Old 04-29-2009, 01:22 PM   #163
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
it wont be an issue as long as I can find the pin under the dash with help from PK's writeup or instructions/pics, whatever, lol
Old 04-29-2009, 11:36 PM   #164
I just posted a DIY for those with 09s, who wish to use the switch method:
http://www.yarisworld.com/forums/sho...783#post302783
Old 04-30-2009, 10:09 AM   #165
33OH
Drives: '08 Yaris
Hurry up PK!
Old 04-30-2009, 01:30 PM   #166
Pitt Yaris
Drives: Flint Mica Sedan
Very cool, I'm thinking of mounting the switch where my auto mirror adjustment would be to the left of the steering wheel
Old 05-01-2009, 09:10 PM   #167
I just added a note on my DIY in regards to cars with MT. TDB-1 PM'd me tonight. He attempted the two button method on his 09, and the on/off worked, but not the set. He inquired if there was anything different about a MT, and it turns out that the MT requires a second switch on the clutch for cruise.
The "Cruise Control Clutch Switch" is needed as well. This is a second clutch switch (there's already one called the "Clutch Start Switch"). The "Cruise Control Clutch Switch" connects to connector A29. Its part number is: 88280-14030 and it lists for ~$18.
Old 05-01-2009, 09:36 PM   #168
ahhh so its not the same as the clutch switch for the ignition inhibit
Seems pretty silly, except the start one detects fully pressed and the cruise on detects the initial press of the pedal.
Old 05-02-2009, 12:37 AM   #169
MGargano
Drives: 2009 Yaris Hatchback
Is the 'Cruise Control Clutch Switch' only needed if using your two button method on a MT? Will I still need it if I'm using the OEM stalk?
MGargano is offline   Reply With Quote
Old 05-02-2009, 04:09 AM   #170
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
Damn damn damn! I have an 08 MT. That's 2 strikes. My dream of $20 OEM CC is fading fast...
Old 05-02-2009, 07:57 AM   #171
Yes, the clutch switch is just for MT, and it is still needed with the OEM stalk. It keeps the car from over revving if you press the clutch while in cruise mode.
Old 05-02-2009, 10:24 AM   #172
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
There's no way of rigging your own MT Clutch Switch for doing this DIY? Not that 18 bucks is that bad, but if you didn't want to wait around for the thing to show and could possibly use some stuff you have laying around in your electronics drawer?
My Car Rules!
nickhjort is offline   Reply With Quote
Old 05-02-2009, 10:37 AM   #173
TDB-1
Drives: 09 3-door 5speed
cruise
Ok I just finished up my 2 button cruise setup on my 09 3 door 5speed. I did everything as per the DIY and it works great!!!! I had to jump the clutch switch for the test until I get the correct switch. This works just don't step on the clutch while on cruise or the engine could over rev. I got my switches at Radio Shack for $2.69 each and they look identical to the ones in the DIY. I used 2- 330 ohm resisters also from Radio Shack that cost $.99 for a 5 pack. This is the best thing I did to the car since I got it. THANKS to all who figured this was possible
TDB-1 is offline   Reply With Quote
Old 05-02-2009, 11:09 AM   #174
nickhjort
nickhjort's Avatar
Also I searched quick and I couldn't find anything on removing the dash for the 07 liftback 3dr. Does anyone know where I might find a quick reference guide?
My Car Rules!
Old 05-02-2009, 11:37 AM   #175
nickhjort
nickhjort's Avatar
Found it...nevermind :) Also they got my Clutch switch at the nearby dealer for 19 bucks. So I'll just splurge and pick me up one of those later this week. But I'll jump it for now, just so I can test it :)
My Car Rules!
Old 05-02-2009, 12:18 PM   #176
nickhjort
nickhjort's Avatar
Yup that's where I found it. Thanks :)
My Car Rules!
Old 05-02-2009, 05:08 PM   #177
nickhjort
nickhjort's Avatar
PK198105 or CTScott, or anybody for that matter :)
PK198105 mentioned if you didn't have blue wires under the sterring wheel, then you'd have to find the AD4 junction box. Well my car is ripped apart (see picture) and I need help finding the right box and which wires to splice into for this cruise control. I set my switches up just like CTScott has them and now I just need to splice wires. Please help me when you guys get a chance. I wanna drive my car by, at least, tomorrow...By the way all these pics are of the top left section of where my dash used to be :) Is there where I should be looking for this "AD4 junction box"?
Also where might I splice the LED wires so that the LED comes on when the cruise is on? Any ideas?
My Car Rules!
Old 05-02-2009, 06:03 PM   #178
Nice pictures! How hard was it to remove the top?
I am out right now for about two more hours. As soon as I am home, I'll look closer and get back to you.
Old 05-02-2009, 06:15 PM   #179
nickhjort
nickhjort's Avatar
Thank you so much, I have about 3 hours before the sun light is bye bye. It wasn't too hard to remove the top. Couple scratches and bruises on my hands, but now that I know how, of course, I can do it a lot quicker next time.
My Car Rules!
Old 05-02-2009, 06:23 PM   #180
nickhjort
nickhjort's Avatar
I'm not the best at reading wiring diagrams, but from what I can see my car doesn't even have this "ad4 plug" see picture...
And I can't find a plug hanging down that would plug into the Clutch Switch for Cruise Control. I can see where the switch mounts to the Clutch Pedal Mount...but no plug. Please help me :(
My Car Rules!
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
