old 06-24-2009, 11:00 AM   #13
hatchbackkid82
Drives: .
I guess you would be the only one that i know of that got a CEL with the AFE. You sure you installed it correctly?
Old 06-24-2009, 12:46 PM   #14
huh? the aFe intake is $174 shipped brand new. $200 off retail is free?
Or maybe we aren't talking about the aFe intake that I sell.
It shouldn't "bounce around" at all. None of the ones I've installed do that, nor have I heard other reports. You bought it used; did it come with all the parts? It IS supposed to be bolted down at the bottom. Make sure you remove the airbox bracket under the stock airbox before installing the aFe box
Old 06-24-2009, 01:16 PM   #15
hatchbackkid82
Drives: .
i didn't even know AFE made a cold air intake for our car, i thought it was just short ram
Old 06-25-2009, 01:27 AM   #16
PETERPOOP
PETERPOOP's Avatar
it is a short ram design, however it's called the AFE CAI 2....i believe. i think they call it a CAI because of the heat shield that goes around the filter, and doesn't go down in the wheel well like traditional CAIs.
Old 06-25-2009, 12:15 PM   #17
they call it a Stage 2 because it replaces everything from the throttle body on; larger diameter pipes, etc.
Old 06-26-2009, 08:30 PM   #18
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
well for the few months that I was able to drive my car before heading overseas mine worked like a champ, didn't rattle/vibrate, and I have no clue about what they dude is talking about having to reposition a solenoid??
AEM cold air intake vs Afe intake... djgab101 Performance Modifications 69 04-28-2013 03:03 PM
AFE Pro Dry S Intake For Sale azhuskcarr Items for Sale by private party 10 03-18-2009 12:11 AM
Pics of my AFE intake install + questions auxmike Performance Modifications 48 03-11-2009 06:39 AM
AFE Intake on a Sedan??? CASTREX Performance Modifications 7 12-12-2008 01:27 PM
