Old 05-01-2009, 08:14 PM   #19
frownonfun
frownonfun's Avatar
i really don't see this as the ugliest part of the yaris. looks like a button to open the hatch to me. might as well get rid of those pesky door handles while your at it.
Or buy a black hatchback and you hardly notice it/it already color-matches the car!
Cheers! M2
i still think maybe i should have gone with the black.
Old 05-01-2009, 09:07 PM   #20
MadMax
MadMax's Avatar
wouldn't be very hard to run a cable back there up to the front somewhere, then delete the exterior handle.
I really wish one of the bigger brains on this forum would do a DIY on this. I love my Yaris, I really do, but I would love it even more if it had a remote hatch release somewhere in the cockpit...and a way to lock it from the hatch that doesn't require using the key.
And I would need a mechanical solution, as I don't have power locks.
Cheers! M2
Old 05-01-2009, 10:00 PM   #21
uncleyaris
The hatch is such little space get rid of it all together if you want.
Old 05-02-2009, 08:39 AM   #22
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
^ LOL. He suggests a new car to fix that part. ok, that really is funny.
+1
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 05-02-2009, 09:26 AM   #23
another problem, even if you could unlatch it from somewhere else, it's gonna be hard to actually get a grip on the hatch itself in order to lift it up! Couple solutions though, you could somehow fit a spring to push the hatch back far enough so you can get your fingers under the bottom edge, or use a door popper which I believe is more or less a small electrically-actuated piston that will push the door out a bit...
Or get the electric trunk life damper thingie from a luxury sedan or van and retrofit that so it opens and closes the hatch all the way by itself
Old 05-02-2009, 12:54 PM   #24
^ Simpler than all that. Just use a stronger lift, it will open itself.
when I switched to a carbon fiber hatch, it would open itself with the stock lifts -- same concept.
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 02:57 PM
Not sure where to start (2009 yaris)... Faith87 General Yaris / Vitz Discussion 37 03-23-2009 05:35 PM
