Old 04-23-2009, 10:26 AM   #1
joeharth
Drives: 2007 Hatchback
kiwi or scangauge?
Hello everone I just found the kiwi plx one ebay for $85 + $8 very cheap.
Item 400043450156. I want to get one for my car, I have a 87 with no tach. Is this a good replacement for an aftermarket tachomerter?. Is it easier to install? or should I expend the extra money and get a scangauge. I looked around in the forum and it looks like this is the way to go for an after market tach. Any suggestions appreciated.
joeharth is offline   Reply With Quote
Old 04-23-2009, 10:32 AM   #2
1stToyota
1stToyota's Avatar
Cheapy Kiwi doesn't offer much, so I'd go Scangauge all the way.
Kiwi offers a real nice one for about 300.00, but it's geared mainly to those that want to get maximum mpg...it's designed to train you how to drive for that maximum fuel economy.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 04-23-2009, 11:51 AM   #3
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
If you just want a cheap, plug and play, tach, the KIWI can fill that need. If it's engine performance that you want, the Scangauge II would be much better.
Microimage sells the SG II.
Old 04-23-2009, 12:07 PM   #4
joeharth
Looks like this unit has mpg and rpms and other things but will the connector work with 07 hatchback? is this a standard connector? Is the set up for this unit easier than an aftermarket tach?
* Fuel Used (Gallons, Liters)
* Fuel Remaining (Gallons, Liters)
* Distance to Empty (Gallons, Liters)
* Engine RPM
* Vehicle Speed (MPH, KMH)
* Coolant Temp (Fahrenheit, Celsius)
* Throttle Position
Old 04-23-2009, 12:31 PM   #5
1stToyota
1stToyota's Avatar
* Engine RPM
* Throttle Position
Set up can't get any easier, Kiwi just plugs into the same OBD-II diagnostic port that all '96-up vehicles have. It'll take you longer to peel the backing off the velcro than it will take you to find the port and plug into it...port is approx 2" right of hood release.
2008 Scion xD
Old 04-23-2009, 03:04 PM   #6
TheUnGroomed
TheUnGroomed's Avatar
Drives: 08 Meteorite LB
Send a message via AIM to TheUnGroomed
The setup is much easier than an aftermarket tach, but the refresh rate is slower than a real tach.
TheUnGroomed is offline   Reply With Quote
Old 04-23-2009, 03:22 PM   #7
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
I have a ScangaugeII and a tach. Tach is more responsive, scangauge is for the MPG's and all the other info like temps, pressures and such that aren't in the Yaris gauge cluster.
Old 04-23-2009, 09:57 PM   #8
GeneW
Drives: 2008 Yaris
A Scanguage is so useful I suggested to my Toyota dealer that they offer them with each new Yaris and other economy car. They said that they'll "Think about it" which I consider a qualified "no".
Having never used a Kiwi I don't know a thing about it.
Gene
Official Scangauge II Thread - Share your Data, Discuss Settings ,Problems, Findings! TRD_Yaris General Yaris / Vitz Discussion 183 02-01-2017 12:18 PM
WTB stock rims + tires + ScanGauge Tonavi Willing to Buy by private party 5 12-25-2008 11:09 PM
scangauge II versions TinyGiant Fuel Economy Forum 1 12-23-2008 12:10 PM
FS: Scangauge II (barely used) $80 Fel Items for Sale by private party 25 12-08-2008 11:15 PM
PLX Kiwi natethegreat38 Fuel Economy Forum 27 11-14-2008 10:57 AM
