![]() Drives: 2008 Yaris Join Date: Apr 2009
Snow tires won't come off?
Anyone else have trouble taking their snow tires off this spring?
I purchased new rims from Toyota last fall and they went on fine. It's like they are seized at the hubs. I whacked the tire (quite) a few times with a 2x4 after taking the lug nuts off, but there's no play at all. ![]() I'm kinda reluctant to spray penetrating oil on the hubs because it's so close to the brakes. Bill |
![]() ![]() ![]() ![]() ![]() Drives: 2007 Bayou Blue!!!!!!! Join Date: Nov 2006
I had a similar problem last fall when changing to the winter rims. Now that I'm changing back to summer rims I need to put some lube to prevent sticking. Will a good application of White grease help me out?
get non leaking grease made for high heat resistance. You should be able to find them at Canadian Tires. (since no US members replied to this thread yet. haha)
btw, i have had no problems getting my winter wheels off, as the civic rims sits 2mm larger than the hub ring. But the problem is over the winter, the hub ring has rusted, making it difficult for my summer rims to get on properly. When they are on, it becomes instantly difficult to remove. i have sanded it down, but i don't have much time to mess with it. |
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
Good thing this happens when you are in a garage. Not on the side of the road with a flimbsy car jack on an uneven surface while changing a flat tire. I just rotated my tires and there was a little sticking on one of the tires. Once on a Toyota truck I had to pound the tire from the back side with a sludge hammer. A little greese isn't a bad idea even if the tires come off easy.
Making a decision without following it with an action is still a fantasy. |
Cobra
Drives: '07 3-door Join Date: Jan 2007
Use anti-seaze next time between the wheels and the drum/rotors.
thanks guys, that did it.
when in doubt, get a bigger hammer. ![]() didn't have any anti-seize, but I'll get some in the fall before I put the snow tires back on. Bill |
| Newly installed 15" tires feel 'weird' | kristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 04-24-2010 06:58 PM |
| Snow tires - Really worth the money? | 33OH | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 42 | 01-19-2009 04:11 PM |
| stock steel rims for 15" snow tires | uspnpc | Willing to Buy by private party | 5 | 01-01-2009 11:23 PM |
| snow tires - which ones? | platypus | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 12-05-2008 01:06 PM |
| Snow tires | Phaeton | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 10-30-2008 08:43 PM |
